the package [email protected] not incorporated in ISO[Solved]
Post by albfneto » Mon Nov 19, 2012 19:07
I try to make an Sabayon remasterized with XFCE and MATE,together,and with ATI drivers.
I have some expertise with molecule, as i made some ISOs with KDE and GNOME2,together.
i begin with a recent XFCE Daily ISO, and added the MATE packages
Then all is remasterized good, but, in the spec, the commands to add the Package Sets, as @X, @mate etc.. not worked, packages not found, therefore not installed. In my remasterized ISO, many packages are missing, as xdm, mdm, keyboard configurators etc...
In the boot of this remasterized copy, it only works if i "install" the packages again, in the boot, in the live DVD.
for see the spec files and common files, i begin with these that are in the GIT sabayon repository.
The package sets are working? if not, when i may see the complete list of packages present in each package set?
Re: the package [email protected] not works and not incorporated in
Post by wolfden » Sat Nov 24, 2012 15:30
yes we are aware of that and it's fixed in latest entropy
Post by albfneto » Fri Sep 05, 2014 22:11
This issue was solved years ago....
