Grazie della risposta, ma vorrei ancora aproffittare della tua pazienza, su 10 file da compilare me ne ha completati 9, l'ultimo, digikam, dopo il configure, quando inizia il mke mi restituisce il seguente problema:
Good - your configure finished. Start make now
cd . && /bin/sh /var/tmp/portage/media-gfx/digikam-0.9.0_beta3/work/digikam-0.9.0-beta3/admin/missing --run automake-1.9 --foreign
po/Makefile.am:1: required directory po/pt does not exist
make: *** [Makefile.in] Error 1
!!! ERROR: media-gfx/digikam-0.9.0_beta3 failed.
Call stack:
ebuild.sh, line 1568: Called dyn_compile
ebuild.sh, line 937: Called src_compile
digikam-0.9.0_beta3.ebuild, line 75: Called kde_src_compile
kde.eclass, line 172: Called kde_src_compile 'all'
kde.eclass, line 342: Called kde_src_compile 'myconf' 'configure' 'make'
kde.eclass, line 338: Called die
!!! died running emake, kde_src_compile:make
!!! If you need support, post the topmost build error, and the call stack if relevant.
