Package request, Gentoo-Portage.com is down [Solved]
ddeimeke
Post by ddeimeke » Mon Aug 22, 2011 8:52
how can I request software to be packaged, when Gentoo-Portage.com is down (like it is now)?
I want to request an upgrade of Miro to the recent version (I migrated my last computer to Sabayon and it had a more recent version, migrated data is useless) and I want fatsort (sorting files on FAT filesystems, i.e. mp3-players) to be included in Sabayon.
Cheers
Dirk
Worth a visit: Taskwarrior - What's next?
sihox
Re: Package request, Gentoo-Portage.com is down
Post by sihox » Mon Aug 22, 2011 9:37
Official Gentoo packages site is packages.gentoo.org.
So I think You can use it :)
Have a nice day,
Mariusz
micia
Post by micia » Mon Aug 22, 2011 10:05
ddeimeke wrote: how can I request software to be packaged, when Gentoo-Portage.com is down (like it is now)?
you can follow these guidelines:
http://forum.sabayon.org/viewtopic.php?f=76&t=13891
Post by joost » Mon Aug 22, 2011 10:10
http://gpo.zugaina.org/
^^ I use this.
Latest Miro is already in Entropy, I'll add the other thingy.
micia
Post by micia » Mon Aug 22, 2011 10:23
oh, you meant how do you get a Gentoo ebuild for the package request (I should sleep more), I usually search, using google or any search engine:
<package name> portage
or
<package name> Gentoo
it will usually find out the ebuild in sites like the ones reported above or any ebuild on Gentoo Bugzilla :mrgreen:
When I don't have to make a package request, I use the same link provided by Joost.
ddeimeke
Post by ddeimeke » Mon Aug 22, 2011 10:46
Hi guys,
thanks a lot for your input. Especially Joost, thanks for implementing.
If you need a request to monitor, please tell me, I will raise it.
Thanks
Dirk
ddeimeke
Post by ddeimeke » Mon Aug 22, 2011 10:50
joost wrote:Latest Miro is already in Entropy.
True for "latest in Gentoo" (4.0.1), false for "latest on getmiro.com" (4.0.3).
Cheers
Dirk
Re: Package request, Gentoo-Portage.com is down [Solved]
Post by joost » Mon Aug 22, 2011 10:56
ddeimeke
Post by ddeimeke » Mon Aug 22, 2011 11:00
joost wrote:https://bugs.gentoo.org/show_bug.cgi?id=374999
Upstream bug for it.
Thanks Joost.
Dirk
