Sabayon-Branded Openoffice
momocore
Post by momocore » Sat May 03, 2008 21:08
All,
I created a splash-screen for openoffice to replace the gentoo-branded or vanilla one. Because I am unable to upload .bmp files, I posted it over at kde-look.org
Here's the link:
http://www.kde-look.org/content/show.php?content=80169
I may make a few more to brand the 'about' dialog as well. I figured this would tie the distro together a bit more.
Let me know what you think!
Here's a screenshot of the splash, note this will not work as the actual spash:
Here's a revised with the version number
ashley194
Re: Sabayon-Branded Openoffice
Post by ashley194 » Sun May 04, 2008 11:34
Hi momocore!
Just applied your new branding to my openoffice, it looks great 8)
Thanks :D
Post by joost » Sun May 04, 2008 11:49
Nice one.
Jayrome
Post by Jayrome » Sun May 04, 2008 11:56
You have good karma, brother. :D
Image Image Image
Post by Stupot » Mon May 05, 2008 0:18
I like it. I think entropy should have this one as default.
Post by Fitzcarraldo » Mon May 05, 2008 17:55
I like it too, but personally would prefer the OpenOffice version number to be included on the splash screen too, as per the original splash screen.
momocore
Post by momocore » Tue May 06, 2008 0:41
Understandable, but note that the font is not available without fees, and I didn't want to make a bunch of versions right off the bat.
I'll throw up a version 2.4 soon, and will try to approximate the font.
momocore
Post by momocore » Fri May 09, 2008 13:22
I modified the splash to show the versions number. I used the most recent version -- 2.4 when 2.5 comes out, I'll change it as well.
Do you think we should put the longer version numbers, i.e. 2.4.X??
Post by Fitzcarraldo » Fri May 09, 2008 14:01
Nice. Thanks, momocore.
Is there going to be a version 2.5? I thought that the next version will be 3?
I think that, if longer version numbers are shown on the original splash screen, it would be good to put them on 'your' splash screen too.
momocore
Post by momocore » Fri May 09, 2008 14:29
I'm not sure about 2.5, I know they're working fervently on 3.0. I was just making a point that we'll need to have a series of these screens for the various versions of OOo
The regular splash screen only shows two digits, and doesn't reflect the incremental changes (i.e. 2.3.1). So I'll leave it as-is for now.
With 3.0, there may be more design changes, so I may have to completely revamp the splash. Time will tell!!
Does anyone think I should make it more of a brighter red color? Do we have an "Official" Sabayon color I can work with?
