where is dev-java/oracle-jdk ?
fjkhf
Post by fjkhf » Thu Mar 13, 2014 22:59
Hello ,
I can't find
dev-java/oracle-jdk
It is not in the repositories!
I want to remove icedtea!
Re: where is dev-java/oracle-jdk ?
Post by sabayonino » Fri Mar 14, 2014 0:52
fjkhf
Post by fjkhf » Fri Mar 14, 2014 9:33
A lot of stuff there and I am not sure about the procedure and the results!
So, if I want to install the oracle-jdk I should just use
 emerge oracle-jdk
Or I have to do
nano -w /etc/portage/package.use/00-sabayon.package.use
and so on?
Can you give me ,if possible, a simplified example and what to pay attention to?
Thanks!
Post by sabayonino » Fri Mar 14, 2014 17:48
1 - Edit /etc/entropy/client.conf with your favourite text editor as root
and change thisvariable
from ignore-spm-downgrades = disable
to ignore-spm-downgrades = enable
2 - Sync portage tree (first sync can take a long time)
# emerge --sync
3 - Try to install dev-java/oracle-jdk-bin
# emerge dev-java/oracle-jdk-bin --ask
If all goes fine
# equo rescue spmsync
see equo rescue --help for details
then manage your java environment
List available java VMs
$ java-config -L
and
$ java-config --help
or
$ eselect java-vm list
and set Java env.
$ eselect java-vm set user [n]
see
$ eselect java-vm help
fjkhf
Post by fjkhf » Sat Mar 15, 2014 16:55
Hello and thanks fot the help.
The packges aren't installed and I am getting the following :
[ebuild  N F   ] dev-java/oracle-jdk-bin-1.7.0.51-r1  USE="X alsa fontconfig nsplugin (-aqua) -derby -doc -examples -jce -pax_kernel -source"
[ebuild  N F   ] dev-java/oracle-jre-bin-1.7.0.51  USE="X alsa nsplugin -fontconfig -jce -pax_kernel"
Fetch instructions for dev-java/oracle-jdk-bin-1.7.0.51-r1:
 * Oracle requires you to download the needed files manually after
 * accepting their license through a javascript capable web browser.
 * Download the following files:
 *   jdk-7u51-linux-x64.tar.gz
 * at 'http://www.oracle.com/technetwork/java/javase/downloads/jdk7-downloads-1880260.html'
 * and move them to '/usr/portage/distfiles'
Fetch instructions for dev-java/oracle-jre-bin-1.7.0.51:
 * Please download 'jre-7u51-linux-x64.tar.gz' from:
 * 'http://www.oracle.com/technetwork/java/javase/downloads/jre7-downloads-1880261.html'
 * and move it to '/usr/portage/distfiles'
The following license changes are necessary to proceed:
 (see "package.license" in the portage(5) man page for more details)
# required by dev-java/oracle-jdk-bin (argument)
>=dev-java/oracle-jdk-bin-1.7.0.51-r1 Oracle-BCLA-JavaSE
# required by dev-java/oracle-jre-bin (argument)
>=dev-java/oracle-jre-bin-1.7.0.51 Oracle-BCLA-JavaSE
Use --autounmask-write to write changes to config files (honoring
CONFIG_PROTECT). Carefully examine the list of proposed changes,
paying special attention to mask or keyword changes that may expose
experimental or unstable packages.
!!! The following installed packages are masked:
- net-im/skype-4.2.0.13::gentoo (masked by: skype-4.0.0.7-copyright license(s))
A copy of the 'skype-4.0.0.7-copyright' license is located at '/usr/portage/licenses/skype-4.0.0.7-copyright'.
- www-plugins/adobe-flash-11.2.202.341::gentoo (masked by: AdobeFlash-11.x license(s))
A copy of the 'AdobeFlash-11.x' license is located at '/usr/portage/licenses/AdobeFlash-11.x'.
- dev-util/nvidia-cuda-toolkit-5.5.22::gentoo (masked by: NVIDIA-CUDA license(s))
A copy of the 'NVIDIA-CUDA' license is located at '/usr/portage/licenses/NVIDIA-CUDA'.
So, do I have to download them manually?
And also, the
should I change it back?
Post by sabayonino » Sat Mar 15, 2014 17:41
fjkhf wrote: So, do I have to download them manually?
And also, the
uhm... yes maybe , but the problem is related at license also
run
# echo "ACCEPT_LICENSE='*' >> /etc/portage/make.conf"
"emerge" Oracle-sdk again
anyway follow
* at 'http://www.oracle.com/technetwork/java/ ... 80260.html'
good luck
svantoviit
Post by svantoviit » Sat Mar 15, 2014 18:33
fjkhf wrote:So, do I have to download them manually?
Portage is pretty explicit about that ;)
fjkhf
Post by fjkhf » Sat Mar 15, 2014 21:21
Ok, thank you.
The "accept license" didn't work though.
I downloaded , moved to /usr/portage/distfiles ,tried again emerge oracle ..and nothing happens.
So, anyone who use sabayon (and hence equo ) in order to use java jdk must do all this procedure?
Anyway..
When I finish do I have to change this back?
Post by sabayonino » Sat Mar 15, 2014 21:49
this procedure allows mixing portage (Gentoo Package Manager) and Entropy (Default Sabayon Package Manager)
please see Sabayon Wiki - Mixing Portage and Entropy Safely for further details
svantoviit
Post by svantoviit » Sun Mar 16, 2014 9:03
fjkhf wrote:…and nothing happens.
Really? Please… You expect us to help you, but don't provide correct information.
Check the permissions of the downloaded file (for example with ls -l /usr/portage/distfiles/ | egrep '(jre|jdk)'), should be "-rw-r--r--". If not, change it accordingly (chmod 644 FILE).
