How to free up some space to complete my update [Solved]
gocool
Post by gocool » Sat Nov 18, 2017 13:31
Sorry for this noob question. But when I tried to do an update it complained about insufficient disk space.
I have cleared files from /var/tmp/entropy, but is there anything else I can delete?
 @@ Packages needing to be installed/updated/downgraded: 531
╠  @@ Packages needing to be removed: 0
╠  @@ Packages needing to be installed: 10
╠  @@ Packages needing to be reinstalled: 0
╠  @@ Packages needing to be updated: 519
╠  @@ Packages needing to be downgraded: 2
╠  @@ Download size: 2393.8MB
╠  @@ Used disk space: 769.4MB
╠  @@ You need at least: 5556.9MB of free space
╠  !!! Attention
╠  !!! Attention
╠  !!! You don't have enough space for the installation. Free some space into: /var/tmp/entropy
╠  !!! Attention
╠  !!! Attention
     Would you like to continue ? [Yes/No] no
This is my disk space usage.
cinnaminson-sound-room entropy # df -h
Filesystem                                   Size  Used Avail Use% Mounted on
none                                         3.9G  1.3M  3.9G   1% /run
udev                                          10M     0   10M   0% /dev
tmpfs                                        3.9G  225M  3.7G   6% /dev/shm
[color=#FF0000]/dev/mapper/vg_cinnaminsonsoundroom-lv_root   50G   44G  2.6G  95% /[/color]
tmpfs                                        3.9G     0  3.9G   0% /sys/fs/cgroup
tmpfs                                        100M  684K  100M   1% /tmp
/dev/sdb1                                    146G   74G   66G  53% /var/run/media/user/CinnData
/dev/mapper/vg_cinnaminsonsoundroom-lv_home  235G   85G  138G  39% /home
tmpfs                                        798M   28K  798M   1% /run/user/1000
If you notice my root folder has only 2.6 gb available.
and my /home has more than 100 gb available
Any help would be highly appreciated.
Re: How to free up some space to complete my update
Post by sabayonino » Sat Nov 18, 2017 14:13
your /var/tmp/entropy is full
you can remove all its content
# rm -rf -I /var/tmp/entropy
then
# equo cleanup
remove all downloaded packages
by default stored to /var/lib/entropy/client/packages/*
and
# equo cache clean
see
# equo --help
gocool
Post by gocool » Sun Nov 19, 2017 14:04
Thank you sabayonino. Really appreciate this tip.
