Flash [Solved]
bobcollard
Flash [Solved]
Post by bobcollard » Sun Aug 01, 2010 11:48
Any news on upgrade for amd64 flash upgrade that works? Tried to add nswrapper and reinstalled Flashplugin, no joy.
Robert Collard, Springfield, IL
Dell Inspiron 1545 Intel Core 2 Duo T3400 CPUs @2.16Ghz 4GB RAM
Sabayon 5.4, Xfce 4.8 Spin, amd64, Kernel 2.6.37-1
DanySK
Re: Flash
Post by DanySK » Sun Aug 01, 2010 12:10
I have it working on every 64bit installation. Just run
equo install adobe-flash nspluginwrapper
did the trick.
Which is your output for
nspluginwrapper -l
bobcollard
Re: Flash
Post by bobcollard » Sun Aug 01, 2010 19:40
DanySK wrote:I have it working on every 64bit installation. Just run
did the trick.
nspluginwrapper -l
Tried that with a fresh install, got the following screenshot from Hulu:
DanySK
Re: Flash
Post by DanySK » Sun Aug 01, 2010 21:00
Please report the output for:
nspluginwrapper -l
bobcollard
Re: Flash
Post by bobcollard » Sun Aug 01, 2010 21:06
DanySK wrote:Please report the output for:
nspluginwrapper -l
[email protected] ~ $ nspluginwrapper -l
/usr/lib/nsbrowser/plugins/npwrapper.libflashplayer.so
Original plugin: /usr/lib32/nsbrowser/plugins/libflashplayer.so
Plugin viewer: /usr/lib64/nspluginwrapper/i386/linux/npviewer
Wrapper version string: 1.3.0
/usr/lib64/nsbrowser/plugins/npwrapper.libflashplayer.so
bobcollard
Re: Flash [Solved]
Post by bobcollard » Sun Aug 01, 2010 21:12
Working after reboot, thanks a bunch.
iceman600
Re: Flash [Solved]
Post by iceman600 » Mon Aug 02, 2010 23:21
SOLVED?!
i dont think so... i didnt work for me...
the flashplayer installed correctly but the command
nspluginwrapper -l
is giving a error " basj: nspluginwrapper: command not found
i cannot play HULU :(
DanySK
Re: Flash [Solved]
Post by DanySK » Mon Aug 02, 2010 23:27
su
equo install nspluginwrapper
reboot
is for you: the "command not found" error means that you miss the wrapper itself.
iceman600
Re: Flash [Solved]
Post by iceman600 » Tue Aug 03, 2010 0:28
DanySK wrote:
su
reboot
you mean i have to install this ? but it says its a KDE... Im using Gnome?
DanySK
Re: Flash [Solved]
Post by DanySK » Tue Aug 03, 2010 8:27
The repository is the same for both the flavors, so you must have nspluginwrapper in your repo if you are on 64bit. Please post the output of
uname -m
I think you are on 32bit (nspluginwrapper has no sense to a 32bit installation).
