Philips PCVC675K doesn't work
Alex7793
Post by Alex7793 » Fri Jul 05, 2013 1:44
Hello to all!
I've just upgraded to Sabayon 13.04, and i cannot make work webcam.
When I try to use it appears a disturbed screen or a totally red screen depending of software.
Uname -a output
Linux Spitfire 3.8.0-sabayon #1 SMP Fri May 24 17:20:54 UTC 2013 x86_64 AMD Athlon(tm) 64 Processor 3000+ AuthenticAMD GNU/Linux
lsusb
 lsusb
Bus 002 Device 002: ID 0471:0307 Philips (or NXP) PCVC675K Webcam [pwc]
Bus 004 Device 002: ID 04a9:220d Canon, Inc. CanoScan N670U/N676U/LiDE 20
Bus 004 Device 003: ID ffff:0000
Bus 005 Device 003: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
xawtv -c /dev/video0
This is xawtv-3.95, running on Linux/x86_64 (3.8.0-sabayon)
WARNING: v4l-conf is compiled without DGA support.
/dev/video0 [v4l2]: no overlay support
v4l-conf had some trouble, trying to continue anyway
ioctl: VIDIOC_ENUMSTD(index=0;id=0x0 [];name="";frameperiod.numerator=0;frameperiod.denominator=0;framelines=0): ioctl non appropriata per il device
Warning: Missing charsets in String to FontSet conversion
Warning: Cannot convert string "-*-ledfixed-medium-r-*--39-*-*-*-c-*-*-*" to type FontStruct
ioctl: VIDIOC_G_STD(std=0x7fa2ec70bdb0 [PAL_I,PAL_D,PAL_K,PAL_M,PAL_Nc,PAL_60,NTSC_M,NTSC_M_JP,?,SECAM_K,SECAM_K1,SECAM_L,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)]): ioctl non appropriata per il device
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x32315559 [YU12];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=0;fmt.pix.colorspace=unknown;fmt.pix.priv=0): Dispositivo o risorsa occupata
ioctl: VIDIOC_S_CTRL(id=9963778;value=0): ioctl non appropriata per il device
ioctl: VIDIOC_S_CTRL(id=9963776;value=63): ioctl non appropriata per il device
ioctl: VIDIOC_S_CTRL(id=9963777;value=48): ioctl non appropriata per il device
ioctl: VIDIOC_S_STD(std=0x0 []): ioctl non appropriata per il device
no way to get: 384x288 32 bit TrueColor (LE: bgr-)
mplayer tv:// -tv driver=v4l2:width=352:height=288:device=/dev/video0 -fps 15
MPlayer 1.1-4.7.3 (C) 2000-2012 MPlayer Team
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing tv://.
TV file format detected.
Selected driver: v4l2
 name: Video 4 Linux 2 input
 author: Martin Olschewski <[email protected]>
 comment: first try, more to come ;-)
v4l2: your device driver does not support VIDIOC_G_STD ioctl, VIDIOC_G_PARM was used instead.
Selected device: Philips 675 webcam
 Capabilities:  video capture  read/write  streaming
 supported norms:
 inputs: 0 = Camera;
 Current input: 0
 Current format: YUV420
v4l2: ioctl set format failed: Invalid argument
tv.c: norm_from_string(pal): Bogus norm parameter, setting default.
v4l2: ioctl enum norm failed: Inappropriate ioctl for device
Error: Cannot set norm!
Selected input hasn't got a tuner!
v4l2: ioctl set mute failed: Invalid argument
v4l2: ioctl query control failed: Invalid argument
[vdpau] Error when calling vdp_device_create_x11: 1
Opening video decoder: [raw] RAW Uncompressed Video
Movie-Aspect is undefined - no prescaling applied.
VO: [xv] 352x288 => 352x288 Planar I420
Selected video codec: [rawi420] vfm: raw (RAW I420)
Audio: no sound
FPS forced to be 15.000  (ftime: 0.067).
Starting playback...
V:   0.0 137/137  0%  1%  0.0% 0 0
v4l2: 139 frames successfully processed, 135 frames dropped.
Exiting... (Quit)
What can I do? thanks in advance
Re: Philips PCVC675K doesn't work
Post by Fitzcarraldo » Mon Jul 08, 2013 15:42
Let's have a look at the modules that your machine has loaded:
lsmod
Alex7793
Post by Alex7793 » Mon Jul 08, 2013 21:26
Module                  Size  Used by
rfcomm                 41248  4
bnep                   11485  2
bluetooth             236518  10 bnep,rfcomm
xt_hl                   1104  6
ip6t_rt                 4480  3
nf_conntrack_ipv6       7152  6
ip6table_filter         1088  1
ip6_tables             13529  1 ip6table_filter
bridge                 63497  0
stp                     1417  1 bridge
llc                     3248  2 stp,bridge
act_police              3224  0
cls_basic               3072  0
cls_flow                5120  0
cls_fw                  3280  0
cls_u32                 5552  0
sch_fq_codel            5264  0
sch_tbf                 3216  0
sch_prio                2992  0
sch_htb                10800  0
sch_hfsc               10464  0
sch_ingress             1296  0
sch_sfq                 7680  0
xt_CHECKSUM             1008  0
ipt_rpfilter            1552  0
xt_statistic            1040  0
xt_CT                   3456  18
xt_LOG                  9672  5
xt_connlimit            2736  0
xt_realm                 864  0
xt_addrtype             2192  4
xt_comment               816  16
xt_recent               6520  0
xt_nat                  1840  0
ipt_ULOG                8224  0
ipt_REJECT              1888  4
ipt_MASQUERADE          1856  0
ipt_ECN                 1584  0
ipt_CLUSTERIP           4848  0
ipt_ah                  1632  0
nf_nat_tftp              784  0
nf_nat_snmp_basic       6952  0
nf_conntrack_snmp       1064  3 nf_nat_snmp_basic
nf_nat_sip              6272  0
nf_nat_pptp             3136  0
nf_nat_proto_gre        1616  1 nf_nat_pptp
nf_nat_irc              1152  0
nf_nat_h323             6336  0
nf_nat_ftp              1744  0
nf_nat_amanda            976  0
ts_kmp                  1440  5
nf_conntrack_amanda     2144  3 nf_nat_amanda
nf_conntrack_sane       4488  2
nf_conntrack_tftp       4032  3 nf_nat_tftp
nf_conntrack_sip       17709  3 nf_nat_sip
nf_conntrack_proto_udplite     3136  0
nf_conntrack_proto_sctp     9248  0
nf_conntrack_pptp       7112  3 nf_nat_pptp
nf_conntrack_proto_gre     4733  1 nf_conntrack_pptp
nf_conntrack_netlink    19824  0
nf_conntrack_netbios_ns      944  2
nf_conntrack_broadcast     1101  2 nf_conntrack_netbios_ns,nf_conntrack_snmp
nf_conntrack_irc        3784  3 nf_nat_irc
nf_conntrack_h323      42823  1 nf_nat_h323
nf_conntrack_ftp        8264  3 nf_nat_ftp
xt_TPROXY               6192  0
nf_defrag_ipv6          8409  2 xt_TPROXY,nf_conntrack_ipv6
nf_tproxy_core           967  1 xt_TPROXY
xt_time                 1712  0
xt_TCPMSS               2640  0
xt_tcpmss               1296  0
xt_sctp                 2560  0
xt_policy               1968  0
xt_pkttype               912  0
xt_physdev              1408  0
xt_owner                1008  0
xt_NFQUEUE              1664  0
xt_NFLOG                 928  0
nfnetlink_log           6370  1 xt_NFLOG
xt_multiport            1968  4
xt_mark                 1024  1
xt_mac                   912  0
xt_limit                1432  0
xt_length               1040  0
xt_iprange              2176  0
xt_helper               1104  0
xt_hashlimit            5928  0
xt_DSCP                 1840  0
xt_dscp                 1408  0
xt_dccp                 1792  0
xt_conntrack            2496  11
xt_connmark             1392  0
xt_CLASSIFY              944  0
xt_AUDIT                2304  0
xt_tcpudp               2704  53
xt_state                1008  0
iptable_raw             1056  1
iptable_mangle          1232  1
nfnetlink               2663  2 nfnetlink_log,nf_conntrack_netlink
iptable_filter          1136  1
ipv6                  242994  34 bridge,nf_defrag_ipv6,xt_TPROXY,nf_conntrack_ipv6
iptable_nat             2736  0
nf_conntrack_ipv4      10842  24
nf_defrag_ipv4          1166  2 xt_TPROXY,nf_conntrack_ipv4
nf_nat_ipv4             2654  1 iptable_nat
nf_nat                 12352  12 nf_nat_ftp,nf_nat_irc,nf_nat_sip,nf_nat_amanda,ipt_MASQUERADE,nf_nat_proto_gre,nf_nat_h323,nf_nat_ipv4,nf_nat_pptp,nf_nat_tftp,xt_nat,iptable_nat
nf_conntrack           58640  36 nf_nat_ftp,nf_nat_irc,nf_nat_sip,nf_nat_amanda,xt_CT,nf_nat_snmp_basic,nf_conntrack_netbios_ns,nf_conntrack_proto_gre,xt_helper,ipt_MASQUERADE,nf_conntrack_proto_udplite,nf_nat,xt_state,xt_connlimit,nf_nat_h323,nf_nat_ipv4,nf_nat_pptp,nf_nat_tftp,xt_conntrack,nf_conntrack_amanda,ipt_CLUSTERIP,nf_conntrack_proto_sctp,nf_conntrack_netlink,nf_conntrack_broadcast,xt_connmark,nf_conntrack_ftp,nf_conntrack_irc,nf_conntrack_sip,iptable_nat,nf_conntrack_h323,nf_conntrack_ipv4,nf_conntrack_ipv6,nf_conntrack_pptp,nf_conntrack_sane,nf_conntrack_snmp,nf_conntrack_tftp
ip_tables              13957  4 iptable_filter,iptable_mangle,iptable_nat,iptable_raw
x_tables               14010  53 xt_physdev,xt_pkttype,ip6table_filter,xt_statistic,xt_DSCP,xt_dccp,xt_dscp,xt_iprange,xt_mark,xt_sctp,xt_time,xt_CT,xt_hl,xt_helper,xt_length,xt_comment,ipt_ULOG,xt_policy,xt_CHECKSUM,xt_recent,ip_tables,xt_tcpmss,xt_tcpudp,ipt_MASQUERADE,ipt_ah,xt_AUDIT,xt_NFQUEUE,xt_NFLOG,xt_limit,xt_owner,xt_realm,xt_state,ipt_rpfilter,xt_connlimit,xt_conntrack,xt_LOG,xt_mac,xt_nat,ipt_CLUSTERIP,xt_hashlimit,xt_multiport,iptable_filter,xt_CLASSIFY,xt_TCPMSS,ip6t_rt,xt_TPROXY,xt_connmark,ipt_REJECT,iptable_mangle,ipt_ECN,ip6_tables,xt_addrtype,iptable_raw
zfs                   806536  0
zunicode              316296  1 zfs
zavl                    4037  1 zfs
zcommon                28603  1 zfs
nvidia              11233275  24
snd_usb_audio          91795  2
snd_usbmidi_lib        13138  1 snd_usb_audio
snd_hwdep               4638  1 snd_usb_audio
psmouse                59006  0
pcspkr                  1552  0
serio_raw               3992  0
pwc                    61438  0
videobuf2_vmalloc       2361  1 pwc
videobuf2_memops        1840  1 videobuf2_vmalloc
videobuf2_core         20513  1 pwc
videodev               81735  2 pwc,videobuf2_core
media                   8226  1 videodev
k8temp                  2896  0
shpchp                 20271  0
amd64_edac_mod         14327  0
edac_core              28033  2 amd64_edac_mod
snd_via82xx            16088  3
snd_mpu401_uart         4003  1 snd_via82xx
gameport                5716  1 snd_via82xx
snd_rawmidi            14347  2 snd_usbmidi_lib,snd_mpu401_uart
snd_seq_device          3997  1 snd_rawmidi
snd_via82xx_modem       6464  0
snd_ac97_codec         89973  2 snd_via82xx,snd_via82xx_modem
snd_pcm                58959  4 snd_via82xx,snd_usb_audio,snd_ac97_codec,snd_via82xx_modem
snd_page_alloc          6182  3 snd_via82xx,snd_pcm,snd_via82xx_modem
snd_timer              14166  1 snd_pcm
ac97_bus                 944  1 snd_ac97_codec
snd                    46582  22 snd_via82xx,snd_usb_audio,snd_ac97_codec,snd_hwdep,snd_timer,snd_pcm,snd_rawmidi,snd_usbmidi_lib,snd_mpu401_uart,snd_via82xx_modem,snd_seq_device
i2c_viapro              5400  0
pci_hotplug             8609  1 shpchp
skge                   31632  0
firewire_ohci          24456  0
virtio_ring             4674  0
xts                     2807  0
gf128mul                5354  1 xts
aes_x86_64              7403  0
sha512_generic          4817  0
sha256_generic          9613  0
sha1_generic            1846  0
iscsi_tcp               7724  0
tg3                   123383  0
ptp                     6924  1 tg3
pps_core                7800  1 ptp
e1000                 109615  0
fuse                   56997  3
znvpair                42112  2 zfs,zcommon
spl                   107813  5 zfs,zavl,zunicode,zcommon,znvpair
xfs                   426139  0
nfs                   101771  0
lockd                  52677  1 nfs
sunrpc                146358  2 nfs,lockd
jfs                   142737  0
reiserfs              205877  0
ext4                  271612  5
jbd2                   47535  1 ext4
ext3                  108570  0
jbd                    37602  1 ext3
ext2                   53898  0
mbcache                 4610  3 ext2,ext3,ext4
sl811_hcd               8983  0
hid_generic             1057  0
xhci_hcd               75101  0
ohci_hcd               24370  0
sx8                    11013  0
imm                     8772  0
parport                26827  1 imm
ehci_pci                3728  0
ehci_hcd               39837  1 ehci_pci
uhci_hcd               20457  0
firewire_core          43805  1 firewire_ohci
Post by Fitzcarraldo » Mon Jul 08, 2013 22:04
The PCVC675K may be supported by the newer uvcvideo driver, so try unloading the pwc driver and loading the uvcvideo driver:
rmmod pwc
modprobe uvcvideo
Alex7793
Post by Alex7793 » Tue Jul 09, 2013 13:04
I did it and it doesn't work.
This is output:
With Camorama
Could not connect with video device (/dev/video0).
Please check connection... Connection I think is ok because cam had led on
ioctl: VIDIOC_G_STD(std=0x7f15061c3db0 [PAL_I,PAL_D,PAL_K,PAL_M,PAL_Nc,PAL_60,NTSC_M,NTSC_M_JP,SECAM_G,SECAM_H,SECAM_K,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)]): ioctl non appropriata per il device
ioctl: VIDIOC_DQBUF(index=0;type=VIDEO_CAPTURE;bytesused=0;flags=0x0 [];field=ANY;;timecode.type=0;timecode.flags=0;timecode.frames=0;timecode.seconds=0;timecode.minutes=0;timecode.hours=0;timecode.userbits="";sequence=0;memory=unknown): Nessun device corrisponde
ioctl VIDIOC_STREAMOFF: Nessun device corrisponde
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x34524742 [BGR4];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=152064;fmt.pix.colorspace=SRGB;fmt.pix.priv=0): Nessun device corrisponde
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x33524742 [BGR3];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=152064;fmt.pix.colorspace=SRGB;fmt.pix.priv=0): Nessun device corrisponde
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x33424752 [RGB3];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=152064;fmt.pix.colorspace=SRGB;fmt.pix.priv=0): Nessun device corrisponde
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x00000000 [....];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=152064;fmt.pix.colorspace=SRGB;fmt.pix.priv=0): Nessun device corrisponde
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x59455247 [GREY];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=152064;fmt.pix.colorspace=SRGB;fmt.pix.priv=0): Nessun device corrisponde
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x56595559 [YUYV];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=152064;fmt.pix.colorspace=SRGB;fmt.pix.priv=0): Nessun device corrisponde
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x50323234 [422P];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=152064;fmt.pix.colorspace=SRGB;fmt.pix.priv=0): Nessun device corrisponde
ioctl: VIDIOC_S_FMT(type=VIDEO_CAPTURE;fmt.pix.width=384;fmt.pix.height=288;fmt.pix.pixelformat=0x32315559 [YU12];fmt.pix.field=ANY;fmt.pix.bytesperline=0;fmt.pix.sizeimage=152064;fmt.pix.colorspace=SRGB;fmt.pix.priv=0): Nessun device corrisponde
Playing tv://.
v4l2: unable to open '/dev/video0': No such file or directory
v4l2: ioctl set mute failed: Bad file descriptor
v4l2: 0 frames successfully processed, 0 frames dropped.
Exiting... (End of file)
Post by Fitzcarraldo » Tue Jul 09, 2013 20:54
What do you have in /dev?
ls /dev/*
OK, let's try again with the pwc module. Create the file /etc/modprobe.d/pwc with the following contents:
alias video0 pwc
options pwc compression=0
Then reboot. If that doesn't work, try putting the above two lines in /etc/modprobe.d/aliases.conf instead and reboot.
Alex7793
Post by Alex7793 » Tue Jul 09, 2013 23:55
Don't work :(
This is output of ls /dev/*
/dev/agpgart             /dev/ram13     /dev/tty15  /dev/tty61
/dev/alarm               /dev/ram14     /dev/tty16  /dev/tty62
/dev/ashmem              /dev/ram15     /dev/tty17  /dev/tty63
/dev/autofs              /dev/ram2      /dev/tty18  /dev/tty7
/dev/binder              /dev/ram3      /dev/tty19  /dev/tty8
/dev/btrfs-control       /dev/ram4      /dev/tty2   /dev/tty9
/dev/cdrom               /dev/ram5      /dev/tty20  /dev/ttyS0
/dev/console             /dev/ram6      /dev/tty21  /dev/ttyS1
/dev/core                /dev/ram7      /dev/tty22  /dev/ttyS2
/dev/cpu_dma_latency     /dev/ram8      /dev/tty23  /dev/ttyS3
/dev/dac960_gam          /dev/ram9      /dev/tty24  /dev/urandom
/dev/fb0                 /dev/random    /dev/tty25  /dev/usbmon0
/dev/fbcondecor          /dev/rfkill    /dev/tty26  /dev/usbmon1
/dev/full                /dev/root      /dev/tty27  /dev/usbmon2
/dev/fuse                /dev/rtc       /dev/tty28  /dev/usbmon3
/dev/fw0                 /dev/rtc0      /dev/tty29  /dev/usbmon4
/dev/hidraw0             /dev/sda       /dev/tty3   /dev/usbmon5
/dev/hpet                /dev/sda1      /dev/tty30  /dev/vcs
/dev/i2octl              /dev/sdb       /dev/tty31  /dev/vcs1
/dev/initctl             /dev/sdb1      /dev/tty32  /dev/vcs10
/dev/kmem                /dev/sdb2      /dev/tty33  /dev/vcs11
/dev/kmsg                /dev/sdb3      /dev/tty34  /dev/vcs12
/dev/log                 /dev/sdb4      /dev/tty35  /dev/vcs16
/dev/loop0               /dev/sdb5      /dev/tty36  /dev/vcs2
/dev/loop1               /dev/sdb6      /dev/tty37  /dev/vcs3
/dev/loop2               /dev/sdc       /dev/tty38  /dev/vcs4
/dev/loop3               /dev/sdd       /dev/tty39  /dev/vcs5
/dev/loop4               /dev/sde       /dev/tty4   /dev/vcs6
/dev/loop5               /dev/sdf       /dev/tty40  /dev/vcs7
/dev/loop6               /dev/sg0       /dev/tty41  /dev/vcs8
/dev/loop7               /dev/sg1       /dev/tty42  /dev/vcs9
/dev/loop-control        /dev/sg2       /dev/tty43  /dev/vcsa
/dev/lpfcmgmt            /dev/sg3       /dev/tty44  /dev/vcsa1
/dev/mcelog              /dev/sg4       /dev/tty45  /dev/vcsa10
/dev/megadev0            /dev/sg5       /dev/tty46  /dev/vcsa11
/dev/mem                 /dev/sg6       /dev/tty47  /dev/vcsa12
/dev/mpt2ctl             /dev/sg7       /dev/tty48  /dev/vcsa16
/dev/mptctl              /dev/snapshot  /dev/tty49  /dev/vcsa2
/dev/network_latency     /dev/sr0       /dev/tty5   /dev/vcsa3
/dev/network_throughput  /dev/sr1       /dev/tty50  /dev/vcsa4
/dev/null                /dev/stderr    /dev/tty51  /dev/vcsa5
/dev/nvidia0             /dev/stdin     /dev/tty52  /dev/vcsa6
/dev/nvidiactl           /dev/stdout    /dev/tty53  /dev/vcsa7
/dev/port                /dev/tty       /dev/tty54  /dev/vcsa8
/dev/psaux               /dev/tty0      /dev/tty55  /dev/vcsa9
/dev/ptmx                /dev/tty1      /dev/tty56  /dev/vga_arbiter
/dev/ram0                /dev/tty10     /dev/tty57  /dev/zero
/dev/ram1                /dev/tty11     /dev/tty58  /dev/zfs
/dev/ram10               /dev/tty12     /dev/tty59
/dev/ram11               /dev/tty13     /dev/tty6
/dev/ram12               /dev/tty14     /dev/tty60
/dev/block:
1:0   11:0  1:12  1:15  1:4  1:7  7:0  7:3  7:6  8:1   8:18  8:21  8:48
1:1   1:11  1:13  1:2   1:5  1:8  7:1  7:4  7:7  8:16  8:19  8:22  8:64
1:10  11:1  1:14  1:3   1:6  1:9  7:2  7:5  8:0  8:17  8:20  8:32  8:80
/dev/bsg:
0:0:0:0  1:0:0:0  5:0:0:0  5:0:1:0  7:0:0:0  7:0:0:1  7:0:0:2  7:0:0:3
/dev/bus:
usb
/dev/char:
10:1    10:55   116:8    189:256  243:0  4:0   4:25  4:41  4:58  7:1    7:16
10:166  10:56   1:2      189:3    244:0  4:1   4:26  4:42  4:59  7:10   7:2
10:175  10:57   1:3      189:384  245:0  4:10  4:27  4:43  4:6   7:11   7:3
10:220  10:58   13:32    189:385  245:1  4:11  4:28  4:44  4:60  7:12   7:4
10:221  10:59   13:63    189:386  245:2  4:12  4:29  4:45  4:61  7:128  7:5
10:227  10:60   13:64    189:512  245:3  4:13  4:3   4:46  4:62  7:129  7:6
10:228  10:61   13:65    189:514  245:4  4:14  4:30  4:47  4:63  7:130  7:7
10:229  10:62   13:66    1:9      245:5  4:15  4:31  4:48  4:64  7:131  7:8
10:231  10:63   13:67    202:0    252:0  4:16  4:32  4:49  4:65  7:132  7:9
10:234  1:1     13:68    203:0    252:1  4:17  4:33  4:5   4:66  7:133
10:235  1:11    13:69    21:0     252:2  4:18  4:34  4:50  4:67  7:134
10:236  116:2   1:4      21:1     252:3  4:19  4:35  4:51  4:7   7:135
10:237  116:3   1:5      21:2     252:4  4:2   4:36  4:52  4:8   7:136
10:252  116:33  1:7      21:3     252:5  4:20  4:37  4:53  4:9   7:137
10:51   116:4   1:8      21:4     252:6  4:21  4:38  4:54  5:0   7:138
10:52   116:5   180:0    21:5     252:7  4:22  4:39  4:55  5:1   7:139
10:53   116:6   189:0    21:6     254:0  4:23  4:4   4:56  5:2   7:140
10:54   116:7   189:128  21:7     29:0   4:24  4:40  4:57  7:0   7:144
/dev/cpu:
0
/dev/disk:
by-id  by-label  by-path  by-uuid
/dev/fd:
0  1  2  3
/dev/input:
by-path  event0  event1  event2  event3  event4  event5  mice  mouse0
/dev/mapper:
control
/dev/mqueue:
/dev/pktcdvd:
control
/dev/pts:
0  ptmx
/dev/shm:
pulse-shm-2256062737  pulse-shm-3640225033  pulse-shm-521262225
pulse-shm-3303223310  pulse-shm-3930294267  pulse-shm-541521142
/dev/snd:
by-id    controlC0  pcmC0D0c  pcmC0D1c  pcmC1D0c
by-path  controlC1  pcmC0D0p  pcmC0D1p  timer
/dev/usb:
hiddev0
Post by Fitzcarraldo » Wed Jul 10, 2013 14:20
Well, you don't have a device /dev/video0, which is why the xawtv and mplayer commands you are using don't work. You're telling xawtv and mplayer to use a non-existent device (/dev/video0). The question is, though, what device, if any, you do have. Try the following, to find out more.
1. Check that the pwc module is running (use the lsmod command to see).
2. Unplug the USB Webcam.
3. Issue the dmesg command as root user and note the last line of the output.
4. Plug in the USB Webcam.
5. Issue the dmesg command as root user.
6. Paste here the additional lines that appeared in the Konsole/Terminal window from the second dmesg command, i.e. the new lines that appeared at the end of the output; the difference between the output in Steps 3 and 5.
Alex7793
Post by Alex7793 » Wed Jul 10, 2013 16:16
Pwc module is not running
Output of two steps is:
[  243.514056] usb 2-1: USB disconnect, device number 2
[  331.063037] usb 2-1: new full-speed USB device number 3 using uhci_hcd
[  331.585936] usb 2-1: New USB device found, idVendor=0471, idProduct=0307
[  331.585944] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[  331.585948] usb 2-1: SerialNumber: 0213021180103A60
[  332.681887] pwc: Unknown parameter `compression'
Post by Fitzcarraldo » Wed Jul 10, 2013 17:19
Delete the following lines from /etc/modprobe.d/pwc and /etc/modprobe.d/aliases.conf:
alias video0 pwc
then reboot and repeat the procedure I gave in my last post, and post the additional dmesg lines again. Then also post the output of the following command:
lsmod | grep -E '(videodev|pwc)'
