Skype connect only if root
ezioze
Post by ezioze » Thu Jul 11, 2013 11:16
Hi all.
After last update, skype works only if started as root.
If started as normal user it won't connect
Any help?
Re: Skype connect only if root
Post by Fitzcarraldo » Thu Jul 11, 2013 21:07
Run Skype from the command line in a Konsole/Terminal window under your own user account, and paste here the output.
$ skype
ezioze
Post by ezioze » Fri Jul 12, 2013 8:21
Hi.
This is what i see:
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 78: saw unknown, expected number
then skype start but it doesn't connect (grey icon rotating) and no other messages
(to close skype i have to do CTRL+C in terminal)
Post by Fitzcarraldo » Fri Jul 12, 2013 18:01
Please post the output of the following command, issued in a Konsole/Terminal window under your own user account:
ls -la ~/.Skype/
ezioze
Post by ezioze » Sat Jul 13, 2013 9:08
[email protected] ~ $ ls -la ~/.Skype/
totale 100
drwx------ 6 ezio ezio 4096 11 lug 18.52 .
drwxr-xr-x 161 ezio ezio 12288 13 lug 09.52 ..
drwx------ 2 ezio ezio 4096 11 lug 18.52 DbTemp
drwxr-xr-x 5 ezio ezio 4096 11 lug 18.52 ezioze
drwxr-xr-x 2 ezio ezio 4096 11 lug 18.52 shared_dynco
drwxr-xr-x 2 ezio ezio 4096 11 lug 18.52 shared_httpfe
-rw-r--r-- 1 ezio ezio 0 1 ott 2010 shared.lck
-rw------- 1 ezio ezio 66869 11 lug 18.52 shared.xml
Post by Fitzcarraldo » Sun Jul 14, 2013 0:50
All that looks OK to me. Try the following:
$ mv ~/.Skype/ ~/.Skype.bak/
then start Skype under your own user account, not root.
ezioze
Post by ezioze » Sun Jul 14, 2013 9:07
I just tried that 2 day ago after googoling
Post by Fitzcarraldo » Sun Jul 14, 2013 11:09
Have you checked if any other process is accessing the Skype lock file simultaneously? After you launch Skype under your own user account, open a Konsole/Terminal window and enter the following commands:
$ lsof | grep '.Skype'
You can tell the process ID for Skype by using the command:
$ ps -ef | grep skype
The only process accessing the .Skype files should be Skype. If any other process is trying to access them, kill it:
$ kill -9 <process ID>
ezioze
Post by ezioze » Sun Jul 14, 2013 18:04
just made this check. No other process lock slype files
Post by Fitzcarraldo » Sun Jul 14, 2013 22:36
Although I don't think it is the cause, have you checked if all the dependencies, libraries and configuration files are correct?
# equo conf update
# equo deptest
# equo libtest
Have you tried uninstalling Skype and re-installing it?
