Installing Sabayon inside of Virtual Box on Mint [Solved]
Discussion for all VM - Installing, Software, Problems
mcmillhj
Post by mcmillhj » Tue Jan 28, 2014 18:02
It may be something very obvious that I missed since I am not familiar with Gentoo or Sabayon specifics, but I just downloaded the Saboyon 14.01 GNOME ISO to install in VirtualBox to see how I liked Sabayon.
The installation process went smoothly, and I encountered no errors. However, after the post-install reboot I didn't see my local user that I created during the install process. I only see a user called 'Sabayon', which didn't seem that normal since there is no point to ask for a username if it won't be created.
I verified that the user didn't exist on the system by checking for an entry /etc/passwd
Here are the VirtualBox configurations I used when installing Sabayon:
Architecture : Gentoo (64 bit)
RAM          : 1 GB
CPUs         : 1
DISK         : 12 GB
Any thoughts/suggestions would be helpful.
Thanks.
Hunter.
Re: Installing Sabayon inside of Virtual Box on Mint host
Post by Stupot » Tue Jan 28, 2014 18:37
Are you sure your VM isn't still booting the iso as opposed to the virtual hard drive?
mcmillhj
Post by mcmillhj » Tue Jan 28, 2014 18:59
This is one of those moments when I should have just walked away for 10 minutes and come back. Thanks, that was exactly what happened. I forgot to unmount the disk image.
Thanks.
Hunter
Post by Stupot » Tue Jan 28, 2014 20:27
No problem. More often than not it's the easiest things we overlook. Don't forget to mark this thread as Solved, if you don't mind.
mcmillhj
Post by mcmillhj » Tue Jan 28, 2014 22:36
Is there an option to mark as solved? (If so I must be overlooking it). Or should I just edit the post title to include [Solved]?
Post by Stupot » Tue Jan 28, 2014 23:34
Sorry, I should have included this link:
viewtopic.php?f=86&t=17059
But yeah, basically edit the first post's title to end with [Solved]
