Upgrade trashed my system and now Rigo won't start!?
LichPortal
Post by LichPortal » Fri Jul 26, 2013 22:18
I was running Sabayon 11 KDE, did an upgrade via Rigo, and (after a couple of hours) the upgrade process stopped dead. Something had obviously died silently.
I rebooted and logged in, but I only got a console. I.e., no X-windows, no KDE, no nothing. Couldn't even run a browser to ask for help on this forum. OK, this is serious. The upgrade pretty much trashed my existing system. :x
Not knowing what else to do, I reinstalled Sabayon 11 from scratch off my original DVD, downloaded the iso file for Sabayon 13.04, and installed it (i.e., as a fresh install). Seemed ok.
Then I opened Rigo. It said upgrades were available, so I told it to apply them all. Seemed ok, and I rebooted my system.
But now, when I try to start Rigo from the launcher, the little icon just bounces for a while and then silently disappears. I.e., Rigo fails to start. I don't get a popup error message. Nothing. What's gone wrong? How do I fix it?
Re: Upgrade trashed my system and now Rigo won't start!?
Post by joost » Fri Jul 26, 2013 22:32
try launching it from a shell.
Without more details we certainly have no idea.
Open terminal/Konsole and type in (as normal user) "rigo" then copy paste the output here.
life-on-mars
Post by life-on-mars » Sat Jul 27, 2013 5:28
Perhaps you can resume the upgrade with equo from a terminal:
equo upgrade
sɹɐɯ uo əɟıɿ sı əɹəɥʇ -- ⠐⠮ ⠊⠎ ⠇⠊⠋⠑ ⠕⠝ ⠍⠜⠎⠖
LichPortal
Post by LichPortal » Sat Jul 27, 2013 5:50
joost wrote:Open terminal/Konsole and type in (as normal user) "rigo" then copy paste the output here.
OK, here's the output:
rigo:7114): GLib-GIO-CRITICAL **: g_file_new_for_path: assertion `path != NULL' failed
(rigo:7114): GLib-GIO-CRITICAL **: g_loadable_icon_load: assertion `G_IS_LOADABLE_ICON (icon)' failed
(rigo:7114): GLib-GIO-CRITICAL **: g_file_new_for_path: assertion `path != NULL' failed
(rigo:7114): Gtk-WARNING **: gtkwidget.c:5826: widget `GtkEntry' has no activatable signal "move-cursor" without arguments
(rigo:7114): Gtk-WARNING **: gtkwidget.c:5826: widget `GtkEntry' has no activatable signal "delete-from-cursor" without arguments
  File "/usr/bin/rigo", line 994, in <module>
    app = Rigo()
  File "/usr/bin/rigo", line 273, in __init__
    True, AppListStore.ICON_SIZE, store=None)
  File "/usr/lib/rigo/rigo/ui/gtk3/widgets/apptreeview.py", line 66, in __init__
    scrolling_cb=_is_scrolling)
  File "/usr/lib/rigo/rigo/ui/gtk3/widgets/cellrenderers.py", line 103, in __init__
    self.OVERLAY_SIZE, 0)
  File "/usr/lib64/python2.7/site-packages/gi/types.py", line 113, in function
    return info.invoke(*args, **kwargs)
gi._glib.GError: Failed to load icon
LichPortal
Post by LichPortal » Sat Jul 27, 2013 6:01
life-on-mars wrote:Perhaps you can resume the upgrade with equo from a terminal: [...]
The upgrade appeared to have finished -- except for a complaint about 3 config files needing checking and updating (which is a bit bizarre -- how would a newbie know what to do with them??).
Anyway, I ran "equo upgrade", and it said the same thing and told me there's nothing to upgrade or remove, but then told me to run "equo conf update", so I did. I chose the "-5" option (automerge all the files without questioning). Then I rebooted. But... no change. Rigo still gives the same errors as posted above. :cry:
Post by joost » Sat Jul 27, 2013 15:12
A guess, maybe this will fix it.
run as root:
equo install gdk-pixbuf
//edit: fixed a typo
LichPortal
Post by LichPortal » Sun Jul 28, 2013 2:11
joost wrote:A guess, maybe this will fix it.
run as root:
equo install gdk-pixbug
Alas, no...
# equo install gdk-pixbug
>> !!! No match for gdk-pixbug in repositories.
>> ? When you wrote gdk-pixbug You Meant(tm) one of these below?
>> # dev-perl/GD-SVG
>> # x11-libs/gdk-pixbuf
>> # dev-vcs/git-cvs
>> # dev-vcs/git-subversion
>> # dev-util/gtk-builder-convert
>> # net-libs/gtk-vnc
>> # dev-perl/gtk2-fu
>> # dev-perl/gtk2-perl
>> # games-puzzle/gtkballs
>> # games-board/gtkboard
>> # app-benchmarks/gtkperf
>> # app-pda/gtkpod
>> # app-text/gtkspell
>> # app-text/gtkspell
>> # dev-python/gtkspell-python
>> # sci-electronics/gtkwave
>> No packages found.
Edit: Guessing that you might have meant "equo install gdk-pixbuf", I tried the latter, which seemed to perform a nontrivial install. After reboot, Rigo now starts up, so it seems your guess was right (modulo a typo).
But... I guess this means the tree of Rigo's dependencies is broken somewhere? That's kinda serious, no?
life-on-mars
Post by life-on-mars » Sun Jul 28, 2013 2:52
After each upgrade, perhaps even after each software install, you should also run equo deptest and equo libtest, and as I recently came to realise, check your eselect settings (some upgrades seem to reset them). If you don't do this, evil things happen sooner or later. :twisted:
VolvoBirkenstock
Post by VolvoBirkenstock » Sun Jul 28, 2013 3:57
My system very recently suffered a hard-drive failure (the hard drive was 8 months old :evil:), and I am now attempting to complete a fresh installation. My system is allegedly fully current now. I have also placed a few extra packages, including the 3.10.0 kernel and sources, as well as the ATI drivers and the vim editor. Other than this, I have not placed the additional packages I need which go beyond a LiveCD/DVD install.
I am also seeing a Rigo failure. I am hoping this can be fixed quickly since I very greatly depend on Rigo.
As for the suggestion regarding "gdk-pixbug", I think joost likely meant "gdk-pixbuf".
I performed "su" to root.
I executed "equo query gdk-pixbuf" and this was returned:
Titanic / # equo query installed gdk-pixbuf
>>  @@ Searching...
>>      @@ Package: x11-libs/gdk-pixbuf-2.28.2 branch: 5, [__system__]
>>         Installed:     version: 2.28.2 ~ tag: NoTag ~ revision: 0
>>         Slot:          2
>>         Homepage:      http://www.gtk.org/
>>         Description:   Image loading library for GTK+
>>         License:       LGPL-2+
>>  Keywords:  gdk-pixbuf
>>  Found:     1 entry
The following was returned by "equo deptest" and "equo libtest":
Titanic / # equo deptest
>>  @@ Running dependency test...
Titanic / # equo libtest
>>  @@ Libraries test
>>  @@ discarding directory: /usr/lib64, because it's symlinked on: /usr/lib
>>  @@ discarding directory: /lib64, because it's symlinked on: /lib
>>  @@ Collecting broken executables
>>  @@ Attention: don't worry about libraries that are shown here but not later.
>>  @@ Matching broken libraries/executables
>>  @@ System is healthy.
I also executed "equo update" and was told the repository was up-to-date. I then forced the update by executing "equo update --force". After this I executed "equo install entropy rigo" and the result follows:
Titanic / # equo install entropy rigo
>>  @@ Calculating dependencies...
>>  ## [R] [sabayon-weekly] app-admin/rigo-210|0   [210|0]
>>  ## [R] [sabayon-weekly] sys-apps/entropy-210|0   [210|0]
>>  @@ Packages needing to be installed/updated/downgraded: 2
>>  @@ Packages needing to be removed: 0
>>  @@ Download size: 0b
>>  @@ Freed disk space: 0.0b
>>  @@ You need at least: 1.5MB of free space
>>  ::: >>>  (1/1) 2 packages
>>    ## Package checksum matches: app-admin:rigo-210.279b2fd7e6b33c8da16d98784e143d955dc5a15e~0.tbz2
>>    ## Package checksum matches: sys-apps:entropy-210.46e24c51d1c15d4112f04c0dd99b557d8c688cb4~0.tbz2
>>  +++ >>>  (1/2) app-admin/rigo-210
>>    ## Unpacking: app-admin:rigo-210.279b2fd7e6b33c8da16d98784e143d955dc5a15e~0.tbz2
>>    ## Installing package: app-admin/rigo-210
>>    ## [Rigo, the Sabayon Application Browser]
>>    ## Updating database: app-admin/rigo-210
>>    ## Cleaning previously installed application data.
>>    ## Package phase: postremove
 * Updating shared mime info database ...
 * Updating desktop mime database ...
>>    ## Package phase: postinstall
 * Compilation and optimization of Python modules placed outside of site-packages directories for CPython 2.7 ...                                        [ ok ]
>>    ## Cleaning: app-admin/rigo-210
>>  +++ >>>  (2/2) sys-apps/entropy-210
>>    ## Unpacking: sys-apps:entropy-210.46e24c51d1c15d4112f04c0dd99b557d8c688cb4~0.tbz2
>>    ## Package phase: setup
>>    ## Installing package: sys-apps/entropy-210
>>    ## [Entropy Package Manager foundation library]
>>    ## Updating database: sys-apps/entropy-210
>>> Regenerating /etc/ld.so.cache...
 * Purging current Entropy cache
 * If you want to enable Entropy packages delta download support, please
 * install dev-util/bsdiff.
>>    ## Cleaning: sys-apps/entropy-210
>>  @@ Installation complete.
>>  @@ No configuration files to update.
I then executed "equo --version" and as expected it returned "210". However, no version number was returned for "entropy", and this deviates from the description seen in http://wiki.sabayon.org/index.php?title=En:Entropy.
Thank you very much in advance.
VolvoBirkenstock
Post by VolvoBirkenstock » Sun Jul 28, 2013 4:01
What follows is what is pumped to stderr when I enter "rigo" on the command line as a non-root user:
Gtk-Message: (for origin information, set GTK_DEBUG): failed to retrieve property `gtk-toolbar-style' of type `GtkToolbarStyle' from rc file value "((GString*) 0x339f8c0)" of type `GtkToolbarStyle'
(rigo:7219): GLib-GIO-CRITICAL **: g_file_new_for_path: assertion `path != NULL' failed
(rigo:7219): GLib-GIO-CRITICAL **: g_loadable_icon_load: assertion `G_IS_LOADABLE_ICON (icon)' failed
(rigo:7219): Gtk-WARNING **: gtkwidget.c:5826: widget `GtkEntry' has no activatable signal "move-cursor" without arguments
(rigo:7219): Gtk-WARNING **: gtkwidget.c:5826: widget `GtkEntry' has no activatable signal "delete-from-cursor" without arguments
    app = Rigo()
Thank you again for your assistance.
