extract subtitles stream from avi
msdobrescu
Post by msdobrescu » Mon Apr 09, 2012 16:35
I have a bunch of avi's with an additional subtitles stream.
How could I extract them (they are sub, not DVD or hardcoded).
Thank you.
ShadowCat8
Location: That shadow you thought you saw something moving in...
Re: extract subtitles stream from avi
Post by ShadowCat8 » Wed Apr 25, 2012 21:45
Well,
I know that you can do it with 'ffmpeg'. Ffmpeg supports the following subtitle codecs:
  • ass - Advanced SubStation Alpha subtitle
  • dvbsub - DVB subtitles
  • dvdsub - DVD subtitles
  • pgssub - HDMV Presentation Graphic Stream subtitles
  • srt - SubRip subtitle
  • xsub - DivX subtitles (XSUB)
And, if you're not sure which one you need, you can usually get an idea from running the following command on the avi file:
 ~ $ ffplay -an -vn -stats <path to AVI file>
HTH. Let us know.
Regards,
ShadowCat8
"I do not feel obliged to believe that the same God who has endowed
us with sense, reason, and intellect has intended us to forgo their use."
-- Galileo Galilei
msdobrescu
Post by msdobrescu » Sat May 12, 2012 8:35
Sorry to reply so late.
I don't know what's wrong, but it didn't work.
I have used mkvmerge to remux it and extract it from the mkv.
