[HOWTO]: Resolve Problems With HDA-INTEL Sound Cards
XaresAssassin
Re: [HOWTO]: Resolve Problems With HDA-INTEL Sound Cards
Post by XaresAssassin » Sun Oct 11, 2009 4:59
Edit: For some reason, Sebayon supported my Intel audio from the beginning. I just needed to enable Speakers volume and headphones in Kmix.
peispud
Post by peispud » Thu Sep 30, 2010 8:14
I just updated to 5.4 and and have very low sound and only one channel. I am frustrated as this is the fourth time that sound has stopped on a Sabayon upgrade for this very common chipset. My question is simple. Why not fix pulse audio as Mandriva has done or simply dump it as PCLinux has done so that everybody's hardware works ? I don't want to sound overly critical, but it's a shame when such a polished distro uses alpha quality sound drivers, effectively destroying it's multimedia capabilities. Is is possible to remove pulse audio permanently, or is it tied to system upgrades ? dmesg -
[    1.523523] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[    1.524277] SGI XFS Quota Management subsystem
[    1.524528] Btrfs loaded
[    1.524784] aufs 2-standalone.tree-20100517
[    1.524788] msgmni has been set to 7913
[    1.525242] alg: No test for stdrng (krng)
[    1.525247] async_tx: api initialized (async)
[    1.525328] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    1.525331] io scheduler noop registered
[    1.525332] io scheduler deadline registered
[    1.525424] io scheduler cfq registered (default)
[    1.525651] pcieport 0000:00:02.0: setting latency timer to 64
[    1.525666]   alloc irq_desc for 24 on node 0
[    1.525667]   alloc kstat_irqs on node 0
[    1.525672] pcieport 0000:00:02.0: irq 24 for MSI/MSI-X
[    1.525787] pcieport 0000:00:0a.0: setting latency timer to 64
[    1.525800]   alloc irq_desc for 25 on node 0
[    1.525801]   alloc kstat_irqs on node 0
[    1.525804] pcieport 0000:00:0a.0: irq 25 for MSI/MSI-X
[    1.525911] pcieport 0000:00:15.0: setting latency timer to 64
[    1.525934]   alloc irq_desc for 26 on node 0
[    1.525935]   alloc kstat_irqs on node 0
[    1.525940] pcieport 0000:00:15.0: irq 26 for MSI/MSI-X
[    1.550333] Linux agpgart interface v0.103
[    1.550692] vesafb: framebuffer at 0xd5000000, mapped to 0xffffc90011680000, using 3072k, total 14336k
[    1.550694] vesafb: mode is 1024x768x16, linelength=2048, pages=1
[    1.550695] vesafb: scrolling: redraw
[    1.550697] vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
[    1.556803] Console: switching to colour frame buffer device 128x48
[    1.613940] fbcondecor: console 0 using theme 'sabayon'
[    1.651389] fbcondecor: switched decor state to 'on' on console 0
[    1.652044] fb0: VESA VGA frame buffer device
[    1.652244] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    1.652247] ACPI: Power Button [PWRB]
[    1.652299] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    1.652301] ACPI: Power Button [PWRF]
[    1.656073] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.886154] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.886720] 00:05: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    4.897101] floppy0: no floppy controllers found
[    4.898399] brd: module loaded
[    4.898970] loop: module loaded
[    4.898971] Compaq SMART2 Driver (v 2.6.0)
[    4.899050] HP CISS Driver (v 3.6.20)
[    4.899316] MM: desc_per_page = 128
[    4.899515] Loading iSCSI transport class v2.0-870.
[    4.899863] fnic: Cisco FCoE HBA Driver, ver 1.4.0.98
[    4.900083] Loading Adaptec I2O RAID: Version 2.4 Build 5go
[    4.900084] Detecting Adaptec I2O RAID controllers...
[    4.900202] Adaptec aacraid driver 1.1-5[24702]-ms
[    4.900283] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
[    4.900468] QLogic Fibre Channel HBA Driver: 8.03.02-k2
[    4.900549] iscsi: registered transport (qla4xxx)
[    4.900579] QLogic iSCSI HBA Driver
[    4.900580] Emulex LightPulse Fibre Channel SCSI driver 8.3.10
[    4.900581] Copyright(c) 2004-2009 Emulex.  All rights reserved.
[    4.900726] DC390: clustering now enabled by default. If you get problems load
[    4.900727]        with "disable_clustering=1" and report to maintainers
[    4.900790] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
[    4.900836] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[    4.900865] megasas: 00.00.04.17.1-rc1 Thu. Oct. 29, 11:41:51 PST 2009
[    4.900897] mpt2sas version 04.100.01.00 loaded
[    4.900995] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[    4.901111] 3ware Storage Controller device driver for Linux v1.26.02.002.
[    4.901142] 3ware 9000 Storage Controller device driver for Linux v2.26.02.013.
[    4.901178] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[    4.901212] ipr: IBM Power RAID SCSI Device Driver version: 2.5.0 (February 11, 2010)
[    4.901245] RocketRAID 3xxx/4xxx Controller driver v1.6 (090910)
[    4.901277] stex: Promise SuperTrak EX Driver version: 4.6.0000.4
[    4.901340] cxgb3i: tag itt 0x1fff, 13 bits, age 0xf, 4 bits.
[    4.901372] iscsi: registered transport (cxgb3i)
[    4.901375] Broadcom NetXtreme II iSCSI Driver bnx2i v2.1.0 (Dec 06, 2009)
[    4.901405] iscsi: registered transport (bnx2i)
[    4.901407] VMware PVSCSI driver - version 1.0.1.0-k
[    4.901440] st: Version 20081215, fixed bufsize 32768, s/g segs 256
[    4.901511] osst :I: Tape driver with OnStream support version 0.99.4
[    4.901512] osst :I: $Id: osst.c,v 1.73 2005/01/01 21:13:34 wriede Exp $
[    4.901697] ahci 0000:00:11.0: version 3.0
[    4.901704]   alloc irq_desc for 19 on node 0
[    4.901705]   alloc kstat_irqs on node 0
[    4.901709] ahci 0000:00:11.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[    4.901758]   alloc irq_desc for 27 on node 0
[    4.901759]   alloc kstat_irqs on node 0
[    4.901765] ahci 0000:00:11.0: irq 27 for MSI/MSI-X
[    4.901818] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 4 ports 6 Gbps 0xf impl SATA mode
[    4.901820] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[    4.902079] scsi0 : ahci
[    4.902240] scsi1 : ahci
[    4.902325] scsi2 : ahci
[    4.902409] scsi3 : ahci
[    4.902527] ata1: SATA max UDMA/133 abar [email protected] port 0xfbdfe100 irq 27
[    4.902529] ata2: SATA max UDMA/133 abar [email protected] port 0xfbdfe180 irq 27
[    4.902531] ata3: SATA max UDMA/133 abar [email protected] port 0xfbdfe200 irq 27
[    4.902533] ata4: SATA max UDMA/133 abar [email protected] port 0xfbdfe280 irq 27
[    4.903340]   alloc irq_desc for 17 on node 0
[    4.903341]   alloc kstat_irqs on node 0
[    4.903344] pata_atiixp 0000:00:14.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    4.903360] pata_atiixp 0000:00:14.1: setting latency timer to 64
[    4.903410] scsi4 : pata_atiixp
[    4.903496] scsi5 : pata_atiixp
[    4.904485] ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
[    4.904487] ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xff08 irq 15
[    4.905917] Fixed MDIO Bus: probed
[    4.905972] cnic: Broadcom NetXtreme II CNIC Driver cnic v2.1.1 (Feb 22, 2010)
[    4.906010] I2O subsystem v1.325
[    4.906011] i2o: max drivers = 8
[    4.906219] I2O Configuration OSM v1.323
[    4.906293] I2O Bus Adapter OSM v1.317
[    4.906318] I2O Block Device OSM v1.325
[    4.906506] I2O SCSI Peripheral OSM v1.316
[    4.906529] I2O ProcFS OSM v1.316
[    4.906554] Fusion MPT base driver 3.04.14
[    4.906555] Copyright (c) 1999-2008 LSI Corporation
[    4.906559] Fusion MPT SPI Host driver 3.04.14
[    4.906590] Fusion MPT FC Host driver 3.04.14
[    4.906620] Fusion MPT SAS Host driver 3.04.14
[    4.906651] Fusion MPT misc device (ioctl) driver 3.04.14
[    4.906692] mptctl: Registered with Fusion MPT base driver
[    4.906693] mptctl: /dev/mptctl @ (major,minor=10,220)
[    4.906694] Fusion MPT LAN driver 3.04.14
[    4.906754] usbmon: debugfs is not available
[    4.906755] Initializing USB Mass Storage driver...
[    4.906785] usbcore: registered new interface driver usb-storage
[    4.906786] USB Mass Storage support registered.
[    4.906814] usbcore: registered new interface driver libusual
[    4.906848] usbcore: registered new interface driver ums-alauda
[    4.906870] usbcore: registered new interface driver ums-cypress
[    4.906892] usbcore: registered new interface driver ums-datafab
[    4.906915] usbcore: registered new interface driver ums-freecom
[    4.906938] usbcore: registered new interface driver ums-isd200
[    4.906962] usbcore: registered new interface driver ums-jumpshot
[    4.906985] usbcore: registered new interface driver ums-karma
[    4.907031] usbcore: registered new interface driver ums-onetouch
[    4.907059] usbcore: registered new interface driver ums-sddr09
[    4.907084] usbcore: registered new interface driver ums-sddr55
[    4.907115] usbcore: registered new interface driver ums-usbat
[    4.907215] PNP: No PS/2 controller found. Probing ports directly.
[    4.907550] serio: i8042 KBD port at 0x60,0x64 irq 1
[    4.907557] serio: i8042 AUX port at 0x60,0x64 irq 12
[    4.907756] mice: PS/2 mouse device common for all mice
[    4.908132] rtc_cmos 00:02: RTC can wake from S4
[    4.908186] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    4.908202] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    4.908231] md: linear personality registered for level -1
[    4.908232] md: raid0 personality registered for level 0
[    4.908234] md: raid1 personality registered for level 1
[    4.908235] md: raid10 personality registered for level 10
[    4.908236] md: raid6 personality registered for level 6
[    4.908237] md: raid5 personality registered for level 5
[    4.908238] md: raid4 personality registered for level 4
[    4.908239] md: multipath personality registered for level -4
[    4.908241] md: faulty personality registered for level -5
[    4.908349] device-mapper: ioctl: 4.17.0-ioctl (2010-03-05) initialised: [email protected]
[    4.909137] cpuidle: using governor ladder
[    4.909973] cpuidle: using governor menu
[    4.910066] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    4.910875] usbcore: registered new interface driver hiddev
[    4.910899] usbcore: registered new interface driver usbhid
[    4.910899] usbhid: USB HID core driver
[    4.911039] TCP bic registered
[    4.911041] NET: Registered protocol family 17
[    4.911115] powernow-k8: Found 1 AMD Phenom(tm) II X6 1055T Processor processors (6 cpu cores) (version 2.20.00)
[    4.911144] powernow-k8:    0 : pstate 0 (2800 MHz)
[    4.911145] powernow-k8:    1 : pstate 1 (2200 MHz)
[    4.911146] powernow-k8:    2 : pstate 2 (1500 MHz)
[    4.911147] powernow-k8:    3 : pstate 3 (800 MHz)
[    4.912066] TuxOnIce 3.1 (http://tuxonice.net)
[    4.912117] Scanning swap devices for TuxOnIce signature...
[    4.912195] TuxOnIce scan: No image found.
[    5.095288] ata5.01: ATAPI: HL-DT-ST DVDRAM GH22NS50, TN02, max UDMA/100
[    5.095343] ata5.01: limited to UDMA/33 due to 40-wire cable
[    5.101366] ata5.01: configured for UDMA/33
[    5.207108] ata4: SATA link down (SStatus 0 SControl 300)
[    5.360111] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    5.360115] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    5.360132] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    5.360767] ata3.00: ATA-7: ST3250410AS, 3.AAF, max UDMA/133
[    5.360769] ata3.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[    5.361548] ata3.00: configured for UDMA/133
[    5.362669] ata1.00: ATA-8: WDC WD1002FAEX-00Z3A0, 05.01D05, max UDMA/133
[    5.362671] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.364759] ata1.00: configured for UDMA/133
[    5.375120] scsi 0:0:0:0: Direct-Access     ATA      WDC WD1002FAEX-0 05.0 PQ: 0 ANSI: 5
[    5.375399] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[    5.375426] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    5.375439] sd 0:0:0:0: [sda] Write Protect is off
[    5.375440] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    5.375449] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.375520]  sda:
[    5.386696] ata2.00: ATA-8: WDC WD5000AAJS-22YFA0, 12.01C02, max UDMA/133
[    5.386698] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.387534] ata2.00: configured for UDMA/133
[    5.392069]  sda1 sda2 sda3
[    5.398129] scsi 1:0:0:0: Direct-Access     ATA      WDC WD5000AAJS-2 12.0 PQ: 0 ANSI: 5
[    5.398335] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[    5.398357] sd 1:0:0:0: [sdb] Write Protect is off
[    5.398359] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    5.398368] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.398418] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    5.398432]  sdb:
[    5.398552] scsi 2:0:0:0: Direct-Access     ATA      ST3250410AS      3.AA PQ: 0 ANSI: 5
[    5.398718] sd 2:0:0:0: [sdc] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[    5.398741] sd 2:0:0:0: [sdc] Write Protect is off
[    5.398743] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    5.398752] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.398798] sd 2:0:0:0: Attached scsi generic sg2 type 0
[    5.398814]  sdc:
[    5.402270] scsi 4:0:1:0: CD-ROM            HL-DT-ST DVDRAM GH22NS50  TN02 PQ: 0 ANSI: 5
[    5.407847]  sdb1 sdb2 <
[    5.412240] sd 0:0:0:0: [sda] Attached SCSI disk
[    5.423155]  sdb5sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[    5.424077] Uniform CD-ROM driver Revision: 3.20
[    5.424216] sr 4:0:1:0: Attached scsi CD-ROM sr0
[    5.424312] sr 4:0:1:0: Attached scsi generic sg3 type 5
[    5.434568]  sdb6 sdc1 sdc2 < sdb7 sdb8 sdb9 sdb10 sdc5 sdc6 sdb11 sdc7 sdb12 >
[    5.496524] sd 1:0:0:0: [sdb] Attached SCSI disk
[    5.507348]  sdc8 sdc9 sdc10 >
[    5.537705] sd 2:0:0:0: [sdc] Attached SCSI disk
[    5.537729] Scanning swap devices for TuxOnIce signature...
[    5.783929] - Trying 8:37.
[    5.900820] TuxOnIce scan: No image found.
[    5.900974] TuxOnIce: No image found.
[    5.901387] registered taskstats version 1
[    5.901614] rtc_cmos 00:02: setting system clock to 2010-09-30 02:39:25 UTC (1285814365)
[    5.901655] Freeing unused kernel memory: 584k freed
[    6.327183] scsi: <fdomain> Detection failed (no card)
[    6.373028] imm: Version 2.05 (for Linux 2.4.0)
[    6.434966] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    6.435028] ehci_hcd 0000:00:12.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    6.435059] ehci_hcd 0000:00:12.2: EHCI Host Controller
[    6.435075] ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
[    6.435098] ehci_hcd 0000:00:12.2: debug port 1
[    6.435113] ehci_hcd 0000:00:12.2: irq 17, io mem 0xfbdfe400
[    6.441062] ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 1.00
[    6.441076] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    6.441078] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.441079] usb usb1: Product: EHCI Host Controller
[    6.441080] usb usb1: Manufacturer: Linux 2.6.34-sabayon ehci_hcd
[    6.441081] usb usb1: SerialNumber: 0000:00:12.2
[    6.441340] hub 1-0:1.0: USB hub found
[    6.441343] hub 1-0:1.0: 5 ports detected
[    6.441663] ehci_hcd 0000:00:13.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    6.441674] ehci_hcd 0000:00:13.2: EHCI Host Controller
[    6.441680] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 2
[    6.441698] ehci_hcd 0000:00:13.2: debug port 1
[    6.441707] ehci_hcd 0000:00:13.2: irq 17, io mem 0xfbdfe800
[    6.447065] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[    6.447076] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    6.447077] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.447079] usb usb2: Product: EHCI Host Controller
[    6.447080] usb usb2: Manufacturer: Linux 2.6.34-sabayon ehci_hcd
[    6.447081] usb usb2: SerialNumber: 0000:00:13.2
[    6.447304] hub 2-0:1.0: USB hub found
[    6.447306] hub 2-0:1.0: 5 ports detected
[    6.447611] ehci_hcd 0000:00:16.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    6.447622] ehci_hcd 0000:00:16.2: EHCI Host Controller
[    6.447631] ehci_hcd 0000:00:16.2: new USB bus registered, assigned bus number 3
[    6.447650] ehci_hcd 0000:00:16.2: debug port 1
[    6.447660] ehci_hcd 0000:00:16.2: irq 17, io mem 0xfbdfec00
[    6.453061] ehci_hcd 0000:00:16.2: USB 2.0 started, EHCI 1.00
[    6.453073] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    6.453074] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.453075] usb usb3: Product: EHCI Host Controller
[    6.453077] usb usb3: Manufacturer: Linux 2.6.34-sabayon ehci_hcd
[    6.453078] usb usb3: SerialNumber: 0000:00:16.2
[    6.453291] hub 3-0:1.0: USB hub found
[    6.453293] hub 3-0:1.0: 4 ports detected
[    6.472395] uhci_hcd: USB Universal Host Controller Interface driver
[    6.486605] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    6.486658] ohci_hcd 0000:00:12.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    6.486683] ohci_hcd 0000:00:12.0: OHCI Host Controller
[    6.486691] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 4
[    6.486711] ohci_hcd 0000:00:12.0: irq 18, io mem 0xfbdf7000
[    6.539082] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    6.539084] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.539088] usb usb4: Product: OHCI Host Controller
[    6.539089] usb usb4: Manufacturer: Linux 2.6.34-sabayon ohci_hcd
[    6.539090] usb usb4: SerialNumber: 0000:00:12.0
[    6.539340] hub 4-0:1.0: USB hub found
[    6.539344] hub 4-0:1.0: 5 ports detected
[    6.539650] ohci_hcd 0000:00:13.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    6.539661] ohci_hcd 0000:00:13.0: OHCI Host Controller
[    6.539666] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 5
[    6.539678] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfbdfc000
[    6.592081] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    6.592082] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.592083] usb usb5: Product: OHCI Host Controller
[    6.592084] usb usb5: Manufacturer: Linux 2.6.34-sabayon ohci_hcd
[    6.592085] usb usb5: SerialNumber: 0000:00:13.0
[    6.592326] hub 5-0:1.0: USB hub found
[    6.592330] hub 5-0:1.0: 5 ports detected
[    6.592636] ohci_hcd 0000:00:14.5: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    6.592646] ohci_hcd 0000:00:14.5: OHCI Host Controller
[    6.592652] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 6
[    6.592664] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfbdfd000
[    6.645091] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    6.645092] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.645094] usb usb6: Product: OHCI Host Controller
[    6.645095] usb usb6: Manufacturer: Linux 2.6.34-sabayon ohci_hcd
[    6.645096] usb usb6: SerialNumber: 0000:00:14.5
[    6.645331] hub 6-0:1.0: USB hub found
[    6.645335] hub 6-0:1.0: 2 ports detected
[    6.645627] ohci_hcd 0000:00:16.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    6.645638] ohci_hcd 0000:00:16.0: OHCI Host Controller
[    6.645643] ohci_hcd 0000:00:16.0: new USB bus registered, assigned bus number 7
[    6.645655] ohci_hcd 0000:00:16.0: irq 18, io mem 0xfbdff000
[    6.698072] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    6.698076] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.698077] usb usb7: Product: OHCI Host Controller
[    6.698078] usb usb7: Manufacturer: Linux 2.6.34-sabayon ohci_hcd
[    6.698079] usb usb7: SerialNumber: 0000:00:16.0
[    6.698321] hub 7-0:1.0: USB hub found
[    6.698325] hub 7-0:1.0: 4 ports detected
[    6.713877] sl811: driver sl811-hcd, 19 May 2005
[    6.744101] usb 1-1: new high speed USB device using ehci_hcd and address 2
[    6.773575] Intel(R) PRO/1000 Network Driver - version 7.3.21-k5-NAPI
[    6.773576] Copyright (c) 1999-2006 Intel Corporation.
[    6.808873] iscsi: registered transport (tcp)
[    6.861329] usb 1-1: New USB device found, idVendor=04b4, idProduct=6830
[    6.861331] usb 1-1: New USB device strings: Mfr=56, Product=78, SerialNumber=100
[    6.861333] usb 1-1: Product: USB2.0 Storage Device
[    6.861334] usb 1-1: Manufacturer: Cypress Semiconductor
[    6.861335] usb 1-1: SerialNumber: DEF10AF1F9AD
[    6.861837] scsi6 : usb-storage 1-1:1.0
[    7.015068] usb 1-3: new high speed USB device using ehci_hcd and address 4
[    7.131653] usb 1-3: New USB device found, idVendor=05e3, idProduct=0718
[    7.131655] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[    7.131656] usb 1-3: Product: USB Storage
[    7.131657] usb 1-3: SerialNumber: 000000000033
[    7.132251] scsi7 : usb-storage 1-3:1.0
[    7.613089] usb 7-3: new full speed USB device using ohci_hcd and address 2
[    7.767381] usb 7-3: New USB device found, idVendor=03f0, idProduct=7d04
[    7.767383] usb 7-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    7.767384] usb 7-3: Product: Deskjet F2100 series
[    7.767385] usb 7-3: Manufacturer: HP
[    7.767386] usb 7-3: SerialNumber: CN7984R1GD04XM
[    7.863681] scsi 6:0:0:0: Direct-Access     ST325062 0A               0000 PQ: 0 ANSI: 0
[    7.864624] sd 6:0:0:0: Attached scsi generic sg4 type 0
[    7.865404] sd 6:0:0:0: [sdd] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[    7.866283] sd 6:0:0:0: [sdd] Write Protect is off
[    7.866285] sd 6:0:0:0: [sdd] Mode Sense: 27 00 00 00
[    7.866287] sd 6:0:0:0: [sdd] Assuming drive cache: write through
[    7.867783] sd 6:0:0:0: [sdd] Assuming drive cache: write through
[    7.867785]  sdd: sdd1
[    7.875660]  sdd1: <solaris: [s0] sdd5 [s2] sdd6 [s8] sdd7 >
[    7.878283] sd 6:0:0:0: [sdd] Assuming drive cache: write through
[    7.878285] sd 6:0:0:0: [sdd] Attached SCSI disk
[    7.996071] usb 7-4: new low speed USB device using ohci_hcd and address 3
[    8.132702] scsi 7:0:0:0: Direct-Access     USB TO I DE/SATA Device   0041 PQ: 0 ANSI: 0
[    8.133784] sd 7:0:0:0: Attached scsi generic sg5 type 0
[    8.135302] sd 7:0:0:0: [sde] Attached SCSI disk
[    8.146428] usb 7-4: New USB device found, idVendor=046d, idProduct=c317
[    8.146430] usb 7-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.146431] usb 7-4: Product: USB Multimedia Keyboard
[    8.146432] usb 7-4: Manufacturer: Logitech
[    8.153661] input: Logitech USB Multimedia Keyboard as /devices/pci0000:00/0000:00:16.0/usb7/7-4/7-4:1.0/input/input2
[    8.153821] generic-usb 0003:046D:C317.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Multimedia Keyboard] on usb-0000:00:16.0-4/input0
[    8.164562] input: Logitech USB Multimedia Keyboard as /devices/pci0000:00/0000:00:16.0/usb7/7-4/7-4:1.1/input/input3
[    8.164714] generic-usb 0003:046D:C317.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Multimedia Keyboard] on usb-0000:00:16.0-4/input1
[    8.391069] usb 4-2: new low speed USB device using ohci_hcd and address 2
[    8.541587] usb 4-2: New USB device found, idVendor=046d, idProduct=c045
[    8.541589] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.541590] usb 4-2: Product: USB-PS/2 Optical Mouse
[    8.541591] usb 4-2: Manufacturer: Logitech
[    8.549757] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb4/4-2/4-2:1.0/input/input4
[    8.549985] generic-usb 0003:046D:C045.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:12.0-2/input0
[    8.777066] usb 4-4: new full speed USB device using ohci_hcd and address 3
[    8.930674] usb 4-4: New USB device found, idVendor=07d1, idProduct=f101
[    8.930676] usb 4-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.930677] usb 4-4: Product: D-Link DBT-122
[    8.930678] usb 4-4: Manufacturer: Broadcom Corp
[   28.695121] kjournald starting.  Commit interval 5 seconds
[   28.695129] EXT3-fs (sdb11): mounted filesystem with writeback data mode
[   31.924448] udev: starting version 154
[   35.518687] ATK0110 ATK0110:00: EC enabled
[   35.551696] input: PC Speaker as /devices/platform/pcspkr/input/input5
[   36.026112] EDAC MC: Ver: 2.1.0 Sep 20 2010
[   36.031380] EDAC amd64_edac:  Ver: 3.3.0 Sep 20 2010
[   36.031535] EDAC amd64: This node reports that Memory ECC is currently disabled, set F3x44[22] (0000:00:18.3).
[   36.031546] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   36.031547]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
[   36.031548]  (Note that use of the override may cause unknown side effects.)
[   36.031556] amd64_edac: probe of 0000:00:18.2 failed with error -22
[   36.118383] Bluetooth: Core ver 2.15
[   36.118454] NET: Registered protocol family 31
[   36.118455] Bluetooth: HCI device and connection manager initialized
[   36.118457] Bluetooth: HCI socket layer initialized
[   36.232708] Error: Driver 'pcspkr' is already registered, aborting...
[   36.320221] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[   36.320232] r8169 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[   36.320298] r8169 0000:01:00.0: setting latency timer to 64
[   36.320298] r8169 0000:01:00.0: (unregistered net_device): unknown MAC, using family default
[   36.320325]   alloc irq_desc for 28 on node 0
[   36.320326]   alloc kstat_irqs on node 0
[   36.320336] r8169 0000:01:00.0: irq 28 for MSI/MSI-X
[   36.320403] r8169 0000:01:00.0: eth0: RTL8168b/8111b at 0xffffc90011d98000, 48:5b:39:c9:f7:95, XID 0c100000 IRQ 28
[   36.346299] HDA Intel 0000:00:14.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[   36.495695] xhci_hcd 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[   36.495719] xhci_hcd 0000:03:00.0: setting latency timer to 64
[   36.495721] xhci_hcd 0000:03:00.0: xHCI Host Controller
[   36.495729] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 8
[   36.495815] xhci_hcd 0000:03:00.0: irq 18, io mem 0xfbffe000
[   36.499187] usb usb8: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor
[   36.499192] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[   36.499193] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   36.499194] usb usb8: Product: xHCI Host Controller
[   36.499195] usb usb8: Manufacturer: Linux 2.6.34-sabayon xhci_hcd
[   36.499196] usb usb8: SerialNumber: 0000:03:00.0
[   36.499311] xHCI xhci_add_endpoint called for root hub
[   36.499312] xHCI xhci_check_bandwidth called for root hub
[   36.499330] hub 8-0:1.0: USB hub found
[   36.499332] hub 8-0:1.0: 4 ports detected
[   36.517418] HDA Intel 0000:04:00.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[   36.517420] hda_intel: Disable MSI for Nvidia chipset
[   36.517445] HDA Intel 0000:04:00.1: setting latency timer to 64
[   36.614107] ACPI: resource piix4_smbus [io  0x0b00-0x0b07] conflicts with ACPI region SMRG [io  0x0b00-0x0b2f pref]
[   36.614109] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   36.680443] Bluetooth: Generic Bluetooth USB driver ver 0.6
[   36.680508] usbcore: registered new interface driver btusb
[   37.156876] nvidia: module license 'NVIDIA' taints kernel.
[   37.156881] Disabling lock debugging due to kernel taint
[   37.734687] nvidia 0000:04:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[   37.734693] nvidia 0000:04:00.0: setting latency timer to 64
[   37.734696] vgaarb: device changed decodes: PCI:0000:04:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   37.734857] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  256.53  Fri Aug 27 20:27:48 PDT 2010
[   41.325329] EXT3-fs (sdb11): using internal journal
[   41.519546] kjournald starting.  Commit interval 5 seconds
[   41.519717] EXT3-fs (sdb12): using internal journal
[   41.519720] EXT3-fs (sdb12): mounted filesystem with writeback data mode
[   43.465591] Bluetooth: L2CAP ver 2.14
[   43.465592] Bluetooth: L2CAP socket layer initialized
[   43.500781] Bluetooth: RFCOMM TTY layer initialized
[   43.500786] Bluetooth: RFCOMM socket layer initialized
[   43.500789] Bluetooth: RFCOMM ver 1.11
[   48.165283] r8169 0000:01:00.0: eth0: link up
[   48.165325] r8169 0000:01:00.0: eth0: link up
[   48.699829] fbcondecor: console 1 using theme 'sabayon'
[   48.751775] fbcondecor: switched decor state to 'on' on console 1
[   48.805654] fbcondecor: console 2 using theme 'sabayon'
[   48.857826] fbcondecor: switched decor state to 'on' on console 2
[   48.912619] fbcondecor: console 3 using theme 'sabayon'
[   48.963372] fbcondecor: switched decor state to 'on' on console 3
[   49.017478] fbcondecor: console 4 using theme 'sabayon'
[   49.069055] fbcondecor: switched decor state to 'on' on console 4
[   49.122663] fbcondecor: console 5 using theme 'sabayon'
[   49.174744] fbcondecor: switched decor state to 'on' on console 5
[   50.547536] NET: Registered protocol family 10
[   50.547646] lo: Disabled Privacy Extensions
[   61.196078] eth0: no IPv6 routers present
[   75.729567] ata1.00: configured for UDMA/133
[   75.729571] ata1: EH complete
[   75.810512] ata2.00: configured for UDMA/133
[   75.810516] ata2: EH complete
[   76.632708] ata3.00: configured for UDMA/133
[   76.632711] ata3: EH complete
[  666.945745] plugin-containe[8574]: segfault at 18 ip 00007fd23d220609 sp 00007fd2344cec30 error 4 in libnspr4.so.8[7fd23d20a000+39000]
[  666.990235] plugin-containe[8576]: segfault at 18 ip 00007f6715216609 sp 00007f670c4c4c30 error 4 in libnspr4.so.8[7f6715200000+39000]
[  678.385787] plugin-containe[8584]: segfault at 18 ip 00007f1ab731a609 sp 00007f1aae5c8c30 error 4 in libnspr4.so.8[7f1ab7304000+39000]
[  678.432263] plugin-containe[8586]: segfault at 18 ip 00007fd06d420609 sp 00007fd0646cec30 error 4 in libnspr4.so.8[7fd06d40a000+39000]
[  678.484799] plugin-containe[8588]: segfault at 18 ip 00007f5ae3a0a609 sp 00007f5adacb8c30 error 4 in libnspr4.so.8[7f5ae39f4000+39000]
[  678.531605] plugin-containe[8590]: segfault at 18 ip 00007f1ff19a9609 sp 00007f1fe8c57c30 error 4 in libnspr4.so.8[7f1ff1993000+39000]
[  684.612017] plugin-containe[8592]: segfault at 18 ip 00007f6f09e57609 sp 00007f6f01105c30 error 4 in libnspr4.so.8[7f6f09e41000+39000]
[  684.657778] plugin-containe[8594]: segfault at 18 ip 00007ffc3b121609 sp 00007ffc323cfc30 error 4 in libnspr4.so.8[7ffc3b10b000+39000]
[  684.703973] plugin-containe[8596]: segfault at 18 ip 00007f89a6592609 sp 00007f899d840c30 error 4 in libnspr4.so.8[7f89a657c000+39000]
[  684.747398] plugin-containe[8598]: segfault at 18 ip 00007fcb26a1e609 sp 00007fcb1dcccc30 error 4 in libnspr4.so.8[7fcb26a08000+39000]
[  684.793399] plugin-containe[8600]: segfault at 18 ip 00007fc10a3e1609 sp 00007fc10168fc30 error 4 in libnspr4.so.8[7fc10a3cb000+39000]
[  684.837661] plugin-containe[8602]: segfault at 18 ip 00007fc0eef70609 sp 00007fc0e621ec30 error 4 in libnspr4.so.8[7fc0eef5a000+39000]
[  684.882217] plugin-containe[8604]: segfault at 18 ip 00007f2e5a509609 sp 00007f2e517b7c30 error 4 in libnspr4.so.8[7f2e5a4f3000+39000]
[  684.928950] plugin-containe[8606]: segfault at 18 ip 00007f6bf6c93609 sp 00007f6bedf41c30 error 4 in libnspr4.so.8[7f6bf6c7d000+39000]
[  685.015552] plugin-containe[8608]: segfault at 18 ip 00007f22df8d2609 sp 00007f22d6b80c30 error 4 in libnspr4.so.8[7f22df8bc000+39000]
[  685.088218] plugin-containe[8610]: segfault at 18 ip 00007f685051e609 sp 00007f68477ccc30 error 4 in libnspr4.so.8[7f6850508000+39000]
[ 2277.953047] ata1.00: configured for UDMA/133
[ 2277.953051] ata1: EH complete
[ 2278.017451] ata2.00: configured for UDMA/133
[ 2278.017454] ata2: EH complete
[ 2278.332627] ata3.00: configured for UDMA/133
[ 2278.332630] ata3: EH complete
peispud
Post by peispud » Thu Sep 30, 2010 8:27
I now have acceptable sound after running " $ export KMIX_PULSEAUDIO_DISABLE=1 && kmix" , manually adding master front to the list of available channels, and boosting volume. Hell of a way to turn up the volume.
Post by Fitzcarraldo » Thu Sep 30, 2010 9:48
Much easier just to run ALSAMixer in a Konsole/Terminal and use that to change settings rather than messing with KMix. Just use the command alsamixer and press F6 to select your sound card (or use the command alsamixer -c 0 if your card is Card 0).
peispud
Post by peispud » Thu Sep 30, 2010 10:19
I thought so as well, but only one channel was visible.
Post by Fitzcarraldo » Thu Sep 30, 2010 11:16
Even when you pressed F6 and selected HDA Intel from the pop-up list of sound cards?
BTW, regarding your penultimate post, please use the Code button (top left of the box where you type your post) around console output that you paste into your post. It's a drag to scroll up and down the page to study lengthy output.
peispud
Post by peispud » Thu Sep 30, 2010 11:23
Yes, and thanks for the posting tip ( I was wondering about that ). Selecting the audio tab in winecfg also crashes Wine as it sees HDA Nvidia first instead of the analog VIA chip I'm using with alsamixer to get working sound. I'll play with sabayon later, right now I think I'll reboot into PCLinux for some gaming :) Enough audio troubles for one day :p
Post by Fitzcarraldo » Thu Sep 30, 2010 11:31
Ah, I don't think you mentioned before that you have two sound cards. Did you run ALSAConf (command alsaconf) from a Konsole/Terminal window as root user to select and configure the Intel card? Once you've done that, ALSAMixer can be used to configure the card channels.
If you have more than one sound card it is possible to configure ALSA to know and use them all: see e.g. Gentoo Wiki - ALSA and ALSA Wiki (notice the 'MultipleCards' link on the Main Page?).
Post by Fitzcarraldo » Thu Sep 30, 2010 11:40
peispud wrote:My question is simple. Why not fix pulse audio as Mandriva has done or simply dump it as PCLinux has done so that everybody's hardware works ?
PulseAudio is "fixed". It works fine on the vast majority of PCs on which SL runs. Your problem is that you have multiple sound cards and you need to select the default sound card to be used, which is an ALSA configuration issue, not a PulseAudio issue.
peispud wrote:I don't want to sound overly critical, but it's a shame when such a polished distro uses alpha quality sound drivers, effectively destroying it's multimedia capabilities.
This is nonsense. "alpha quality drivers"! The audio drivers are ALSA drivers, and they are not "alpha quality".
peispud wrote:Is is possible to remove pulse audio permanently, or is it tied to system upgrades ?
See the fourth post in the thread Getting PulseAudio to cooperate
