Sabayon 4.1 K; do not use kuser
dunsurfin
Post by dunsurfin » Thu Apr 30, 2009 0:30
Using kuser to add myself to the lp group made my root and user passwords fail. I advise against using it. Reported as issue 638
Thev00d00
Generally Awesome (tm)
Re: Sabayon 4.1 K; do not use kuser
Post by Thev00d00 » Thu Apr 30, 2009 8:53
Strange, i thought we had sorted this out
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Post by Fitzcarraldo » Wed May 20, 2009 23:07
Just came across Superadduser which is in Portage (but not Entropy). Looks like it would do what you want, if you don't want to use KUser.
screenshot
Thev00d00
Post by Thev00d00 » Thu May 21, 2009 8:52
Kuser is fixed now however =D
twitter: Follow Me
G+: Circle Me
imperialeagle79
Post by imperialeagle79 » Sat Jun 06, 2009 12:03
Thev00d00 wrote:Kuser is fixed now however =D
As of when? I just had a problem this last weekend, it messed up my root and user passwords. (The added guest account worked perfectly! With 0 access to anything :roll: ) I'm pretty sure I was up to date on packages as well.
Post by wolfden » Sat Jun 06, 2009 16:04
yea, it's still not safe to use
Post by Fitzcarraldo » Sat Jun 06, 2009 16:41
Fitzcarraldo wrote:Just came across Superadduser which is in Portage (but not Entropy). Looks like it would do what you want, if you don't want to use KUser.
screenshot
Might be an idea to add this package to the Entropy repository, especially as it's independent of the desktop environment and can be used in any, or even on a TTY console.
Post by wolfden » Sat Jun 06, 2009 16:51
I find doing:
# useradd -m -G users,wheel,audio -s /bin/bash john
# passwd john
Password: (Enter the password for john)
Re-enter password: (Re-enter the password to verify)
much easier than firing up a gui, just add whatever groups you want with it
Post by Fitzcarraldo » Sat Jun 06, 2009 17:18
I'm sure you do, but newcomers might find Superadduser less daunting.
amoebios
Post by amoebios » Tue Jun 09, 2009 9:34
There should be a warning in KUser or it should be removed/hidden until it's fixed. I just ran into that problem. :?
Auto-login saved me from losing access to my account, but i can't perform any administrative tasks now. Any way to recover the root account or reset the password?
Edit:
I'm thinking if you open KUser, add users, then set the passwords for the old users it would prevent losing the passwords. Can somebody confirm that? (or what exactly happens with the passwords?)
