Installing software from the command line
rmcellig
Post by rmcellig » Sat May 11, 2013 2:02
When I was using Debian and Ubuntu based distros, I would use sudo apt-get install to install software packages. How would I do this in Sabayon?
Re: Installing software from the command line
Post by Fitzcarraldo » Sat May 11, 2013 2:35
The command line interface to the Entropy package manager is Equo. See the comprehensive article on Entropy and Equo in the SL Wiki (link 'Wiki' is at top of this page).
$ su
Password: <-- Enter root user's password.
# equo install firefox libreoffice
See also:
$ equo --help
Also see the sticky thread in the 'Entropy|Equo|Rigo Package Managers' shed (forum).
Post by wolfden » Sat May 11, 2013 10:35
Ryuno-Ki
Post by Ryuno-Ki » Sat May 11, 2013 14:30
also please see http://wiki.sabayon.org/index.php?title ... _Functions (not complete, but most commands are there)
rmcellig
Post by rmcellig » Sat May 11, 2013 16:20
Wow! I like Equo. Reminds me a bit of the arch way of installing software that I use in Manjaro. Equo seems to be a robust package installer. At least from a first impression perspective. :)
Post by Fitzcarraldo » Sat May 11, 2013 16:46
It is very robust, actually. And easy to use. Note also that SL is a rolling-release distribution. All I need to do from time to time to roll forward is:
# equo update
# equo upgrade
# equo conf update # Actually the previous command's output will even tell you whether or not you need to do this.
# # Optional stuff now:
# kernel-switcher switch linux-sabayon-<x>.<y>.<z> # Only needed if there is a new version of the kernel in the repository and you want to upgrade to it.
# deptest # A dependency check and fix if necessary.
# libtest # A quick library check and fix if necessary.
All is explained in the aforementioned SL Wiki articles.
