where is dev-java/oracle-jdk ?
Re: where is dev-java/oracle-jdk ?
Postby fjkhf » Sun Mar 16, 2014 20:14
Really? Please… You expect us to help you, but don't provide correct information.
Yes!But what kind of information do you want me to provide?It just nothing happens.
The permissions are
"-rw-r--r--"
fjkhf
Postby svantoviit » Mon Mar 17, 2014 23:32
If you downloaded the tar.gz packages, placed them into distfiles and they have the correct permissions, you should be able to emerge them now.
fjkhf wrote:what kind of information do you want me to provide?
Relevant log or steps so we can reproduce your issue.
svantoviit
Postby fjkhf » Tue Mar 18, 2014 9:49
I downloaded and moved them to distfiles but still nothing with emerge..
fjkhf
Postby svantoviit » Tue Mar 18, 2014 10:24
Could you post the emerge command you run and the output from terminal?
And ev. the output of
ls -l /usr/portage/distfiles/ | egrep '(jre|jdk)'
svantoviit
Postby fjkhf » Tue Mar 18, 2014 11:39
 emerge dev-java/oracle-jdk-bin dev-java/oracle-jre-bin
 * IMPORTANT: 9 news items need reading for repository 'gentoo'.
 * Use eselect news to read news items.
[ebuild  N F   ] dev-java/oracle-jdk-bin-1.7.0.51-r1  USE="X alsa fontconfig nsplugin (-aqua) -derby -doc -examples -jce -pax_kernel -source"
[ebuild  N F   ] dev-java/oracle-jre-bin-1.7.0.51  USE="X alsa nsplugin -fontconfig -jce -pax_kernel"
Fetch instructions for dev-java/oracle-jdk-bin-1.7.0.51-r1:
 * Oracle requires you to download the needed files manually after
 * accepting their license through a javascript capable web browser.
 * Download the following files:
 *   jdk-7u51-linux-x64.tar.gz
 * at 'http://www.oracle.com/technetwork/java/javase/downloads/jdk7-downloads-1880260.html'
 * and move them to '/usr/portage/distfiles'
Fetch instructions for dev-java/oracle-jre-bin-1.7.0.51:
 * Please download 'jre-7u51-linux-x64.tar.gz' from:
 * 'http://www.oracle.com/technetwork/java/javase/downloads/jre7-downloads-1880261.html'
 * and move it to '/usr/portage/distfiles'
The following license changes are necessary to proceed:
 (see "package.license" in the portage(5) man page for more details)
# required by dev-java/oracle-jdk-bin (argument)
>=dev-java/oracle-jdk-bin-1.7.0.51-r1 Oracle-BCLA-JavaSE
# required by dev-java/oracle-jre-bin (argument)
>=dev-java/oracle-jre-bin-1.7.0.51 Oracle-BCLA-JavaSE
Use --autounmask-write to write changes to config files (honoring
CONFIG_PROTECT). Carefully examine the list of proposed changes,
paying special attention to mask or keyword changes that may expose
experimental or unstable packages.
!!! The following installed packages are masked:
- net-im/skype-4.2.0.13::gentoo (masked by: skype-4.0.0.7-copyright license(s))
A copy of the 'skype-4.0.0.7-copyright' license is located at '/usr/portage/licenses/skype-4.0.0.7-copyright'.
- www-plugins/adobe-flash-11.2.202.341::gentoo (masked by: AdobeFlash-11.x license(s))
A copy of the 'AdobeFlash-11.x' license is located at '/usr/portage/licenses/AdobeFlash-11.x'.
- dev-util/nvidia-cuda-toolkit-5.5.22::gentoo (masked by: NVIDIA-CUDA license(s))
A copy of the 'NVIDIA-CUDA' license is located at '/usr/portage/licenses/NVIDIA-CUDA'.
ls -l /usr/portage/distfiles | egrep '(jre|jdk)'
It returns nothing
fjkhf
Postby svantoviit » Tue Mar 18, 2014 13:26
Don't know where you put the downloaded files, but it's not there, where emerge needs them, means in /usr/portage/distfiles
Your "nothing" is pretty much output… All you need to do, is to follow the instructions portage gives you.
So download the desired files, put them into /usr/portage/distfiles/ (eventually check the permissions) and run emerge again.
It's really simple…
svantoviit
Postby fjkhf » Tue Mar 18, 2014 14:00
But that is what I did..
I will try it again , anyway.
Thank you
fjkhf
Previous
