Login loop after editing /etc/fstab [Solved]
johnnystuff
Post by johnnystuff » Sat Aug 19, 2017 16:24
I didn't create a mount point for my /home partition during the install, cause I thought it was just a matter of adding a line in /etc/fstab and it was all done. That's what I did:
sabayon ~ # cat /etc/fstab
# /etc/fstab
# Created by anaconda on Sat Aug 19 11:52:33 2017
# Accessible filesystems, by reference, are maintained under '/dev/disk'
# See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info
UUID=4aced30d-4ce8-4078-bc05-061de67daaa6 / ext4 defaults,noatime,discard 1 1
UUID=3a3f8f7e-944b-4458-9f54-3a605ee46b6f /home ext4 defaults,noatime,discard 0 1
UUID=EC46-9DA1 /boot/efi vfat umask=0077,shortname=winnt 0 0
but unfortunately this causes a login loop that I cannot fix in any possible way. Basically after I enter my username and pwd it just launches lightdm again and I'm asked to login again.
I thought it was because in the new partition there were no config files associated to my user so I just copied them. I forgot to run a chown though, but I don't think that should be necessary since the copy command should preserve owner and permissions. Anyway, tried also modifying the fstab into '/home/my-username' instead of '/home' alone but no luck there either.
Any idea? Shell I remove the user, mount the partition as /home and add the user again?
By the way, why is not possible to open another tty shell with the CTRL+ALT+F2/3/4... shortcut?
Re: Login loop after editing /etc/fstab
Post by sabayonino » Sat Aug 19, 2017 17:01
I think you didn't copy any files to the new home partition
change user to root running "su"
umount your new home partition
# umount -l /home
and mount it to a tmp folder
# mkdir /mnt/tmp_home && mount UUID=3a3f8f7e-944b-4458-9f54-3a605ee46b6f /mnt/tmp_home
sync old contents to tmp home
# rsync -av /mnt/tmp_home/ /home/
(keep your old datas, don't remove them now)
mount new home again
# mount -o remount /home
restartthe login manager or the system
your old data is stored to the unmounted /home partition , if you want to remove old data to preserve / space , umount /home and then cleanup /home/* folder)
johnnystuff
Post by johnnystuff » Sat Aug 19, 2017 18:02
I don't know what I was doing wrong, I sware I mounted the new home partition as you suggested and copied the files with a trivial 'copy -R' then added the line in fstab and rebooted. Probably the fact I was mounting with the /dev/sda7 name instead that by UUID? Or because rsync works differently than copy? v0v
Anyway, what matters is that now IT WORKS!!! :lol:
Just one little note: the correct syntax is
rsync -av /home /mnt/mounted_home_partition
Re: Login loop after editing /etc/fstab [Solved]
Post by sabayonino » Sat Aug 19, 2017 18:52
get /home UUID
# lsblk --output UUID,MOUNTPOINT
johnnystuff
Post by johnnystuff » Sat Aug 19, 2017 19:02
#blkid is shorter to write and prettier to look at :P
By the way, since it happened recently, what's the way to avoid conflicts with other distro? Of course the username would be the same, so only one /home/my_username folder among all the distro I use. Any issue with user ID, group ID, permissions, metadata and whatnot?
Post by sabayonino » Sat Aug 19, 2017 19:14
make sure the user share the same ID (user and group) , if available
# id <your_username>
or
# id -u <your_username> && id -g <your_username>
