Audacity 2.0.3 no longer supports ffmpeg on Gentoo
adsicks
Post by adsicks » Sat Mar 09, 2013 12:34
I tried to open an mp4 in Audacity and got an error telling me that Audacity cannot open Advanced Codex audio files...knowing that I had opened them before, I did some research, and found a bug report...
https://bugs.gentoo.org/show_bug.cgi?id=417869
However, the package entry for Audacity 2.0.3 on Sabayon Linux lists the ffmpeg use flag
https://packages.sabayon.org/show/audac ... ,standard/
Is it possible to just get a build in entropy with a manual library install per this...?
http://manual.audacityteam.org/man/FAQ: ... tallffmpeg
The only work around I could figure was to just mask 2.0.3 for now and downgrade to 2.0.2...
Itsmejerry04
Re: Audacity 2.0.3 no longer supports ffmpeg on Gentoo
Post by Itsmejerry04 » Fri Dec 28, 2018 13:58
How else can I extract foreign audio from avi's (for listening and learning on the ipod). I either need audacity to work with ffmpeg or another program. I don't use any KDE apps though, so those are not an option for me.
Post by Stupot » Fri Dec 28, 2018 18:30
You can just use ffmpeg directly.
