Help login problem
wfp
Help login problem
Post by wfp » Thu Nov 26, 2009 11:18
I just finished installation rebooted, and installed all updates. After rebooting again will not take my password just continues to say login failed. On live cd now.
joeoden
Location: Back in the 'swamp land' Moe, Australia 38°10′20″S 146°16′04″E
Re: Help login problem
Post by joeoden » Thu Nov 26, 2009 11:37
Desktop ASUS M2N-MX SE Plus, AMD 64 X2 Dual Core 5200, 4 Gb RAM, GeForce 9500 1GB
Notebook HP CQ61-311AX, AMD CPU M320, 4 Gb RAM, Radeon HD 4300 512 MB
Wireless AR9285, Audio ATI SBx00 (IDT 92hd75B2x5)
Some mistakes are too much fun to only make once!
wfp
Post by wfp » Sat Nov 28, 2009 7:11
Thanks for the reply. I went for the reinstall, and had the same problem again as before not being able to log in. Went running back to Ubuntu. Sorry for the late reply holidays, and all. It's was really weird I could drop to Console, and log in. But kdm would not accept login.
skypredator
Post by skypredator » Sat Nov 28, 2009 8:34
Hi and sorry my english . Dont go to Ubuntu :D After update and reboot in login screen /down in "password"/ mark "konsole login", type your username and userpassword, after this type "su" and root password and type comand :
eselect opengl list
There are 3 alternative - 1 ati; 2 nvidia; 3 xorg-x11. My video is nvidia and i type comand:
eselect opengl set 2
After comand is applay, reboot PC - is ok now
Hope this help you :D
Post by Fitzcarraldo » Tue Dec 01, 2009 10:40
wfp, have you tried skypredator's solution yet?
