System do not react on boot option xdriver
illirio
Post by illirio » Fri Aug 30, 2013 18:00
As we know X11 will show black screen on machines with nvidia drivers downloaded. I did not find a way to disable tham after starting the system, but tried boot option xdriver. If I use 13.08 iso it works perfectly and use vesa driver as I write before boot, but wheb I tried the same thing with daily iso nothing works - the same black screen.
x86_64 KDE.
