Sabayon_Linux_DAILY_amd64_MATE iso
Postby mrj0ness » Fri Mar 06, 2015 20:41
it seems every release of this iso fails to boot into live cd. Sabayon_Linux_DAILY_amd64_MATE 2014-Jul-09.iso this one seems to work a little bit but can start upgrading items i did'nt request and make my install unbootable at times which i have to re install. Toshiba Satellite P75-A7200 specs THE SPECS
Processor type Intel Core i7 - 4700MQ
Processor speed 2400.0 MHz
Number of Cores 4.0 Graphics
Graphics Type Integrated
Primary Graphics Chipset Intel HD 4600 also the wifi disconnects randomly
Re: Sabayon_Linux_DAILY_amd64_MATE iso
Postby MrJ » Mon Apr 13, 2015 6:03
wifi still drops randomly, so i tried systemctl mask net-auto-wired systemctl disable NetworkManager-wait-online.service
systemctl disable net-auto-wireless.service
Intel® Centrino® Wireless-N 2230 is my card , Ipw2200 Firmware 3.1~3 and Ipw2100 Firmware 1.3~0 are both installed witch can i remove to fix problem
Return to ISO Testing & Molecule
