Trying to install thunderbird [Solved]
harmon
Post by harmon » Sat Jun 25, 2011 20:44
Hi!
After having installed SL 6 / KDE / 64 bit, I installed Opera und Firefox, but thunderbird:
error downloading from ...
40mirrors without success ( all updates made).
I tried this the hole day.
Any idea?
harmon
harmon @ Linux multiboot
Re: Trying to install thunderbird
Post by sabayonino » Sat Jun 25, 2011 23:19
paste your /etc/entropy/repositories.conf
 cat /etc/entropy/repositories.conf
I think repositories.conf has weekly repo only enabled
I've installed SL-6-amd64-K and repositories.conf had only weekly repos
Sabayon-G-64 is OK
dunsurfin
Post by dunsurfin » Sun Jun 26, 2011 8:19
harmon
Post by harmon » Sun Jun 26, 2011 15:36
Hi!
Thanks for the replies; I first try sabayonino's suggestion.
Yes, it's only weekly; but I don't know what to do.
harmon
Edit:
Problem solved - thanks sabayonino; but I had to choose "...force repo update" .
