Install sabayon w/o Bootloader
t0kedo
Post by t0kedo » Mon Jul 06, 2009 13:40
Just wondering how one would go about installing sabayon without the boot loader? I allready have a boot loader and would just like to add it to that one. =)
Thanks in advance,
t0key
WarraWarra
Re: Install sabayon w/o Bootloader
Post by WarraWarra » Mon Jul 06, 2009 21:33
The bootloader is done last and could kill the installer before this happens.
or
At the grub boot menu config add the config of one that is working to new one.
or
Backup current grub and then let it install and before reboot use quit to quit the installer instead of reboot and manually edit grub.conf using old one and copying SL info into it.
Then you should be able to run
grub
root (hd0,0)
setup (hd0)
or
grub-install /dev/sda
Post by wolfden » Tue Jul 07, 2009 9:06
Just tell it not to install the boot loader and add the SL to your existing Grub file
danielson
Post by danielson » Mon Sep 28, 2009 2:58
I am in a similar situation. I chose to install w/o the boot loader because my sabayon 4.2 is on a separate drive from windows. I wanted to not have a bootloader so i could just select the disk I want to load and go from there. When I select the disk sabayon is on i get to a consol style grub... Where do I go from here? if there is a simple command to type to start up the system that would be great or if there was a way I could just get it to install bootloader on this drive and not on the windows drive that would also be fantastic.
Post by wolfden » Mon Sep 28, 2009 11:38
what exactly is your command prompt displaying?
Grub will dual boot Windows and Linux, why don't you want grub boot loader?
danielson
Post by danielson » Mon Sep 28, 2009 17:12
screan displays:
grub>
I have no problem with the bootloader I just would rather it be installed on sdb instead of sda. This option I cant seem to find. Durring installation I can only choose to not install bootloader or install on sda.
mikey0000
Post by mikey0000 » Sun Oct 04, 2009 12:40
I've found the cheap way around that is checking harddrive order in bios(don't know if this actually works) or disconnect your other drives and install sabayon
triple Booting Mac-osx 10.6, Sabayon Linux and Windows 7
2.5 athlon dual core
DFI infinity mobo
2 gb of DDR2 800 G skill ram 3.3.3.12
nvidia 9600gt
housed in a thermaltake taser III case with 7 fans - all turned off lol
