No sound on firefox
adrian78666
No sound on firefox
Post by adrian78666 » Mon Jul 20, 2009 6:21
whenever I try to look at a flash video on firefox I get no sound but I can play streams on xbmc just fine I had a similar problem when I was using 2 soundcards on ubuntu ultimate edition and I just disabled the on board sound and everything worked just fine but now the hdmi sound port on my video card it's showing and I don't know how to disable it the output is already selected on my audigy please help I really like this distro sorry I just noticed that the screenshot doesn't show that well it says "HDA ATI HDMI"
Re: No sound on firefox
Post by wolfden » Tue Jul 21, 2009 0:42
so it's only with flash you have no sound?
Post by joost » Tue Jul 21, 2009 12:36
If its flash try this:
equo install libflashsupport
Also read here: http://forum.sabayonlinux.org/viewtopic ... dio#p99955
Thev00d00
Generally Awesome (tm)
Post by Thev00d00 » Tue Jul 21, 2009 14:31
Personally I have to force libflashsupport to use PulseAudio, pulseaudio is very nice however.
add the line
export FLASH_FORCE_PULSEAUDIO=1
to the /usr/bin/firefox script, before it calls firefox itself
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
onlyoneskwalla
Post by onlyoneskwalla » Thu Sep 10, 2009 10:00
got my solution to this from the gentoo forums
here http://forums.gentoo.org/viewtopic-p-59 ... dfa6f4ba30
pulseaudio user ?
then you might need
www-plugins/libflashsupport
and set up pulseaudio correctly:
edit ~/.asoundrc :
pcm.pulse {
     type pulse
 ctl.pulse {
     type pulse
 pcm.!default {
    type pulse
 ctl.!default {
     type pulse
btw this solved the sound problem of flash across konqueror too not just firefox.
64bit sabayon branch5 had the same issue in 4.2kde also
frosch62
Post by frosch62 » Tue Oct 06, 2009 22:42
checked out the linked gentoo forum discussion on this topic and as of today it still doesn't seem solved. i thought i had this same "bug" after a clean install of sabayon 5 kde (x86), but i found a way around it. both amarok and flash are playing after i raised the PCM volume in KMix. it was turned all the way down by default, but doesn't appear to be having problems.
not an expert at all, so i can't help any further if this doesn't work, but it might be worth a try! good luck!
