Sabayon Linux 5.4 "Experimental Spins": Stable release
This is the place where you can find all the Sabayon Linux Press Releases
lxnay
Land Owner
Post by lxnay » Thu Nov 04, 2010 10:10
Press Release: Sabayon Linux 5.4 "Experimental Spins" releases
Our crew, is happy to announce the immediate availability of E17, XFCE, LXDE, SpinBase/OpenVZ, ServerBase Sabayon 5.4 "Spins" built on top of Sabayon "SpinBase" ISO images.
Under the "Experimental Spins" umbrella, the Sabayon developers are going to experiment new Stable Releases with different package compositions.
Just like the other regular Sabayon releases, these "Experimental Spins" are also daily built by our Build Servers and available in our mirrors inside the "iso/daily" directory.
The E17 Spin contains the famous, stable-releases-are-for-n00bs, often compared to Duke Nukem Forever, Enlightenment 17 Desktop Environment.
XFCE and LXDE contain, surprise surprise, the respective Desktop Environments, while SpinBase/OpenVZ contains, guess what, an OpenVZ template ready to go!
Last but not least, ServerBase is our first public ISO image, based on SpinBase, powered by a server-oriented Linux kernel.
  • Features of Sabayon 5.4 E17 Spin:
  • Bootable Image suitable for a CD or USB thumb drive (<700Mb)
  • Linux 2.6.35 Desktop kernel w/Tuxonice and AUFS support
  • Enlightenment 17 Desktop Environment recently built from SVN
  • NetworkManager 0.8 as default networking tool
  • Out of the box NTFS support via NTFS-3G
  • Mozilla Firefox 3.6.11
  • VirtualBox integration
  • Super fast installation
  • Very minimal setup to fit into a CD, no fancy features and drivers. Designed for low-end computers.
  • Features of Sabayon 5.4 XFCE Spin:
  • XFCE 4.6.2 Desktop Environment
  • Features of Sabayon 5.4 LXDE Spin:
  • LXDE 0.5.0 Desktop Environment
  • Features of Sabayon 5.4 SpinBase/OpenVZ templates:
  • To be used with OpenVZ servers (or Sabayon OpenVZ installations with sys-kernel/linux-openvz kernel)
  • Very small footprint, yet providing a full feature OpenVZ guest Virtual Machine
  • OpenVZ template installation howto available at planet.sabayon.org
  • Features of Sabayon 5.4 ServerBase:
  • Remastered Sabayon SpinBase release using server-optimized Linux 2.6.35 kernel (sys-kernel/linux-server)
  • Very small footprint, just like SpinBase, containing the bare minimum to make your system boot
Download sources
Our Mirrors Page:
Just choose a link from the list and get to the "iso" directory (also containing packages list)
- http://www.sabayon.org/download
Bittorrent:
- http://tracker.sabayon.org
MD5 hashes of released files
14bd11a57471768a37eb47c1d1937528 Sabayon_Linux_ServerBase_5.4_amd64.iso
a7131fba2e36a34242c2cb06c5016c5c Sabayon_Linux_ServerBase_5.4_x86.iso
294c3cf454ab4065d18abfcf87563828 Sabayon_Linux_5.4_amd64_XFCE.iso
041018802970337c02ff0afc8bd9bb35 Sabayon_Linux_5.4_x86_XFCE.iso
ad909b62478d594c14552946f9522c2d Sabayon_Linux_5.4_amd64_E17.iso
0ed906528063e625cad1408c4b24c3c8 Sabayon_Linux_5.4_x86_E17.iso
e5763f0eea54e0314e4217d817a07471 Sabayon_Linux_5.4_amd64_LXDE.iso
c8f9abc2811577c5d6c505a8eeba9c80 Sabayon_Linux_5.4_x86_LXDE.iso
3d15a2e550855d2f279cc72a8646258f Sabayon_Linux_SpinBase_5.4_amd64_openvz.tar.gz
13df05430eed5e7e08193897f41f086e Sabayon_Linux_SpinBase_5.4_x86_openvz.tar.gz
Follow me on Twitter
Add me on Facebook
Add me on Google+
bobcollard
Re: Sabayon Linux 5.4 "Experimental Spins": Stable release
Post by bobcollard » Thu Nov 04, 2010 17:04
I downloaded, burned and installed the XFCE Spin 11/03/10 and the only difference I found between it and the 5.3 version upgraded until today was the addition of Abiword, a waste of time IMO. Still, great work guys, keep it up.
Post by joost » Thu Nov 04, 2010 21:57
@bobcollard
Then we done our job well because it also features a newer installer version and a zillion package updates and you didn't even notice!
seeds
Post by seeds » Thu Nov 04, 2010 22:33
I am using 5.3. can I upgrade to 5.4 using equo update && equo upgrade?
bobcollard
Post by bobcollard » Fri Nov 05, 2010 12:06
joost wrote:@bobcollard
Just to clarify, I think the addition of Abiword is a waste of time, I use OpenOffice, so I had to remove it. Everything else works like a charm out of the box, thanks again.
rpil
Post by rpil » Fri Nov 05, 2010 15:08
Congratulations for the E17 Edition! Keep on working!!
carra
Post by carra » Sat Dec 04, 2010 20:13
On Mac Os X 10.6.5 I cannot burn ISO images 5.4 Spinbase AMD64, CoreCdX and G versions.
I downloaded them from torrent files, so they're already hash checked.
Every time I tried, I had a strange error:
Unable to read "/Volumes/ Sabayon CoreCDX /isolinux/boot.cat"
I found no info on Google so I rely on Your expertise to solve the problem...
Thanks in advance!
carra
Post by carra » Sat Dec 04, 2010 20:48
Ok, my fault: I found solution here http://hints.macworld.com/article.php?s ... 9181010389.
