Nvidia drivers / kernel mismatch? [Solved]
skippy204
Post by skippy204 » Fri Oct 27, 2017 17:35
Hello;
I installed Sabyon on a new computer. Booted into the OS. All working good.
Executed:
equo update
equo upgrade --ask --purge
equo conf update
equo libtest
equo deptest
equo cleanup
reboot the system
X no longer works.
dmesg tells me:
API mismatch: the client has the version 384.90 but this kernel module has the version 370.28. Please make sure that this kernel module and all NVIDIA driver components are the same version.
So I'm thinking this is a mismatch between the Nvidia drivers in the kernel and the Nividia drivers installed with the nvidia-drivers package. Maybe I need to update the kernel (which I've never done on a Sabyon box).
I went to
https://wiki.sabayon.org/index.php?titl ... ng_Entropy
and attempted to follow that. However
 # equo install --ask linux-sabayon
gives me a long list of packages followed by "no packages found"
and
quo search nvidia-drivers
gives me these versions, neither of which match what I think the kernel is looking for.
340.102-r1
Am I correctly identifying the problem? How can I go about resolving?
Thank you much!
Re: Nvidia drivers / kernel mismatch?
Post by sabayonino » Sat Oct 28, 2017 0:05
which kernel version do you have installed or running ?
To install nvidia kernel modules on running kernel :
# equo i  nvidia-drivers#$(uname -r) --ask
PS : There are nvidia-drivers legacy for older nvidia GPUs (x11-drivers/nvidia-drivers-340-*)
reboot and goodluck :roll:
skippy204
Post by skippy204 » Sat Oct 28, 2017 0:48
Kernel is 4.8.0
returns
no packages found.
Post by sabayonino » Sat Oct 28, 2017 11:35
kernel 4.8 (and its modules) was dropped time ago
# $ equo s linux-sabayon -qv
sys-kernel/linux-sabayon-3.10.107
sys-kernel/linux-sabayon-3.18.73
sys-kernel/linux-sabayon-4.1.43
sys-kernel/linux-sabayon-4.11.12
sys-kernel/linux-sabayon-4.12.14
sys-kernel/linux-sabayon-4.13.6
sys-kernel/linux-sabayon-4.4.91
sys-kernel/linux-sabayon-4.9.56
if you want latest nvidia-drivers consider to upgrade to available kernels
kernel-switcher can help you to do this
See available kernels
# kernel-switcher list
Switch to kernel (its modules will be installed)
# kernel-switch <new-kernel-to-instal>l
I.e. : switch to the latest available kernel on repository : (4.13.6)
Consider to switch to one (or more than one) of these kernels according your hardware specs
#kernel-switcher switch  sys-kernel/linux-sabayon-4.13.6 --ask
Look at the new nvidia-drivers installation
more details of kernel-switcher tool :
# kernel-switcher --help
skippy204
Post by skippy204 » Wed Nov 08, 2017 20:33
Thank you for all that.
I got the kernel updated and and synced with Nvidia.
Problem solved. Now on to the next problem which I'm about to post about.
