How to install Kazam?
Postby kholyphoenix1 » Sat Oct 21, 2017 16:44
I need to install Kazam to record some videos.
Could someone help me install it?
I confess that I am a beginner in 'Sabayon'.
Thank you!
kholyphoenix1
Re: How to install Kazam?
Postby kholyphoenix1 » Mon Nov 20, 2017 17:05
[email protected] ~ $ kazam -g
(kazam:8878): Gtk-WARNING **: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(kazam:8878): Gtk-WARNING **: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(kazam:8878): Gtk-WARNING **: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
/usr/bin/kazam:32: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
  from gi.repository import Gtk
  File "/usr/bin/kazam", line 122, in <module>
    from kazam.instant import InstantApp
  File "/usr/lib64/python3.5/site-packages/kazam/instant.py", line 29, in <module>
    from kazam.backend.prefs import *
  File "/usr/lib64/python3.5/site-packages/kazam/backend/prefs.py", line 478, in <module>
    prefs = Prefs()
  File "/usr/lib64/python3.5/site-packages/kazam/backend/prefs.py", line 121, in __init__
    self.read_config()
  File "/usr/lib64/python3.5/site-packages/kazam/backend/prefs.py", line 199, in read_config
    self.audio_source = int(self.config.get("main", "audio_source"))
  File "/usr/lib64/python3.5/site-packages/kazam/backend/config.py", line 103, in get
    return ConfigParser.get(self, section, key)
  File "/usr/lib64/python3.5/configparser.py", line 797, in get
    d)
  File "/usr/lib64/python3.5/configparser.py", line 393, in before_get
    self._interpolate_some(parser, option, L, value, section, defaults, 1)
  File "/usr/lib64/python3.5/configparser.py", line 406, in _interpolate_some
    rawval = parser.get(section, option, raw=True, fallback=rest)
TypeError: get() got an unexpected keyword argument 'raw'
kholyphoenix1
