Zenana Community Repo
ws4life16
Re: Zenana Community Repo
Post by ws4life16 » Fri Oct 03, 2008 3:47
how do i get my wireless internet to work on sabayon 3.3 i am new to this os i have a dell inspiron 1521 laptop and i can get the ethernet cord plugged into my router and laptop to work but the wireless card does not and im getting so frustrated when i run codes it reads
[email protected] ~ $ ipconfig
bash: ipconfig: command not found
bash: ip: command not found
[email protected] ~ $ ip config
[email protected] ~ $ /sbin/ifconfig eth0
eth0 Link encap:Ethernet HWaddr 00:1C:23:B1:17:27
inet addr:192.168.1.71 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1842 errors:0 dropped:0 overruns:0 frame:0
TX packets:1483 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1190906 (1.1 Mb) TX bytes:262336 (256.1 Kb)
Interrupt:22
[email protected] ~ $ netstat -nr
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
127.0.0.0 127.0.0.1 255.0.0.0 UG 0 0 0 lo
0.0.0.0 192.168.1.254 0.0.0.0 UG 0 0 0 eth0
please help before i go back to windows vista :(
Post by wolfden » Fri Oct 03, 2008 6:10
moved to archive as 3.3 is not support, nor is 3.4, please download 3.5
sjieke
Post by sjieke » Fri Oct 03, 2008 8:10
Aren't you a little bit hasty about moving this entire thread to archive?
This threads discusses mostly problems with Voodoo's community repo 'Zenana' and thus deals with Sabayon 3.5
The post of Sabayon 3.3 is in the wrong thread in my opinion...
Post by Fitzcarraldo » Fri Oct 03, 2008 11:13
sjieke wrote:Aren't you a little bit hasty about moving this entire thread to archive?
I agree. It looks like the SL 3.3 post about wireless networking has nothing at all to do with the Zenana Community Repo for Entropy.
kodiakmax
Post by kodiakmax » Sun Oct 19, 2008 10:53
I was attempting to install "x11-wm/compiz-0.7.8" however a there is a dependency issue.
"kde-base/kwin:4" is not found.
any suggestions or help?
nimekuwa
Post by nimekuwa » Sun Oct 19, 2008 13:10
kodiakmax wrote:I was attempting to install "x11-wm/compiz-0.7.8" however a there is a dependency issue.
We reported this on the zenana forums, I'm sure v00d00 will look in to it soon
Thev00d00
Generally Awesome (tm)
Post by Thev00d00 » Mon Oct 20, 2008 14:19
Ill try and sort this out today, please look for reports on the zenana forum (http://zenana.hyperfish.org/zenana)
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
DanySK
Post by DanySK » Thu Nov 13, 2008 10:30
Fresh installation, all updates from sabayonlinux.org done. I added zenana and:
localhost danysk # equo world
>>  @@ Calculating System Updates...
>>  @@ Nothing to update.
>>  @@ Nothing to remove.
>>  @@ Caching complete.
No updates in zenana?? :shock:
Database seems to be up to date:
localhost danysk # equo update
>>  @@ Repositories synchronization ...
>>   #  (1/2) Zenana x86-64
>>   # Database URL: http://zenana.hyperfish.org/standard/zenana/database/amd64/3.5
>>   # Database local path: /var/lib/entropy/client/database/amd64/zenana/standard/amd64/3.5
>>   # Database EAPI: 2
>>      Attention: database is already up to date.
