terminal CLI education needed
Alveolar
Post by Alveolar » Wed Jan 06, 2010 4:35
I have been using kubuntu exclusively for over a year. I just installed the latest gaming version of sabayon (3.9GB) and I began reading the how-to's. I opened up the following link and followed instructions
http://wiki.sabayonlinux.org/index.php? ... t_to_do.3F
So I opened up a terminal that said "[email protected] ~ " I typed in "su" It asked for my password. So I typed it in. I then got "add user #" then I started copying and pasting from the above url and basically nothing happens. So I typed in "help" and I got a help menu. So at least my terminal works even if I can manage to screw-up extremely simple instructions.
I am use to sudo bash-ing then apt-get installing (my background is obviously not computer science so I am floundering in what must seem to be pathetic ignorance)
Clay
throdon
Re: terminal CLI education needed
Post by throdon » Wed Jan 06, 2010 5:36
I know this might sound snide, it is not meant to be. if you want some hands on CLI training start reading about gentoo. I haven't even got X running on it but I learned more about the command line in a week over there than in 2.5 to 3 years on linux. Stay here and Sabayon will teach you a lot, and the forum is quite forgiving. Sabayon is a bad ass stable distro but it is a little unforgiving if you do not read before you execute. so use the forums and read all of our documentation, I truly used some of our documentation on my gentoo install because reading it for 2 years I knew where to find out where my questions could be answered. a good place to start is
http://forum.sabayon.org/viewtopic.php?f=86&t=16505
I am not being a dick here I don't know how to add additional users in Sabayon but it should be the same way as in gentoo
 passwd
useradd -m -G users john
passwd john
su - john
just change john to what ever user name you want and away you go. one last thing allow someone to confirm this as the syntax might be a little different in sabayon. if gentoo ever gets its claws in you spend ALOT of time reading about it. I spent 2 years reading about it and I am still clueless, but I continue to read everything I can find, Have fun with sabayon it is a great distro.
Troll hunter with an overzealous nature
micia
Post by micia » Wed Jan 06, 2010 11:05
This topic might help you a lot, if you are searching for bash basics:
http://forum.sabayon.org/viewtopic.php?f=3&t=17235
I don't remember if there is also the user add procedure, but I think that the
way explained by throdon is excellent, you could also be interested in the
CLI utility superadduser:
eix superadduser
* app-admin/superadduser
     Available versions:  1.0.9
     Homepage:            http://www.interlude.org.uk/unix/slackware/
     Description:         Interactive adduser script from Slackware
I was working to a wiki page about bash, but lately I have no time at all, so there is only
a little page about it in Italian...
Post by Fitzcarraldo » Wed Jan 06, 2010 11:05
Alveolar wrote:So I opened up a terminal that said "[email protected] ~ " I typed in "su" It asked for my password.
It was not asking for your password, it was asking for the root user's password (analogous to the Administrator's password in Windows).
[email protected] ~ $ su
Password:  <---- You enter the root user's password here, not user fitzcarraldo's password.
acertm8215 fitzcarraldo # whoami
root
acertm8215 fitzcarraldo # exit
exit
[email protected] ~ $ whoami
fitzcarraldo
No sudo'ing needed here! Actually sudo is still usable, being a valid Linux command, and you can use it if you want although the usual way is to instead use the 'su' (substitute user') command in a Konsole/Terminal window when you need to do anything as the root user, but to only do that when it's really necessary and to log-out ('exit') once the job is done:
fitzcarraldo
Password:
root
acertm8215 fitzcarraldo # <system-wide command here>
exit
fitzcarraldo
If you use the command 'su' then the environment variables and home directory remain those of the user who entered the 'su' command. If you use the command 'su -' rather than just 'su' then the environment variables and home directory become those of the root user.
Actually, the 'su' command can be used to switch temporarily to any other user, not just the root user. For example:
fitzcarraldo
[email protected] ~ $ su - herzog
Password:  <--- User fitzcarraldo needs to enter user herzog's password here, or else he won't be given access to user herzog's account.
herzog
[email protected] ~ $ exit
logout
fitzcarraldo
A well-written explanation of the 'su' command: The su Command.
Alveolar
Post by Alveolar » Wed Jan 06, 2010 15:48
W O W ! and I mean that. Thank you all so very much for your support. I have a lot of reading and things to attempt. You have pointed me in a good direction. Thank You.
Respectfully,
Clay
