hping binary "without tcl scripting support" problem
NotExcessive
Post by NotExcessive » Thu Jun 03, 2010 12:47
I've installed hping and gotten this message when I try to run it.
Editing make.conf to set the tcl USE flag, I've downloaded the source and unpacked it, but after running "configure" and make, the compile crashes after a short while.
Can anyone suggest a solution that will enable hping to run?
Re: hping binary "without tcl scripting support" problem
Post by joost » Thu Jun 03, 2010 12:53
Start to learn how portage works?
!!!at your own risk! you will break your system if you dunno how to use portage!!!
emerge --sync && USE="tcl" emerge -av net-analyzer/hping
OR file a bug and request it to be repackaged.
NotExcessive
Post by NotExcessive » Thu Jun 03, 2010 12:56
If I use emerge, the system doesn't recognise the package:
emerge: there are no ebuilds to satisfy "net-analyzer/hping".
but equo does.
Post by Fitzcarraldo » Thu Jun 03, 2010 16:54
^There are certainly ebuilds for hping in Portage:
meshedgedx / # eix hping
* net-analyzer/hping
     Available versions:  2.0.0_rc3-r1 (~)2.0.0_rc3-r2 (~)3_pre20051105-r1 (~)3_pre20051105-r2 {debug tcl}
     Homepage:            http://www.hping.org
     Description:         A ping-like TCP/IP packet assembler/analyzer
Did you do the following first?
emerge --sync
layman -S
