Steam - Error Libxcb-dri3
kholyphoenix1
Post by kholyphoenix1 » Sun Nov 05, 2017 13:34
I've done steam installation through the wiki
Link: https://wiki.sabayon.org/index.php?title=Steam
equo i -a steam-meta
steam
Error:
[email protected] ~ $ steam
Repairing installation, linking /home/linux/.steam/steam to /home/linux/.local/share/Steam
Running Steam on sabayon 1.0.0.54-r3 64-bit
STEAM_RUNTIME is enabled by the user
Installing breakpad exception handler for appid(steam)/version(0)
/home/linux/.local/share/Steam/ubuntu12_32/steam: symbol lookup error: /usr/lib32/libxcb-dri3.so.0: undefined symbol: xcb_send_request_with_fds
/home/linux/.local/share/Steam/steam.sh: linha 444: sem correspondência: ssfn*
Re: Steam - Error Libxcb-dri3
Post by joost » Sun Nov 05, 2017 13:58
Try:
find ~/.local/share/Steam/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" \) -print -delete
Then launch Steam again.
kholyphoenix1
Post by kholyphoenix1 » Sun Nov 05, 2017 14:35
No Solved.
Post by joost » Sun Nov 05, 2017 14:37
Should have ran this is user, not as root!
:D
kholyphoenix1
Post by kholyphoenix1 » Sun Nov 05, 2017 14:39
sabayon linux # find ~/.local/share/Steam/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" \) -print -delete
find: ‘/root/.local/share/Steam/’: Arquivo ou diretório não encontrado
sabayon linux #
Delete it manually.
You have displayed the terms of agreement.
I agreed to the terms.
It then displays the following error.
Setting up Steam content in /home/linux/.local/share/Steam
Using no root...
[email protected] ~ $ find ~/.local/share/Steam/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" \) -print -delete
/home/linux/.local/share/Steam/ubuntu12_32/steam-runtime/i386/lib/i386-linux-gnu/libgcc_s.so.1
/home/linux/.local/share/Steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libstdc++.so.6.0.21
Post by sabayonino » Sun Nov 05, 2017 14:46
 equo q belongs /usr/lib32/libxcb-dri3.so.0 -qv
x11-libs/libxcb-1.12-r2
need x11-libs/libxcb-1.12-r2 ??
reinstall
# equo i  x11-libs/libxcb
kholyphoenix1
Post by kholyphoenix1 » Sun Nov 05, 2017 16:40
Installed... Libxcd...
sabayon linux # equo q belongs /usr/lib32/libxcb-dri3.so.0 -qv
sabayon linux # x11-libs/libxcb-1.12-r2
bash: x11-libs/libxcb-1.12-r2: Arquivo ou diretório não encontrado
sabayon linux # clear
sabayon linux # equo i  x11-libs/libxcb
╠  @@ Calculando dependências...
╠  ## [R] [sabayon-weekly] x11-libs/libxcb-1.12-r2|1   [1.12-r2|1]
╠  @@ Pacotes que precisam ser instalados/atualizados/rebaixados: 1
╠  @@ Pacotes que precisam ser removidos: 0
╠  @@ Tamanho de recebimento: 0b
╠  @@ Espaço de disco liberado: 0.0b
╠  @@ Você precisa de pelo menos: 3.0MB de espaço livre
╠  ::: >>>  (1/1) 1 pacote
╠    ## Recebendo: 1 pacote
╠    ## ( mirror #1 ) [x11-libs:libxcb-1.12-r2.a4760534fb4657f597623b33315b8cfac4ff39f5~1.tbz2] @ http://sabayon.c3sl.ufpr.br
╠   ## Recebimento agregado: 1 ítem
╠    # [1] sabayon.c3sl.ufpr.br => x11-libs:libxcb-1.12-r2.a4760534fb4657f597623b33315b8cfac4ff39f5~1.tbz2
╠    ## Verificando a soma de checagem do pacote...
╠    ## ( mirror #1 ) [x11-libs:libxcb-1.12-r2.a4760534fb4657f597623b33315b8cfac4ff39f5~1.tbz2] sucesso @ http://sabayon.c3sl.ufpr.br
╠  +++ >>>  (1/1) x11-libs/libxcb-1.12-r2
╠    ## Desempacotando: x11-libs:libxcb-1.12-r2.a4760534fb4657f597623b33315b8cfac4ff39f5~1.tbz2
╠    ## Fase do Pacote: setup
╠    ## Instalando pacote: x11-libs/libxcb-1.12-r2
╠    ## [X C-language Bindings library]
╠    ## Atualizando repositório dos pacotes instalados: x11-libs/libxcb-1.12-r2
╠    ## Limpando dados do aplicativos anteriormente instalados
>>> Regenerating /etc/ld.so.cache...
╠    ## Fase do Pacote: postremove
╠    ## Fase do Pacote: postinstall
╠    ## Limpando: x11-libs/libxcb-1.12-r2
╠  @@ Instalação completa.
╠ Atualização encontrada: /etc/._cfg0000_locale.gen
╠ Atualização encontrada: /etc/gdm/._cfg0000_custom.conf
╠ Atualização encontrada: /etc/iscsi/._cfg0000_initiatorname.iscsi
╠ Atualização encontrada: /etc/sane.d/._cfg0000_dll.conf
☛ Há arquivos de configuração 4 requerendo atualização
☛ Por favor execute: equo conf update
sabayon linux # exit
exit
libxcb-dri3.so.0 exist... /usr/lib32/... what's problem it's file? :(
Post by joost » Sun Nov 05, 2017 17:51
https://wiki.archlinux.org/index.php/St ... using_dri3
(found with Google, you should try it!) :mrgreen:
kholyphoenix1
Post by kholyphoenix1 » Sun Nov 05, 2017 19:07
LIBGL_DRI3_DISABLE=1 steam
:o :oops:
Solved!
Thanks a lot!
