After upgrading, Sabayon can not start gdm
Revolver
Re: After upgrading, Sabayon can not start gdm
Post by Revolver » Wed Jan 11, 2012 15:05
Wolfden sorry but you have don't understood my problem.
After updates gnome session (or maybe x server) goes in crash when the sistem start (the screen start to flash from mouse waiting cursor to black screen) BEFORE!!! the kernel update.
I have installed the kernel AFTER the problem to try to solve it!
It's not my fault (ok i'm not so able to use linux) but i know that when a kernel update a user MUST update modules and drivers.
And the problem it's the same even in kernel .39 nor in kernel 3.1-r2 (grub has been updated correctly).
Sorry for my wrong explanation but i'm Italian and sabayonino know it! :D :D :D
Post by sabayonino » Wed Jan 11, 2012 19:57
@Rev
When you upgraded the kernel , did you make sure select it at boot ?
If you did't upgrade any modules about that you have 2 problems :
1 - Kenrel set is not complete
2 - Gdm session doesn't work
Solve These or run older kernel
post here varuìious logs : ~/.xsession-errors ; /var/log/Xorg.0.log and /var/log/rc.log
press ctrl+alt+F1
If you can't copy any logs use/install app-text/pastebin to paste logs to pastebin.com
Example :
 # pastebin /var/log/rc.log
# http://pastebin.com/XXXXX
copy last link (this is the link where pasted the logs)
Post by wolfden » Thu Jan 12, 2012 1:02
Also in the future if you run into an issue, don't go changing kernels. Resolve all issues before doing a kernel change.
Revolver
Post by Revolver » Thu Jan 12, 2012 8:10
Ok,
I've installed sabayon-limbo repo and I've done an update.
This time the screen become black with the white cursor flashing...
When i try to start gdm i got and error of comunication of dbus (i'm not at home so this evening i try to install it) but i have no error about gnome session.
Maybe we found the way outside this black hole... =)
Post by sabayonino » Thu Jan 12, 2012 13:03
Revolver wrote:Ok,
You've done everything except what I asked you :roll:
Where Are the logs ?
logs might help you/us solve the problems
Revolver
Post by Revolver » Fri Jan 13, 2012 21:37
here is the rc.log
http://pastebin.com/FJW7M5ry
xsession-errors
http://pastebin.com/qjMKn0u7
Xorg.0.log
http://pastebin.com/LbE9hp2e
i have to say that i've make an update now throught sabayon-limbo repo and the problem is always the same.
hope you can help me! =)
