Upgrade trashed my system and now Rigo won't start!?
life-on-mars
Re: Upgrade trashed my system and now Rigo won't start!?
Post by life-on-mars » Mon Jul 29, 2013 12:50
VolvoBirkenstock wrote:However, no version number was returned for "entropy", and this deviates from the description seen in http://wiki.sabayon.org/index.php?title=En:Entropy.
equo s entropy
That should give you the entropy version.
I wouldn't count that much on anything written in the wiki. Much of it is either incorrect or outdated. Most likely because wiki.sabayon.org is not open for everyone (looks more like an invite-only club to me).
sɹɐɯ uo əɟıɿ sı əɹəɥʇ -- ⠐⠮ ⠊⠎ ⠇⠊⠋⠑ ⠕⠝ ⠍⠜⠎⠖
VolvoBirkenstock
Post by VolvoBirkenstock » Wed Jul 31, 2013 0:55
Thank you, life-on-mars.
The entropy version has checked out as the correct one.
Now if only I could get rigo working...
VolvoBirkenstock
Post by VolvoBirkenstock » Wed Jul 31, 2013 3:49
I just discovered that I can run rigo from the command line if I am root. When I run rigo as root, equo update reports nothing new, even though I use sabayon weekly and my last update was last week. I still cannot start rigo from either the command line or the desktop icon if I am a "regular user".
VolvoBirkenstock
Post by VolvoBirkenstock » Wed Jul 31, 2013 3:51
By the way, when I run rigo from the command line as root and try to manage repositories, the rigo display blanks along with the following written to the konsole where root started rigo:
  File "/usr/lib/rigo/rigo/ui/gtk3/widgets/cellrenderers.py", line 1035, in do_render
    is_rtl)
  File "/usr/lib/rigo/rigo/ui/gtk3/widgets/cellrenderers.py", line 902, in _render_icon
    icon = self._icon
  File "/usr/lib/rigo/rigo/ui/gtk3/widgets/cellrenderers.py", line 890, in _icon
    self._icon_size, 0)
  File "/usr/lib64/python2.7/site-packages/gi/types.py", line 113, in function
    return info.invoke(*args, **kwargs)
gi._glib.GError: Failed to load icon
(rigo:11465): GLib-GIO-CRITICAL **: g_file_new_for_path: assertion `path != NULL' failed
(rigo:11465): GLib-GIO-CRITICAL **: g_loadable_icon_load: assertion `G_IS_LOADABLE_ICON (icon)' failed
    is_rtl)
    icon = self._icon
    self._icon_size, 0)
Post by joost » Wed Jul 31, 2013 8:11
joost wrote:A guess, maybe this will fix it.
run as root:
equo install gdk-pixbuf
VolvoBirkenstock
Post by VolvoBirkenstock » Thu Aug 01, 2013 1:57
Thank you, joost. That fixed it. The gdk-pixbuf now on my system is x11-libs/gdk-pixbuf-2.28.2. This is the same revision on my system that I reported in the 9th post to this thread. Did another package downloaded during an upgrade overwrite something normally distributed under x11-libs/gdk-pixbuf-2.28.2? Otherwise I have no idea what could have caused this issue.
I would mark this thread "Solved", except that I'm not the original author.
Again, thank you very much, joost. Most excellent. :-)
