ssh configuration ? (doesn' work)[Solved]
fjkhf
Post by fjkhf » Wed Jan 01, 2014 13:11
Hello and I wish you a happy new year!
I want to use rsynch with ssh between 2 pcs on my lan.
I did:
/etc/init.d/sshd restart
and I edited :
/etc/ssh/sshd_config
in order to enable
Port 22
Is there sth else to be done? (I have installed on both pc2 openssh)
I am trying :
rsync -avzhe ssh /home/user1/temp/ [email protected]:/home/user2/temp/
Here : should I have user2 or the name of pc? (work-pc)
Thanks!
Cb7
Re: ssh configuration ? (doesn' work)
Post by Cb7 » Wed Jan 01, 2014 14:54
Editing /etc/ssh/sshd_config does not “enable” port. That's firewall's job. What you can do with it, is to tell SSH on which port listen for incoming connections.
If you're using OpenRC it should work, except for part I'm not sure about, which is rsync -avzhe ssh . Perhaps better would be:
rsync -avh -e 'ssh -i keyfile' /local [email protected]:/remote
As you've noticed, there's no -z, since there's no need for it on LAN (it only would slow down things, unless you don't have even 10 Mb/s of bandwidth on LAN…).
Note that your command will require to enter password every time. Better way would be to authenticate using keys.
Kind regards
~Zetok Zalbavar
fjkhf
Post by fjkhf » Wed Jan 01, 2014 17:22
Hello ,
I am trying to generate the keys.
From host (user1) , I did:
ssh-keygen -t dsa
From remote (user2) ,I did:
ssh-copy-id [email protected]
but it gives me:
/usr/bin/ssh-copy-id :ERROR : No identities found
Am I doing sth wrong here?
Post by sabayonino » Thu Jan 02, 2014 19:41
Hi
Is ssh daemon running ? (and starting its service at boot...)
For OpenRc
# /etc/init.d/sshd start && rc-update add sshd default
For Systemd (Default from scratch)
# systemctl start sshd.service && systemctl enable sshd.service
:roll:
Honeyman
Post by Honeyman » Fri Jan 03, 2014 0:29
fjkhf wrote:Hello ,
ssh-keygen -t dsa
but it gives me:
For copying your SSH-key onto the other machine you need to specity the location of your key:
ssh-copy-id -i ~/.ssh/id_dsa.pub [email protected]
That should work. I'm not quite sure you are copying from the correct machine to the machine intended. You need to copy the key from the machine where you generated the key to the machine where you want to login. On that machine there must already exist a user you can login in order for the copy-command to work.
For example:
On machine1:
[email protected]:$ ssh-keygen -t dsa
Copy the SSH-key from machine1 to machine2 (There logging in as user2):
[email protected]:$ ssh-copy-id -i ~/.ssh/id_dsa.pub [email protected]
I hope that is somewhat clear :roll:
Je me regarde pour me désoler,
je me compare pour me consoler
Maurice de Talleyrand
fjkhf
Post by fjkhf » Sat Jan 04, 2014 10:15
Excellent!!!!!
Thank you both!
I think it needed both commands:
and
Thanks!
