KDE 4.8.0 plasma-desktop-shell crashes w/ USB disks [Solved]
grimly64
Re: KDE 4.8.0 plasma-desktop-shell crashes w/ USB disks atta
Post by grimly64 » Tue Mar 06, 2012 9:19
Guessing that this has not been resolved yet. Have not seen any updates lately.
Experiencing the same problem since KDE 4.8. Insert (not just usb stick) external HDD, plasma screen goes black. Hit Ctrl+Alt+Del then logoff, and sometimes can get back to a screen, if that does not work, then do a full re-boot.
(fyi using dual monitors)
Question, with a "rolling release" is there something we are supposed to do to uninstall or clean up, after a new release? May have missed it, but did not see it in the Wiki.
Also the icon on desktop not being able to open related folder is still now working either. Believe that is a Dolphin issue.
mikael71140
Post by mikael71140 » Tue Mar 06, 2012 11:14
First of all, I'm french and my english is bad... sorry
I experienced the same issue, but not with usb stick, only when attaching a external USB HDD.
The only way I found to resolve temporarily this problem is to remove the "new device notifier" plasmoid from the bottom taskbar (near the clock).
At least I can now browse my HDD with any file manager, like Dolphin, without crash of plasma-desktop or plasma-netbook when I turn on the HDD (the desktop does not turn to black anymore).
I didn't have this problem with 4.7 release, but only since the upgrade to 4.8.
I hope it can help you !
Post by joost » Tue Mar 06, 2012 11:59
Since nearly nobody is giving any technical details about their systems this is still going nowhere.
However I did notice that somebody opened up a bug for latest NVIDIA drivers and GNOME3 Shell problems.
Could it be that people who have their plasma desktop crashing and getting a blank screen that it is because of they are using latest nvidia driver in combination with this bug in KDE 4.8.0?
So far I was able to at some point make Kactivities crash when brutally insert/eject an USB key. However in my case (I use ATI/AMD FGLRX) the desktop was able to recover itself.
Post by Fitzcarraldo » Tue Mar 06, 2012 22:08
I don't suffer from any Plasma Desktop Shell crashes in KDE 4.8.0, and I don't have time to read through all this thread at the moment. But I wonder if the following blog post by KDE developer Lamarque Souza has any relevance to what some of you are experiencing: http://lamarque-lvs.blogspot.com/2012/0 ... n-48x.html?
Lamarque wrote:In bug #287002 it is stated that apper is one of programs that freezes kded. Just as a notice I have never used apper. Until now everybody that has disabled apper's kded module reported that it fixed the freezing problem. You can try it yourself, just go to systemsettings -> Startup and Shutdown -> Service Manager, locate the "apper" service, stop it and uncheck the checkbox in "Use" column for that service, then click on the "Ok" button.
All I can state is that I don't have Apper running.
cmost
Post by cmost » Tue Mar 06, 2012 23:55
@ Fitzcarraldo
Thanks for the information! Unfortunately, I don't have, (nor have I ever had) the apper service running on my system. Another interesting tidbit I've found with this bug is that plasma-desktop-shell will crash at the conclusion of a CD or DVD burn. The bug has something to do with KDE's new re-written removable devices do-dad. Personally, I'm of the school of thought that if it ain't broke...don't fix it! The old one worked just fine as evidenced by KDE 4.7.4's stability.
AMD Phenom II 64 X6 1090T Black Edition
8192 MB DDR2 RAM
nVidia GeForce GTX 660 w 2048 MB DDR5
Sabayon 2014.x 64 Bit KDE
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -- Abraham Lincoln
grimly64
Post by grimly64 » Wed Mar 07, 2012 2:28
While rebooting with a usb hdd
The Plasma Desktop Shell - The KDE Crash Handler comes up with
Details:
Executable: kdeinit4 PID: 12022 Signal: Segmentation fault (11)
Installed gdb-7.4 and reloaded the KDE Crash Handler and it gave this.
Application: Plasma Desktop Shell (kdeinit4), signal: Segmentation fault
[KCrash Handler]
#6 0x0000003efb20ca8d in QFontPrivate::~QFontPrivate() () from /usr/lib64/qt4/libQtGui.so.4
#7 0x0000003efb20ceb3 in QFont::~QFont() () from /usr/lib64/qt4/libQtGui.so.4
#8 0x00007f51ada92e2b in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#9 0x00007f51ada930c9 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#10 0x0000003efb5c018a in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#11 0x00007f51ada6ac70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#12 0x00007f51ada2c025 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#13 0x0000003efb5c00a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#14 0x00007f51ada6ac70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#15 0x00007f51ada2be25 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#16 0x0000003efb5c00a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#17 0x00007f51ada6ac70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#18 0x00007f51ada6ace9 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#19 0x0000003efb5c00a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#20 0x00007f51ada6ac70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#21 0x00007f51ada2baa5 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#22 0x0000003efb5c00a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#23 0x00007f51ada6ac70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#24 0x00007f51ada2bba5 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#25 0x0000003efb5c00a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#26 0x00007f51ada6ac70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#27 0x00007f51ada2be25 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#28 0x0000003ef899ac08 in QObject::event(QEvent*) () from /usr/lib64/qt4/libQtCore.so.4
#29 0x0000003efafd9df4 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#30 0x0000003efafdec73 in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#31 0x0000003f0145fcb6 in KApplication::notify(QObject*, QEvent*) () from /usr/lib64/libkdeui.so.5
#32 0x0000003ef8981bfc in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/qt4/libQtCore.so.4
#33 0x0000003ef898549a in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () from /usr/lib64/qt4/libQtCore.so.4
#34 0x0000003ef89b08c3 in ?? () from /usr/lib64/qt4/libQtCore.so.4
#35 0x0000003ef2c4713d in g_main_context_dispatch () from /usr/lib64/libglib-2.0.so.0
#36 0x0000003ef2c47938 in ?? () from /usr/lib64/libglib-2.0.so.0
#37 0x0000003ef2c47b0d in g_main_context_iteration () from /usr/lib64/libglib-2.0.so.0
#38 0x0000003ef89b0cef in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt4/libQtCore.so.4
#39 0x0000003efb07d0ee in ?? () from /usr/lib64/qt4/libQtGui.so.4
#40 0x0000003ef89809e2 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt4/libQtCore.so.4
#41 0x0000003ef8980c37 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt4/libQtCore.so.4
#42 0x0000003ef8985795 in QCoreApplication::exec() () from /usr/lib64/qt4/libQtCore.so.4
#43 0x00007f51a63c2e43 in kdemain () from /usr/lib64/libkdeinit4_plasma-desktop.so
#44 0x00000000004073a4 in _start ()
Dmesg shows:
Mar 6 17:22:34 Devos dbus[6193]: [system] Activating service name='org.kde.powerdevil.backlighthelper' (using servicehelper)
Mar 6 17:22:34 Devos org.kde.powerdevil.backlighthelper: QDBusConnection: system D-Bus connection created before QCoreApplication. Application may misbehave.
Mar 6 17:22:34 Devos dbus[6193]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Mar 6 17:22:43 Devos kernel: [ 561.496738] plasma-desktop[12162]: segfault at 0 ip 0000003ef8997bda sp 00007fffda67aa20 error 6 in libQtCore.so.4.8.0[3ef8800000+2cc000]
Hardware Info:
Hostname :
Host Address : 192.168.1.101
Main Memory : 8176948
Number of CPUs : 4
CPU Type : x86_64 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz 3000.000 MHz
OS Release : Sabayon Linux amd64 8
OS Edition : Sabayon Linux 5.5 amd64 KDE
Kernel Name : Linux GNU/Linux
Kernel Version : 3.2.0-sabayon
Uptime : 17:30:23 up 17 min, 2 users, load average: 0.21, 0.34, 0.33
Entropy Version
entropy: 1.0_rc87
equo: 1.0_rc87
Portage Version
Portage 2.2.0_alpha84 (default/linux/amd64/10.0/desktop, gcc-4.6.2, glibc-2.13-r4, 3.2.0-sabayon x86_64)
Kernel List
[1] linux-2.6.37-sabayon
[2] linux-3.0.0-sabayon
[3] linux-3.1.0-sabayon
[4] linux-3.2.0-sabayon *
Your Kernel Should Be Set To:
3.2.0-sabayon
Use eselect kernel set #
OpenGL List
[1] ati
[2] nvidia *
[3] xorg-x11
The above should be set to your video card, see lspci
Use eselect opengl set #
Java VM List
Available Java Virtual Machines:
[1] emul-linux-x86-java-1.6
[2] icedtea-6
[3] icedtea6-bin
[4] sun-jdk-1.6
[5] sun-jre-bin-1.6 system-vm
Use java-config --set-system-vm #
Java-nsplugin List
Available 32-bit Java browser plugins
Available 64-bit Java browser plugins
[1] sun-jdk-1.6
[2] sun-jre-bin-1.6 current
Use eselect java-nsplugin set #
Devices - lspci
Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
Intel Corporation 4 Series Chipset PCI Express Root Port (rev 03)
Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 4
Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5
Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6
Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
Intel Corporation 82801 PCI Bridge (rev 90)
Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller
Intel Corporation 82801JI (ICH10 Family) SMBus Controller
nVidia Corporation GF104 [GeForce GTX 460] (rev a1)
nVidia Corporation GF104 High Definition Audio Controller (rev a1)
JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 02)
Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
Devices - lsmod
Module Size Used by
it87 21096 0
hwmon_vid 2004 1 it87
coretemp 4664 0
ipv6 237344 18
snd_seq_dummy 1080 0
snd_seq_oss 21979 0
snd_seq_midi_event 4111 1 snd_seq_oss
snd_seq 37787 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event
snd_seq_device 4013 3 snd_seq_dummy,snd_seq_oss,snd_seq
snd_pcm_oss 28609 0
snd_mixer_oss 10881 1 snd_pcm_oss
nvidia 12220129 42
snd_hda_codec_hdmi 19342 4
snd_hda_codec_realtek 173840 1
snd_hda_intel 19000 1
snd_hda_codec 60896 3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel
i2c_i801 6824 0
ses 4432 0
enclosure 4584 1 ses
i2c_core 14248 2 nvidia,i2c_i801
snd_hwdep 4382 1 snd_hda_codec
r8169 34408 0
intel_agp 9320 0
pcspkr 1472 0
intel_gtt 10551 1 intel_agp
snd_pcm 55658 4 snd_pcm_oss,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_timer 13958 2 snd_seq,snd_pcm
snd 43877 14 snd_seq_oss,snd_seq,snd_seq_device,snd_pcm_oss,snd_mixer_oss,snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_timer
iTCO_wdt 10504 0
iTCO_vendor_support 1617 1 iTCO_wdt
snd_page_alloc 5845 2 snd_hda_intel,snd_pcm
xts 2213 0
gf128mul 5338 1 xts
sha512_generic 6657 0
sha256_generic 9501 0
sha1_generic 1787 0
aes_x86_64 7340 0
iscsi_tcp 7724 0
tg3 115327 0
e1000 83663 0
fuse 54994 3
xfs 417549 0
nfs 246010 0
nfs_acl 1983 1 nfs
auth_rpcgss 35290 1 nfs
lockd 61372 1 nfs
sunrpc 163888 4 nfs,nfs_acl,auth_rpcgss,lockd
jfs 139607 0
reiserfs 203193 0
ext4 228944 3
jbd2 43238 1 ext4
ext3 106307 0
jbd 36315 1 ext3
ext2 53365 0
mbcache 4513 3 ext4,ext3,ext2
scsi_wait_scan 695 0
sl811_hcd 8915 0
ohci_hcd 17358 0
uhci_hcd 18658 0
ehci_hcd 33418 0
sx8 10885 0
imm 8645 0
parport 26823 1 imm
pata_pcmcia 9621 0
pcmcia 29224 1 pata_pcmcia
Devices - lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 1058:1110 Western Digital Technologies, Inc.
Bus 001 Device 003: ID 1058:1102 Western Digital Technologies, Inc.
Bus 001 Device 004: ID 1058:1110 Western Digital Technologies, Inc.
Memory
total used free shared buffers cached
Mem: 7985 2358 5627 0 149 850
-/+ buffers/cache: 1358 6626
Swap: 7007 0 7007
Total: 14993 2358 12635
Disk Space
Filesystem Type Size Used Avail Use% Mounted on
rootfs rootfs 54G 19G 33G 36% /
udev devtmpfs 11M 0 11M 0% /dev
/dev/mapper/vg_devos-lv_root ext4 54G 19G 33G 36% /
tmpfs tmpfs 4.2G 680k 4.2G 1% /run
rc-svcdir tmpfs 1.1M 152k 898k 15% /lib64/rc/init.d
cgroup_root tmpfs 11M 0 11M 0% /sys/fs/cgroup
tmpfs tmpfs 4.2G 369k 4.2G 1% /dev/shm
/dev/sda5 ext4 521M 112M 383M 23% /boot
/dev/mapper/vg_devos-lv_home ext4 455G 426G 6.6G 99% /home
/dev/shm tmpfs 4.2G 33k 4.2G 1% /tmp
/dev/shm tmpfs 4.2G 117M 4.1G 3% /var/tmp
This new thing is set to this.
# eselect qtgraphicssystem list
Available Qt Graphics Systems:
[1] native
[2] opengl (experimental)
[3] raster (default) *
abadonna
Post by abadonna » Wed Mar 07, 2012 23:25
Today update rendered my Sabayon non-operational.... I have experienced all possible problems regarding USB drives with latest KDE 4.8.0, but today's update has made my system unusable.
Before KDE was crashing when I disconnect pendrives, and sometimes when I connect them. Now it is enough to connect USB and bang!
Every single time I put my USB pendrive KDE crashes:
[KCrash Handler]
#6  0x00007fd577c86f80 in QHashData::nextNode(QHashData::Node*) () from /usr/lib64/qt4/libQtCore.so.4
#7  0x00007fd56d60156d in ?? () from /usr/lib64/libplasma.so.3
#8  0x00007fd56d6017a0 in Plasma::FrameSvg::~FrameSvg() () from /usr/lib64/libplasma.so.3
#9  0x00007fd54d9240bb in ?? () from /usr/lib64/kde4/imports/org/kde/plasma/core/libcorebindingsplugin.so
#10 0x00007fd577d7d0b5 in QObjectPrivate::deleteChildren() () from /usr/lib64/qt4/libQtCore.so.4
#11 0x00007fd577d8332c in QObject::~QObject() () from /usr/lib64/qt4/libQtCore.so.4
#12 0x00007fd56adb3e25 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#13 0x00007fd5774c40a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#14 0x00007fd56adf2c70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#15 0x00007fd56adb3e25 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#16 0x00007fd5774c40a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#17 0x00007fd56adf2c70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#18 0x00007fd56adb49b8 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#19 0x00007fd5774c40a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#20 0x00007fd56adf2c70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#21 0x00007fd56adb3ba5 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#22 0x00007fd5774c40a6 in QGraphicsItem::~QGraphicsItem() () from /usr/lib64/qt4/libQtGui.so.4
#23 0x00007fd56adf2c70 in QDeclarativeItem::~QDeclarativeItem() () from /usr/lib64/qt4/libQtDeclarative.so.4
#24 0x00007fd56adb3e25 in ?? () from /usr/lib64/qt4/libQtDeclarative.so.4
#25 0x00007fd577d83c08 in QObject::event(QEvent*) () from /usr/lib64/qt4/libQtCore.so.4
#26 0x00007fd576edddf4 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#27 0x00007fd576ee2c73 in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#28 0x00007fd578b4fcb6 in KApplication::notify(QObject*, QEvent*) () from /usr/lib64/libkdeui.so.5
#29 0x00007fd577d6abfc in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/qt4/libQtCore.so.4
#30 0x00007fd577d6e49a in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () from /usr/lib64/qt4/libQtCore.so.4
#31 0x00007fd577d998c3 in ?? () from /usr/lib64/qt4/libQtCore.so.4
#32 0x00007fd57373d13d in g_main_context_dispatch () from /usr/lib64/libglib-2.0.so.0
#33 0x00007fd57373d938 in ?? () from /usr/lib64/libglib-2.0.so.0
#34 0x00007fd57373db0d in g_main_context_iteration () from /usr/lib64/libglib-2.0.so.0
#35 0x00007fd577d99cef in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt4/libQtCore.so.4
#36 0x00007fd576f810ee in ?? () from /usr/lib64/qt4/libQtGui.so.4
#37 0x00007fd577d699e2 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt4/libQtCore.so.4
#38 0x00007fd577d69c37 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt4/libQtCore.so.4
#39 0x00007fd577d6e795 in QCoreApplication::exec() () from /usr/lib64/qt4/libQtCore.so.4
#40 0x00007fd562cc4e43 in kdemain () from /usr/lib64/libkdeinit4_plasma-desktop.so
#41 0x00000000004073a4 in _start ()
Linux 3.2.0-sabayon #1 SMP Sat Feb 11 08:52:29 UTC 2012 x86_64 Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz GenuineIntel GNU/Linux
lspci:
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5)
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b5)
00:1c.7 PCI bridge: Intel Corporation 82801 PCI Bridge (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation Z68 Express Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
01:00.0 VGA compatible controller: nVidia Corporation G92 [GeForce 9800 GT] (rev a2)
06:00.0 USB controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
08:00.0 PCI bridge: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge (rev 01)
lsmod:
Module                  Size  Used by
cifs                  230899  2
ipt_REJECT              1904  1
ipt_LOG                 6056  1
xt_limit                1432  2
xt_tcpudp               2064  8
xt_addrtype             2176  4
xt_state                 976  6
ip6table_filter         1104  1
ip6_tables             13828  1 ip6table_filter
ipv6                  237344  44
nf_nat_irc              1136  0
nf_conntrack_irc        3080  1 nf_nat_irc
nf_nat_ftp              1328  0
nf_nat                 12313  2 nf_nat_irc,nf_nat_ftp
nf_conntrack_ipv4       8730  8 nf_nat
nf_defrag_ipv4          1150  1 nf_conntrack_ipv4
nf_conntrack_ftp        4984  1 nf_nat_ftp
nf_conntrack           48165  7 xt_state,nf_nat_irc,nf_conntrack_irc,nf_nat_ftp,nf_nat,nf_conntrack_ipv4,nf_conntrack_ftp
iptable_filter          1152  1
ip_tables              12773  1 iptable_filter
x_tables               13341  10 ipt_REJECT,ipt_LOG,xt_limit,xt_tcpudp,xt_addrtype,xt_state,ip6table_filter,ip6_tables,iptable_filter,ip_tables
vboxnetadp              4646  0
vboxnetflt             12893  0
vboxdrv              1757671  2 vboxnetadp,vboxnetflt
nvidia              12220129  43
i2c_i801                6824  0
snd_hda_intel          19000  2
pcspkr                  1472  0
intel_agp               9320  0
serio_raw               3336  0
snd_hda_codec          60896  2 snd_hda_codec_realtek,snd_hda_intel
eeepc_wmi               1992  0
asus_wmi               10988  1 eeepc_wmi
sparse_keymap           2329  1 asus_wmi
r8169                  34408  0
xhci_hcd               61987  0
snd_pcm                55658  2 snd_hda_intel,snd_hda_codec
iTCO_wdt               10504  0
snd_timer              13958  1 snd_pcm
snd                    43877  10 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_timer
mei                    26452  0
mxm_wmi                 1268  0
pci_hotplug             8497  1 asus_wmi
joydev                  8064  0
video                   9950  0
xts                     2213  0
gf128mul                5338  1 xts
sha1_generic            1787  0
aes_x86_64              7340  0
iscsi_tcp               7724  0
tg3                   115327  0
e1000                  83663  0
fuse                   54994  1
xfs                   417549  3
nfs                   246010  1
nfs_acl                 1983  1 nfs
lockd                  61372  1 nfs
sunrpc                163888  16 nfs,nfs_acl,auth_rpcgss,lockd
jfs                   139607  0
reiserfs              203193  0
ext4                  228944  0
jbd2                   43238  1 ext4
ext3                  106307  0
jbd                    36315  1 ext3
ext2                   53365  0
sl811_hcd               8915  0
ohci_hcd               17358  0
uhci_hcd               18658  0
ehci_hcd               33418  0
sx8                    10885  0
imm                     8645  0
parport                26823  1 imm
pata_pcmcia             9621  0
lsusb
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 004: ID 096e:0807 Feitian Technologies, Inc.
Bus 002 Device 005: ID 046a:0023 Cherry GmbH CyMotion Master Linux Keyboard
Bus 002 Device 007: ID 1532:0101 Razer USA, Ltd Copperhead Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Please help. Fix whatever is needed to be fixed....
grimly64
Post by grimly64 » Thu Mar 08, 2012 0:34
Believe this is the same issue
https://bugs.kde.org/show_bug.cgi?id=294534
Post by Fitzcarraldo » Thu Mar 08, 2012 3:35
KDE 4.8.1 was released on 7 March, and I installed it.
KDE SC 4.8.1 Info Page wrote:Currently pre-compiled packages are available for:
Gentoo Linux provides KDE SC 4.8.1 packages in main repository.
More details can be found on Gentoo KDE Guide.
Kubuntu packages are available for 11.10 More details can be found in the announcement on Kubuntu.org.
openSUSE packages are available for openSUSE 12.1 (one-click install), for openSUSE 11.4 (one-click install), and openSUSE Factory (one-click install).
Perhaps that will work better for you than 4.8.0. So far it's working well for me, but then so did 4.8.0. Hopefully it will be in the SL Entropy repositories soon so that you can try it out.
KDE Community Announcements wrote:As the release only contains bugfixes and translation updates, it will be a safe and pleasant update for everyone.
Post by joost » Fri Mar 09, 2012 23:13
Best workaround so far: Disable device notifier
- In the KDE panel right click on the "show hidden icons" arrow (it's next to the clock)
- Uncheck "Device notifier"
- Click on "Apply"
Plug and Unplug USB device.
