Questions about respositories [Solved]
fire_dragon
Post by fire_dragon » Fri Mar 15, 2013 15:02
Dear friends,
I am wondering about the respositories. It sounds very easy but somehow it is confusing for me:
If I enable sabayon-weekly and nothing else, I have sabayon-weekly!
I cannot enable sabayon-limbo + sabayon-weekly with a disabled sabayonlinux.org!
If I would enable sabayonlinux.org, do I need to keep sabayonweekly enabled or disable it?
If I would enable sabayon-limbo, I do need to enable sabayonlinux.org, but do I have to enable or disable sabayon-weekly?
If I would enable sabayon-hell (where is not even an example file present in my installation, likely because its not recommended to use this), what other respository do I have to enable and disable and how to enable it in the first place?
Re: Questions about respositories
Post by Stupot » Fri Mar 15, 2013 15:46
Here is what I recall.
Sabayon-weekly should be run on it's own.
Sabayon-limbo is meant to be run with sabayonlinux.org.
sabayonlinux.org can be run on it's own.
colock
Post by colock » Fri Mar 15, 2013 16:09
valid repositories setups:
  • sabayon-weekly
  • sabayonlinux.org
  • sabayonlinux.org + sabayon-limbo
sabayonlinux.org is the "main" repository.
sabayon-weekly is (almost) a snapshot of an older sabayonlinux.org.
sabayon-limbo is an overlay to the main repository.
More info: http://wiki.sabayon.org/index.php?title ... itories.3F
(Edit, removed sabayon-hell, not to be enabled)
fire_dragon
Post by fire_dragon » Sat Mar 16, 2013 0:40
So is this correct?
sabayon-weekly:
enabled - sabayon-weekly
disabled - sabayonlinux.org
disabled - sabayon-limbo
sabayonlinux.org:
disabled - sabayon-weekly
enabled - sabayonlinux.org
sabayon-limbo:
enabled - sabayon-limbo
sabayon-hell:
cannot be enabled by user
Matte88
Location: @/etc/entropy/repositories.conf.d/entropy_sabayon-limbo
Post by Matte88 » Sat Mar 16, 2013 12:11
You're right! ;)
When I became the sun,
I shone life into the man's hearts.
fire_dragon
Post by fire_dragon » Tue Mar 19, 2013 14:32
Thanks.
