KDE 4.2 lost buttons in right top of stuck windows [Solved]
jaguar1637
Post by jaguar1637 » Sat Aug 29, 2009 19:07
hi all
I am experiencing a loss buttons in right top of windows. i dunno which sub-directory I should remove or which actions I should perform to get back those fonctionalities
Worse, I cannot move the windows 'firefox, Xterm..) they are stucked.
Can you help me ?
TIA
Re: KDE 4.2 lost buttons in right top of stuck windows
Post by wolfden » Sat Aug 29, 2009 19:24
you lost your window manager?
can you explain more as to what window manager you are using? kwin? compiz? emerald?
jaguar1637
Post by jaguar1637 » Sat Aug 29, 2009 22:14
Hi
I am using compiz
and I cannot anymore move a window
if you had any idea, it could be fun !
TIA
Post by wolfden » Sun Aug 30, 2009 0:01
and you did what that caused this to happen?
which video card?
does eselect opengl list show your video card active?
do you video card drivers match your kernel?
please see this thread to understand what I am talking about
http://forum.sabayonlinux.org/viewtopic ... 53&t=16399
Post by Fitzcarraldo » Sun Aug 30, 2009 3:10
I have not had this problem in a long while but, when it used to happen I found that right-clicking on the Compiz-Fusion icon and either:
a) selecting Reload Window Manager
or
b) selecting Emerald Theme Manager and re-selecting the desired Emerald theme
brought the missing buttons back.
jaguar1637
Post by jaguar1637 » Sun Aug 30, 2009 22:59
Thank you very much for your answer
The Emeral Themer just gave me back those functionalities
Take care and long life w/ Sabayon
john
