Problemas al emerger alguna aplicacion cualquiera
djchalo
Post by djchalo » Wed May 30, 2007 5:40
Hola tengo el sigte problema....
actualize mi portage con el --sync && -layman algo asi .....
lo malo es k cuando trato de instalar la mas minima aplicacion con el
#emerge (aplicacion)
comienza la descarga del paquete pero luego comienza a lanzarme una infinidad de lineas de codigo como estas...
Making all in .
kopetewindow.cpp:787:39: warning: "/*" within comment
Making all in kconf_update
kopete-nameTracking.cpp: In function ‘int main()’:
kopete-nameTracking.cpp:27: warning: unused variable ‘inst’
Making all in protocols
Making all in groupwise
Making all in icons
Making all in libgroupwise
Making all in qca
Making all in src
Making all in tasks
rtf.ll: In member function 'void RTF2HTML::PrintUnquoted(const char*, ...)':
rtf.ll:316: warning: function might be possible candidate for 'printf' format attribute
Making all in ui
gwconnector.cpp:49: warning: unused parameter 'server'
gwmessagemanager.cpp: In member function 'void GroupWiseChatSession::receiveGuid(int, const GroupWise::ConferenceGuid&)':
gwmessagemanager.cpp:169: warning: comparison between signed and unsigned integer expressions
gwmessagemanager.cpp: In member function 'void GroupWiseChatSession::slotCreationFailed(int, int)':
gwmessagemanager.cpp:195: warning: comparison between signed and unsigned integer expressions
Making all in msn
Making all in ui
Making all in webcam
Making all in libmimic
mimic.c:32: warning: no previous prototype for 'mimic_open'
decode.c: In function 'decode':
decode.c:262: warning: comparison between signed and unsigned
decode.c:273: warning: comparison between signed and unsigned
encode.c: In function 'encode_main':
encode.c:313: warning: comparison between signed and unsigned
encode.c:339: warning: comparison between signed and unsigned
encode.c:130: warning: unused parameter 'out_buf'
encode.c: In function 'compare_blocks':
encode.c:396: warning: declaration of 'd' shadows a previous local
encode.c:388: warning: shadowed declaration is here
vlc_decode.c: In function '_vlc_decode_block':
vlc_decode.c:37: warning: comparison between signed and unsigned
Making all in .
./msnswitchboardsocket.h:135: Warning: Unexpected variable declaration.
./msnswitchboardsocket.h:139: Warning: Unexpected variable declaration.
msnaddcontactpage.cpp:28: warning: unused parameter 'connected'
msnnotifysocket.cpp: In member function 'void MSNNotifySocket::slotMSNAlertLink(unsigned int)':
msnnotifysocket.cpp:701: warning: unused variable 'urlToRun'
msnnotifysocket.cpp: In member function 'virtual void MSNNotifySocket::handleError(uint, uint)':
/usr/bin/install -c -p -m 644 'irc.protocol' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/services/irc.protocol'
/usr/bin/install -c -p -m 644 'ircnetworks.xml' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/apps/kopete/ircnetworks.xml'
libtool: install: warning: remember to run `libtool --finish /usr/kde/3.5/lib64/kde3'
Making install in oscar
Making install in liboscar
Making install in .
/bin/sh ../../../libtool --silent --mode=install /usr/bin/install -c -p 'libkopete_oscar.la' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/lib64/libkopete_oscar.la'
libtool: install: warning: remember to run `libtool --finish /usr/kde/3.5/lib64'
Making install in aim
Making install in ui
/usr/bin/install -c -p -m 644 'kopete_aim.desktop' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/services/kopete_aim.desktop'
/bin/sh ../../../../libtool --silent --mode=install /usr/bin/install -c -p 'kopete_aim.la' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/lib64/kde3/kopete_aim.la'
/usr/bin/install -c -p -m 644 'aim.protocol' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/services/aim.protocol'
Making install in icq
Making install in .
/usr/bin/install -c -p -m 644 'x-icq.desktop' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/mimelnk/application/x-icq.desktop'
/bin/sh ../../../../libtool --silent --mode=install /usr/bin/install -c -p 'kopete_icq.la' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/lib64/kde3/kopete_icq.la'
/usr/bin/install -c -p -m 644 'kopete_icq.desktop' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/services/kopete_icq.desktop'
Making install in icons
mkdir -p -- /var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/apps/kopete/icons/hicolor/16x16/actions
mkdir -p -- /var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/apps/kopete/icons/hicolor/32x32/apps
mkdir -p -- /var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/apps/kopete/icons/hicolor/16x16/apps
Making install in yahoo
Making install in libkyahoo
Making install in .
Making install in tests
/bin/sh ../../../libtool --silent --mode=install /usr/bin/install -c -p 'kopete_yahoo.la' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/lib64/kde3/kopete_yahoo.la'
/usr/bin/install -c -p -m 644 'yahooconferenceui.rc' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/apps/kopete_yahoo/yahooconferenceui.rc'
/usr/bin/install -c -p -m 644 'kopete_yahoo.desktop' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/services/kopete_yahoo.desktop'
/usr/bin/install -c -p -m 644 'yahoochatui.rc' '/var/tmp/portage/kde-base/kopete-3.5.7/image//usr/kde/3.5/share/apps/kopete_yahoo/yahoochatui.rc'
Making install in winpopup
etc... eso no es ni el 1% de las lineas k me arroja... no se pork nunca me habia pasado...
por ejemplo emergi el kopete (porque el otro lo desintale por casualidad)... y bajo el paquete en menos de 10 min pero llevo mas de 1 hora lleno de estas lineas en la consola y aun no lo instala......
k demonios pasa?????
porfavor si alguien sabe k pasa...
mi version es la live cd x64 3.3 2.6.20-sabayon-r3
lo otro el pc hace todo como en camara lenta cuando esta haciendo las famosas lineas de codigo en la consola....
mi makina es un amd 64 de 3800+ con tarjeta nvidia de 128 - 1 giga de ram
ojalas y me ayuden,,,, muchas gracias
daniequy
Post by daniequy » Wed May 30, 2007 14:34
Eso que te pasa es lo mas normal, tu consola esta compilando el programa, poniendo todos los archivos donde deben ir, hay programas que lo hacen rapido porque son pequeños y tienen una pequeña cantidad de ficheros pero los mas grandes demoran mas.
Todo lo que dices es muy normal.
Saludos.... :wink:
Moderador Sabayon Linux
djchalo
Post by djchalo » Wed May 30, 2007 17:45
ufff se demoro 1:15 min instalar el kopete ....
daniequy
Post by daniequy » Wed May 30, 2007 17:57
Normal
