Are We There Yet? Systemd
Postby sqlpython » Wed Oct 23, 2013 22:50
This past 4 days or so I updated my Sabayon Xfce to 13.11 with all accompanying apps on my system.
Looks like this Now after some adjustments...
 sqlpython@bobs-sl410 ~ $ systemd --version
systemd 204
+PAM +LIBWRAP -AUDIT -SELINUX +IMA -SYSVINIT +LIBCRYPTSETUP -GCRYPT +ACL +XZ
sqlpython@bobs-sl410 ~ $ lsb_release -a
LSB Version:   n/a
Distributor ID:   Sabayon
Description:   Sabayon Linux x86 13.11
Release:   n/a
Codename:   n/a
And I am really impressed with this update, artwork also.
Great packaging and execution..
Problem is this....
Grub was also updated and did wipe out my modification to boot into systemd.
I didn't notice at first because the boot times on the sysvinit is much improved.
But when I was checking with
systemdctl -a
and such command I was getting dbus connection failures. This due to systemd not running at the time.
So, I corrected my grub to boot to systemd..
and
eselect sysvinit set systemd
Rebooted again and all seems ok now.
After demonstrating the problem and adjustments the Question is:
Why didn't the Update just come up smiling as systemd but instead went back to sysvinit?
I thought since 13 that all installs would default to systemd including Grub info.
Perhaps is this because my install on this laptop started life as a fresh Sabayon 11 install?
If I could please get some dev feed back..
Or anyone that might know...
Criticism accepted for Solutions that work. ;^)
Sabayon 13-DEBIAN 8- #! -Sid-Slackware 14-Calculate 13-Bridge
sqlpython
Re: Are We There Yet? Systemd
Postby wolfden » Thu Oct 24, 2013 16:30
I was having similar issues with an install prior to the systemd push, but than I had hard drive failure and never got to sort it out and when I did a fresh install with a default systemd sabayon, all was good. So I'm guessing prior installs may have some things to sort out.
Postby sqlpython » Thu Oct 24, 2013 21:33
Yes, thanks for that..
Confirms my suspicions as to my version 11 not bringing all scripts up to a 13.xx systemd level.
Not a big deal, just wanted some confirmation.
Really happy with the latest !!
Quick and tightly built.
sqlpython
Postby Cb7 » Mon Nov 04, 2013 18:48
Actually on my install dating from Sabayon 11, there was no problem switching to systemd.
I haven't done anything but "eselect init" and adjusting services that were supposed to start, and it worked. No changes in grub were needed.
Kind regards
~Zetok Zalbavar
Cb7
Postby sqlpython » Mon Nov 04, 2013 20:01
Thanks, Good info. Don't know why then I had issues. Works now and I will just move forward.
sqlpython
Postby tollgate » Wed Nov 06, 2013 3:52
Are there some definitive instructions somewhere for upgrading to systemd? I tried upgrading one machine by using "eselect init set systemd" (which I came across in the forum somewhere), rebooted and x would no longer start. I haven't really tried to fix this but now get x to start by booting a previous kernel version and it's not using systemd.
tollgate
Postby sqlpython » Wed Nov 06, 2013 4:58
I posted my method in a thread here but it certainly isn't definitive except that it defines what I did..
viewtopic.php?f=57&t=29996&p=162887&hilit=+systemd#p162887
sqlpython
Postby lxnay » Wed Nov 06, 2013 8:08
That seems waaaay too complicate.
You just need to use eselect init and enable the services you use in openrc on systemd. "rc-update show" will tell you the former, "systemctl list-units" the latter. "systemctl enable/disable foo.service" is what you need, and the available units are in /usr/lib/systemd/system. You most likely need to either enable the gdm, kdm, lightdm, lxdm units basing on what is your login manager.
Follow me on Twitter
Add me on Facebook
Add me on Google+
lxnay
Land Owner
Postby tollgate » Wed Nov 06, 2013 9:37
Thanks for the instructions Lxnay. I will try again. I never realised about enabling the kdm unit so that's the most likely reason KDE would not start.
tollgate
Postby sqlpython » Mon Nov 18, 2013 16:14
^^ lxnay.. sorry missed that post earlier
I am a complicated Guy. :lol:
Now that I examine the latest advancements, You are of course Right.
I was continuing to follow the original How to ... that was outlined by Yourself when we introduced Systemd into the Sabayon. Unfortunately, I failed to keep up with Your improvements.. Noted and updated, Thanks.
sqlpython
