XFCE mouse cursor
koge
XFCE mouse cursor
Post by koge » Mon Jul 22, 2013 12:15
I can't change my mouse cursor in XFCE or MATE. In Sabayon 11 I was able change that but not anymore in 13.04 or newer. Any suggestions.
svantoviit
Re: XFCE mouse cursor
Post by svantoviit » Tue Jul 23, 2013 9:00
XFCE: Applications → Settings → Mouse and Touchpad
You will probably need to log out and in to make the changes work.
koge
Post by koge » Tue Jul 23, 2013 12:17
Doesn't work anymore!
matuss
Post by matuss » Tue Jul 23, 2013 14:46
I must say it works, did it a few seconds ago :)
did you log out and back in after setting it?
koge
Post by koge » Tue Jul 23, 2013 19:55
I did reboot. Im running fresh install 13.07
koge
Post by koge » Sat Jul 27, 2013 22:10
Ok I just installed latest daily and the problem still occurs. It's really annoying. In Chromium and some other programs cursor changes to whatever I have chosen. But only partially like wait and hand over link otherwise only black dmz.
