I found a temporary solution to the problem.
It's strange, but after I kdesu kate, I can open dolphin again in super user mode again. However, the problem with dolphin returns after I reboot or ctrl+alt+backspace.
Latest update breaks dolphin and konqueror in root [Solved]
Re: Latest update breaks dolphin and konqueror in root.
Not to bring this off-topic or anything but I have to disagree with this statement.joost wrote:sudo is for ubuntu, we use "su" or as written above.
//edit: works here.
sudo is completely independant of distro or window manager. http://en.wikipedia.org/wiki/Sudo It is mostly used for multiple user administration purposes to allow different levels of privileges. So, on a single user system it is mostly unnecessary. However, I find it usefull if I want to run just one command as root, there would be fewer keystokes involved. It also keeps me in good habits for security reasons.
kdesu and gksu are GUI frontends (for kde and gnome respectively) to su designed to provide root access for just one specific command, whereas su can be used to provide general root access for subsequent use by any number of commands.
http://www.linfo.org/kdesu.html
I use sudo only because root doesn't find many commands.
For example:
$su
#*password*
#dolphin
#bash: dolphin: command not found
Therefore, I'm forced to:
#sudo dolphin
I use sudo while I'm in root mode to run the commands that root won't find on its own. The advantage of sudo over kdesu is that if I want to end the process, I can select the terminal and press ctrl+c.
I know I'm going a bit off topic, but is there a setting to make root aware of all the commands so that I don't have to use sudo?
For example:
$su
#*password*
#dolphin
#sudo dolphin
Out of curiosity, do you have semantic desktop enabled?
Can you try disable Nepomuk and strigi?
Yes I do have it enabled.joost wrote:Out of curiosity, do you have semantic desktop enabled?
I just disabled it, and reseted the computer to see if this was the problem. However, the problem still remains.
The only remedy that I have at the moment is opening kate in superuser at least once every time I reboot the computer.
i'd try to remove
If root now again would use kde, it will regenerate this folder out of skel. Lets see if that fixes it maybe.
rm -rf /root/.kde4.2/
Hi dsparil
I have the same problem as you. If I do a kdesu dolphin, I get the error message "Could not start process cannot talk to klauncher: The name org.kde.klauncher was not provided by any .service files".
I've had this problem in kde 4.2.2 though; ever since I done a fresh install of SabayonLinux 4.1 kde.
Hope you find a solution, might be a kde bug or some kind of permissions problem?
All the best
Dave
Edit: just Googled problem and got straight to answer.
Here is kde bug link https://bugs.kde.org/show_bug.cgi?id=165268
Here is temp solution: try typing in kdesu dbus-launch dolphin
Cheers
Great thing Google
All the best
Dave
Cheers
I tried this:joost wrote:i'd try to removeIf root now again would use kde, it will regenerate this folder out of skel. Lets see if that fixes it maybe.Code: Select all
$su
*password*
#rm -rf /root/.kde4.2/
I opened a new terminal
$kdesu dolphin
I got the same error.
Nepomuk and strigi are also disabled.
I think that the default KDE configuration that is being produced is what is causing this bug.dave_p_b wrote:Hi dsparil
All the best
Dave
I'm not an expert, but the problem might lie in the default settings found in: /root/.kde4.2/share/config/dolphinrc
Here is what is in it:
[General]
FirstRun=false
ViewPropsTimestamp=2009,5,11,10,10,37
[MainWindow]
Height 800=500
State=AAAA/wAAAAD9AAAAAwAAAAAAAABhAAABrvwCAAAAAvsAAAAYAHQAcgBlAGUAVgBpAGUAdwBEAG8AYwBrAAAAAAD/////AAAAGQEAAAL7AAAAFABwAGwAYQBjAGUAcwBEAG8AYwBrAQAAAEYAAAGuAAAATwEAAAIAAAABAAAArgAAAa78AgAAAAH7AAAAEABpAG4AZgBvAEQAbwBjAGsBAAAARgAAAa4AAADzAQAAAgAAAAP///////////wBAAAAAfsAAAAYAHQAZQByAG0AaQBuAGEAbABEAG8AYwBrAAAAAAD/////AAAATQEAAAUAAAHZAAABrgAAAAQAAAAEAAAACAAAAAj8AAAAAQAAAAIAAAABAAAAFgBtAGEAaQBuAFQAbwBvAGwAQgBhAHIBAAAAAP////8AAAAAAAAAAA==
Width 1280=750
I wonder why not everybody suffers from this bug...
beat you to it two posts back joost
