xchat removed from repos?
ReemZ
Post by ReemZ » Tue Jul 30, 2013 21:22
wtf?
>>  @@ Installation complete.
>>  @@ On the system there are packages that are not available anymore in the online repositories.
>>  @@ Even if they are usually harmless, it is suggested (after proper verification) to remove them.
>>  @@ These are the packages that would be removed:
>>  ## [sabayonlinux.org] net-irc/xchat-2.8.8-r2 [3.2MB]
>>  @@ To automatically remove them, please run equo with --purge.
>>  @@ Nothing to remove.
>>  @@ No configuration files to update.
# equo search xchat
>>  @@ Searching...
>>      @@ Package: net-irc/hexchat-2.9.5_p20130525 branch: 5, [sabayonlinux.org]
>>         Available:     version: 2.9.5_p20130525 ~ tag: NoTag ~ revision: 0
>>         Installed:     version: Not installed ~ tag: N/A ~ revision: N/A
>>         Slot:          0
>>         Homepage:      http://www.hexchat.org/
>>         Description:   Graphical IRC client based on XChat
>>         License:       GPL-2
>>      @@ Package: net-irc/xchat-gnome-0.26.1-r2 branch: 5, [sabayonlinux.org]
>>         Available:     version: 0.26.1-r2 ~ tag: NoTag ~ revision: 1
>>         Slot:          0
>>         Homepage:      http://xchat-gnome.navi.cx/
>>         Description:   GNOME frontend for the popular
>>                        X-Chat IRC client
>>         License:       GPL-2
>>  Keywords:  xchat
>>  Found:     2 entries
Handtekening? Zeg...ik ga niet op m'n monitor schrijven!
Re: xchat removed from repos?
Post by joost » Wed Jul 31, 2013 10:19
It is discontinued.
You can replace it with hexchat.
You can migrate your settings like this:
https://github.com/Sabayon/skel/commit/ ... 9e4fb8bd7d
So:
cp ~/.xchat2/xchat.conf ~/.config/hexchat/hexchat.conf
life-on-mars
Post by life-on-mars » Wed Jul 31, 2013 13:04
joost wrote:It is discontinued.
Is there a blog or something that documents changes like these? It happens quite often in Sabayon and can cause a great deal of inconvenience if it goes unnoticed.
sɹɐɯ uo əɟıɿ sı əɹəɥʇ -- ⠐⠮ ⠊⠎ ⠇⠊⠋⠑ ⠕⠝ ⠍⠜⠎⠖
Post by joost » Wed Jul 31, 2013 13:23
Examples?
Understand that we are a rolling release. Things fork/move/remove around all the time.
ReemZ
Post by ReemZ » Wed Jul 31, 2013 13:38
joost wrote:Understand that we are a rolling release. Things fork/move/remove around all the time.
Understood. But, please answer the man's question mate:
life-on-mars wrote:Is there a blog or something that documents changes like these?
Perhaps a line in the repo notice could help solve this kind of problem before it arises ;)
Post by joost » Wed Jul 31, 2013 13:49
Some background information can be found here:
http://www.gossamer-threads.com/lists/g ... w_threaded
lxnay
Land Owner
Post by lxnay » Wed Jul 31, 2013 15:49
Programs die, change name or get forked. That's life.
We track upstream Gentoo and it happened the same with xchat.
Given that we handle 13000 packages per architecture, I'm not sure if we should (and have the man power) consider certain packages more "special" than what they are.
This is Free Software and is provided without warranty.
Follow me on Twitter
Add me on Facebook
Add me on Google+
life-on-mars
Post by life-on-mars » Wed Jul 31, 2013 16:13
joost wrote:Examples?
lxnay wrote: Given that we handle 13000 packages per architecture, I'm not sure if we should (and have the man power) consider certain packages more "special" than what they are.
XChat was a default package in at least one Sabayon iso. Unless default packages are just a random selection of apps, I would say that makes them more "special" than other packages. And changing packages like consolkit can possibly break things. And regarding the manpower, have you considered asking the community on the forums? I am sure there are a lot of us who would like to help. (Though it might be helpful not to ask volunteers for their full resumé and telephone number like you do it in the wiki.)
Actually, making the upgrade process more transparent would most likely make things much easier for all. Try counting the number of bug reports and support threads that were caused by feature and package changes. I doubt the amount of work they cause is less significant than adding 1-2 lines on a notice board.
lxnay wrote:This is Free Software and is provided without warranty.
I would expect such a statement from companies like Google, but not from someone involved in a GNU/Linux distro. We all know that it doesn't come with a "warranty" and no one is going to sue you, but as a community we can improve things if there is a demand for it.
ReemZ
Post by ReemZ » Wed Jul 31, 2013 18:26
joost wrote:Some background information can be found here:
Good bit of info, thanks!
However, in his post, god at politeia states hexchat development to have stalled:
The same way XChat's development died some time ago (with the exception of some critical patches here and there), HexChat's development has met a wall. The only active developer has quit the project. I hope this does not mean the end of the project as there are a couple of contributors who seem interested in further developing HexChat (they have write access to hexchat's github repo so further versions will depend on them).
This was eight months ago.
What's hexchat's current status? Can we expect it to be removed from the tree as well?
ReemZ
Post by ReemZ » Wed Jul 31, 2013 18:37
Sidenote, Entropy still thinks hexchat's website to be http://www.hexchat.org. However, this 404's.
Wikipedia has a link at the bottom that works: http://hexchat.github.io/
