how to install both gnome and kde at the same time
JETHROKANE
Post by JETHROKANE » Fri Nov 06, 2009 14:46
Hi, ya'll im a bit new in linux and was wondering how i install both gnome and kde at the same time and in the same machine.I have installed sabayon 5 kde and would like to add the gnome version of sabayon,so does someone know how i should do it?
Re: how to install both gnome and kde at the same time
Post by albfneto » Sat Nov 07, 2009 0:15
is simple,if you have GNOME and want also KDE, install KDE-META with equo or directly in Sulfur. You may also add many KDE aplicatives....
after, when you login, you may choose KDE or GNOME.
I have, and also many other graphical ambients...
