Error while initializing the sound driver sabayon 4.0 r1
bloodyscript
Post by bloodyscript » Sat Jan 10, 2009 17:26
hi i recently upgraded from mini edition 3.4 to 4.0 r1. the sound worked on mini edition and the live cd. but the second reboot after the instaltion i get an error message in kde:
"Sound server informational message:
Error while initializing the sound driver:
device: default can't be opened for playback (No such file or directory)
The sound server will continue, using the null output device."
alsactl restore:
localhost sircody # alsactl restore
Unknown hardware: "HDA-Intel" "Realtek ALC662 rev1" "HDA:10ec0662" "0x1565" "0x820f"
Hardware is initialized using a guess method
lspci | grep audio
02:00.1 Audio device: ATI Technologies Inc RV610 audio device [Radeon HD 2400 PRO]
80:01.0 Audio device: VIA Technologies, Inc. VT1708/A [Azalia HDAC] (VIA High Definition Audio Controller) (rev 10)
aplay -l
localhost sircody # aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA ATI HDMI], device 3: ATI HDMI [ATI HDMI]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: VT82xx [HDA VIA VT82xx], device 0: ALC662 Analog [ALC662 Analog]
Subdevices: 1/1
card 1: VT82xx [HDA VIA VT82xx], device 1: ALC662 Digital [ALC662 Digital]
Subdevices: 1/1
if you need dmesg ill send the out put. ive done alsa config and then go into ever mixr i have and rasie unmute all volume make sure is on the right card. then open juk player and i still get no sound. but whats weird is that in kaffine player the sound will play but only for half a song than it will display [A_O] audio output device is busy. and i loose all the sound once again. i belive my graphics card is trying to be the default sound card when im not useing hdmi. im not the greatest linux user and have been trying to solve the problem but its like running into a wall thinking theres a door there.
oh yea my user is in the audio group and root has the same problem. thank you for the help.
Re: Error while initializing the sound driver sabayon 4.0 r1
Post by wolfden » Sat Jan 10, 2009 19:22
did u try to run alsaconf?
Post by Fitzcarraldo » Sat Jan 10, 2009 19:35
bloodyscript, have you tried K Menu > Control Centre > Sound & Multimedia > Sound System and, below the Hardware tab, change 'Select the audio device:' from 'Autodetect' to 'Advanced Linux Sound Architecture' (and click Apply)? If that makes no difference, strange as it may seem, try unticking 'Enable the sound system' on the General tab (and click Apply). I used to have to do this in an earlier incarnation of SL in order to get sound to work under ALSA.
Although I have had no trouble with audio under SL in the last few releases, the other day I listened to some music with Audacious under SL 3.5 and afterwards lost all sound and had the error message that you mentioned. I rebooted and have not had a problem since. Strange.
bloodyscript
Post by bloodyscript » Sat Jan 10, 2009 21:06
wolfden, yes i did alsaconf many times, it makes kaffine media player play sound for about a minute. then it displayes a error message "[A_O] audio output device busy." and the sounds stops.
fitzcarraldo, just tried it and it displayed the same error message
Post by wolfden » Sat Jan 10, 2009 21:57
did you look at the HDA howto in our wiki?
I thought must of that was resolved in latest kernel
http://wiki.sabayonlinux.org/index.php? ... ound_Cards
bloodyscript
Post by bloodyscript » Sat Jan 10, 2009 22:57
ok this is what i get hwne i start following the guide
step 1: localhost sircody # rmmod snd_hda_intel
step 2: localhost sircody # modprobe snd_hda_intel ALC662
FATAL: Error inserting snd_hda_intel (/lib/modules/2.6.27-sabayon/kernel/sound/pci/hda/snd-hda-intel.ko): Unknown symbol in module, or unknown parameter (see dmesg)
localhost sircody # modprobe snd_hda_intel 834
localhost sircody # modprobe snd-hda-intel alc662
localhost sircody # modprobe snd-hda-intel 835
dmesg:
[ 19.109936] HDA Intel 0000:02:00.1: PCI INT B -> GSI 25 (level, low) -> IRQ 25
[ 19.110038] HDA Intel 0000:02:00.1: setting latency timer to 64
[ 19.110050] HDA Intel 0000:02:00.1: PCI: Disallowing DAC for device
[ 19.136460] HDA Intel 0000:80:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 19.136503] HDA Intel 0000:80:01.0: setting latency timer to 64
[ 19.136510] HDA Intel 0000:80:01.0: PCI: Disallowing DAC for device
[ 19.145961] hda_codec: Unknown model for ALC662, trying auto-probe from BIOS...
[ 226.349889] HDA Intel 0000:80:01.0: PCI INT A disabled
[ 226.352832] HDA Intel 0000:02:00.1: PCI INT B disabled
[ 235.105012] snd_hda_intel: Unknown parameter `ALC662'
[ 310.493587] snd_hda_intel: Unknown parameter `834'
[ 336.632701] snd_hda_intel: Unknown parameter `alc662'
[ 365.676409] snd_hda_intel: Unknown parameter `835'
etc/modules.d/alsa:
# --- BEGIN: Generated by ALSACONF, do not edit. ---
# --- ALSACONF version 1.0.18 ---
alias snd-card-0 snd-hda-intel
alias sound-slot-0 snd-hda-intel
# --- END: Generated by ALSACONF, do not edit. ---
etc/modprobe.d/alsa:
# Alsa kernel modules' configuration file.
# ALSA portion
alias char-major-116 snd
# OSS/Free portion
alias char-major-14 soundcore
## IMPORTANT:
## You need to customise this section for your specific sound card(s)
## and then run `update-modules' command.
## Read alsa-driver's INSTALL file in /usr/share/doc for more info.
## ALSA portion
## alias snd-card-0 snd-hda-intel
## alias snd-card-1 snd-ens1371
## OSS/Free portion
## alias sound-slot-0 snd-card-0
## alias sound-slot-1 snd-card-1
# OSS/Free portion - card #1
alias sound-service-0-0 snd-mixer-oss
alias sound-service-0-1 snd-seq-oss
alias sound-service-0-3 snd-pcm-oss
alias sound-service-0-8 snd-seq-oss
alias sound-service-0-12 snd-pcm-oss
## OSS/Free portion - card #2
## alias sound-service-1-0 snd-mixer-oss
## alias sound-service-1-3 snd-pcm-oss
## alias sound-service-1-12 snd-pcm-oss
alias /dev/mixer snd-mixer-oss
alias /dev/dsp snd-pcm-oss
alias /dev/midi snd-seq-oss
# Set this to the correct number of cards.
options snd cards_limit=1
in step two it states to do modeprobe snd-hda-intel then use "your modle name" useing the chart above the line that has my card
834 ALC662
835 3stack-dig 3-stack (2-channel) with SPDIF
did i enter the name incorrectly? thats the same card found in kinfo center under sound
Post by wolfden » Sun Jan 11, 2009 1:11
try
bloodyscript
Post by bloodyscript » Sun Jan 11, 2009 1:47
ok i iddnt get the error message but after i completed the guide the sound still didnt work i tried a few differnt model names.
my process for the name alc662:
localhost sircody # modprobe snd_hda_intel model=ALC662
localhost sircody # dmesg | grep hda
[ 20.779946] hda_codec: Unknown model for ALC662, trying auto-probe from BIOS...
[ 4467.442757] hda_codec: Unknown model for ALC662, trying auto-probe from BIOS...
[ 4629.029548] hda_codec: Unknown model for ALC662, trying auto-probe from BIOS...
[ 4821.689137] hda_codec: Unknown model for ALC662, trying auto-probe from BIOS...
previously i tried entering my bios {biostar} and turn on on-board sound but couldnt fidn the option in any of the menus.
bloodyscript
Post by bloodyscript » Sun Jan 11, 2009 17:42
ok so i add sum options to the etc/modules.d/alsa file options snd cards_limit=1
options snd_hda_intel index=0
options snd_hda_intel model=3stack-dig
then i did /etc/init.d/alsasound restart. what happend was that i still get the error message but now kaffine payer plays sound like nobodys buisness its the only player the plays sound currently. i downloaded rythmbox from spritz package manager and im not 100% sure if it worked correctly. every time i play a song it it had the red circle with a line through it. going down hte entire list of songs then eventualy it freezes and the dialog box comes up asking to force quite or cancel.
im confused as to whats going on with my sound this is the first time i ever had any kind of problems useing sabayon linux. its still my favorite browser and i will be trying to fix it so i can get the full experince out of 4.0.
ok my bad i posted b4 i acualy listen to kaffine media player this morning last night it was working under gnome ithought mayb it was kde that was messing with the sound but only kaffine player i gnome worked. in kde all sound is gone inless i do alsaconf then afterwards sound works in kaffine player and only kaffine player.
bloodyscript
Post by bloodyscript » Sun Jan 11, 2009 22:07
i was doing sum research and was wondering if you think a .asoundrc file might fix the problem permantly?
