Steam Games Won't Load
A place where Linux Gamers can share their experience and help each other with Linux Games, native or emulated ;)
DeftPon3
Post by DeftPon3 » Thu Mar 13, 2014 0:49
Hey everyone! I would like to start by saying I absolutely love Sabayon Linux. I just started using it and it has become my favorite Linux distribution. I however have run into an issue with playing Steam games. I download the games just fine (Portal 2 and Metro Last Light), but when I click "PLAY" my screen goes black for a split second (as if the game were about to appear) but then I just go back to my desktop. I figure it may be a graphics driver issue. I have not installed any of my own graphics drivers, I am using whatever Sabayon came with when I installed it. I have a ATI Mobility Radeon HD 5650. Any help would be much appreciated :)
Re: Steam Games Won't Load
Post by Stupot » Thu Mar 13, 2014 16:05
What's the output of:
# eselect opengl list
That will be needed for anybody who hopes to help.
DeftPon3
Post by DeftPon3 » Thu Mar 13, 2014 17:27
Thanks for your reply! :) I got this output.
[1] xorg-x11 *
[2] ati
[3] nvidia
Post by Stupot » Thu Mar 13, 2014 19:45
You'll probably want to use ati proprietary drivers for running games.
From gentoo's wiki (all of these work for Sabayon):
This will modify an existing xorg.conf to use the fglrx driver with a single screen:
root # aticonfig --initial --input=/etc/X11/xorg.conf
For dual-head configuration use this instead (where the second screen is [left|right|above|below]):
root # aticonfig --initial=dual-head --input=/etc/X11/xorg.conf --screen-layout=[left|right|above|below]
Set the OpenGL driver to use fglrx:
root # eselect opengl set ati
Then reboot.
If for some reason that leave you in a horrible state and you can't do anything, this will revert that change:
root # mv /etc/X11/xorg.conf /etc/X11/xorg.conf.bak
root # eselect opengl set xorg-x11l
then reboot.
DeftPon3
Post by DeftPon3 » Thu Mar 13, 2014 21:16
When I enter "aticonfig --initial --input=/etc/X11/xorg.conf" into terminal (as su), I get "bash: aticonfig: command not found". I am not the most experienced Linux user, so I might be doing something wrong. Any idea as to what I am doing wrong? :)
Post by Stupot » Thu Mar 13, 2014 23:00
Hmm, maybe you need to set the opengl first (my bad)..
If that doesn't work, you can follow the guide in the wiki, although truthfully it goes way above and beyond what should need to be done to make the switch:
https://wiki.sabayon.org/index.php?titl ... e_to_FGLRX
DeftPon3
Post by DeftPon3 » Fri Mar 14, 2014 2:51
Yeah :/ I get this output:
"!!! Error: The ati OpenGL implementation doesn't seem to provide
!!! Error: libGL.so file. This might be an effect of breakage introduced
!!! Error: by a prioprietary driver installer. Please re-merge the package
!!! Error: providing your OpenGL implementation.
!!! Error: Selected OpenGL implementation incomplete.
exiting".
Do you think that perhaps downloading and installing the driver from ATI would make it work? Or do you think that would break my system?
Post by Stupot » Fri Mar 14, 2014 15:16
Reinstall the ati-drivers through entropy (the Sabayon package manager). Instructions on how to do so were in the wiki I linked you, specifically:
root # equo install x11-drivers/ati-drivers amdcccle
Post by joost » Fri Mar 14, 2014 22:05
This might be an effect of breakage introduced by a prioprietary driver installer.
NEVER install the ATI/AMD drivers directly from their website, it breaks everything.
DeftPon3
Post by DeftPon3 » Sun Mar 16, 2014 0:09
Okay! I'll give it a shot. Thank you very much for your help! :)
