Resolucion 1440*900 no me funciona Beryl
dguez
Post by dguez » Wed May 30, 2007 2:24
Apenas pude colocar la resolucion nativa de mi monitor Acer Al1916W (1440*900);
gracias a los topics que hay aqui, pero ahora no me funciona Beryl????
si alguien pudiera ayudarme con eso, tengo que reinstalar el beryl o que se puede hacer en este caso????
de antemano les agradesco por toda la informacion aquì encontrada.
OS:sabayon 3.3
por si acaso les dejo mi xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 ([email protected]) Thu Jan 18 11:51:41 UTC 2007
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/lib/X11/rgb"
FontPath "/usr/lib/X11/fonts/local/"
FontPath "/usr/lib/X11/fonts/misc/:unscaled"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/misc/"
FontPath "/usr/lib/X11/fonts/Type1/"
FontPath "/usr/lib/X11/fonts/CID/"
FontPath "/usr/lib/X11/fonts/Speedo/"
FontPath "/usr/lib/X11/fonts/100dpi/"
FontPath "/usr/lib/X11/fonts/75dpi/"
FontPath "/usr/lib/X11/fonts/cyrillic/"
FontPath "/usr/lib/X11/fonts/TTF/"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "ServerFlags"
Option "Xinerama" "0"
EndSection
Section "InputDevice"
# generated from data in "/etc/conf.d/gpm"
Identifier "Mouse0"
Driver "mouse"
Option "Protocol"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
# generated from default
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Acer AL1916W"
HorizSync 31.0 - 84.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce FX 5200"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Option "metamodes" "1440x900_60 +0+0; 800x600 +0+0; 640x480 +0+0"
SubSection "Display"
Depth 24
Modes "1600x1200" "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Apokalyptica79
Post by Apokalyptica79 » Fri Jun 01, 2007 19:57
Hola dguez.
Alguna vez usaste beryl con esa resolución con alguna otra distro? Si fue así con cual fue.
Otra cosa que no entiendo es esto de tu xorg.conf
Section "Screen"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Lo que no entiendo es eso que está en negrita.
Saludos.
b_alf
Imagenes para la cupula de cielo
Post by b_alf » Mon Jun 04, 2007 16:39
Hola, ya se que no tiene asi como que mucho que ver, perdon, pero queria saber si alguien me podia recomendar algun sitio donde bajar imagenes que se adapten bien a la cupula de cielo del cubo de beryl. Gracias :D :wink:
Apokalyptica79
Post by Apokalyptica79 » Mon Jun 04, 2007 17:25
Hola b_alf, lo que estás buscando es el sky dome, busca en google ahi te va a tirar todos los sitios con sky disponibles.
Saludos.
b_alf
Post by b_alf » Mon Jun 04, 2007 17:36
Pura Vida Apokalyptica79! Muchas gracias! :wink:
Apokalyptica79
Post by Apokalyptica79 » Mon Jun 04, 2007 17:47
De nada. Para eso estamos en el foro.
:D
coldfire
Post by coldfire » Thu Jun 07, 2007 15:30
HOLA, ESPERO NOS PUEDAN AYUDAR, YA QUE SI CONFIGURO LA RESOLUCION EN MI USUARIO NORMAL, NO SE GUARDA LA CONFIGURACION Y CADA VEZ QUE INICIO SESION INICIA CON 1024 * 768 (MI RESOLUCION NORMAL ES 1280 * 1024) ENTONCES, HICE EL CAMBIO EN ROOT, Y YA QUEDO PERMANENTE EL CAMBIO, PERO AHORA NO JALA BERYL. :(
ANTES CUANDO INICIABA SESION EN 1024 * 768, Y LO CAMBIABA A 1280 * 1024 EL BERYL NO ME PONIA PEROS, PERO AHORA QUE YA ESTA PERMANENTE SIMPLEMENTE ME CAMBIA A MI OTRO GESTOR DEVENTANAS, ESPERO NOS PUEDAN AYUDAR
igual les dejo el archivo xorg.conf DE ANTEMANO GRACIAS :)
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
ModelName "LG L1950S"
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 75.0
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
BoardName "GeForce 7600 GS"
EndSection
Section "Screen"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Option "metamodes" "CRT-0: 1024x768 +0+0; CRT-0: 1280x1024 +0+0; CRT-0: 800x600 +0+0; CRT-0: 640x480 +0+0"
Depth 24
EndSubSection
EndSection
Apokalyptica79
Post by Apokalyptica79 » Thu Jun 07, 2007 15:37
Hola coldfire que versión de sabayon tenés?
Te paso mi xorg.conf para que veas aunque yo no uso la resolución que vos tenés pero no tengo ningún problema.
Section "Files"
#FontPath "/usr/share/fonts/local/"
FontPath "/usr/share/fonts/misc/"
FontPath "/usr/share/fonts/Type1/"
FontPath "/usr/share/fonts/TTF/"
FontPath "/usr/share/fonts/75dpi/"
FontPath "/usr/share/fonts/100dpi/"
FontPath "/usr/share/fonts/corefonts"
EndSection
# Module section -- this is an optional section which is used to specify
# which run-time loadable modules to load when the X server starts up.
Section "Module"
Load "dbe"
Load "i2c"
Load "glx"
Load "ddc"
Load "type1"
Load "freetype"
Load "extmod"
Load "synaptics"
Load "vbe"
# Load "dri"
EndSection
# Server flags section. This contains various server-wide Options.
Option "AllowMouseOpenFail" "true"
#Option "AIGLX" "true"
EndSection
# Input devices
# Core keyboard's InputDevice section
Identifier "Mouse3"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizScrollDelta" "0"
Option "SHMConfig" "on"
# Do you keep moving the mouse while typing? Try this trick.
#synclient TouchpadOff=1 disable your synaptics touchpad
#synclient TouchpadOff=0 enable your synaptics touchpad
EndSection
Identifier "Keyboard1"
Driver "kbd"
Option "AutoRepeat" "500 5"
Option "XkbModel" "pc105"
Option "XkbLayout" "es"
Option "XkbRules" "xorg"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/wacom" # Change to
# /dev/input/event
# for USB
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
# /dev/input/event
# for USB
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
# /dev/input/event
# for USB
Option "Type" "cursor"
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "ImPS/2"
EndSection
Identifier "Mouse2"
Driver "mouse"
EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "Generic Monitor"
#Option "DPMS"
VertRefresh 50-160
HorizSync 30-71
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
Identifier "VESA"
Driver "nvidia" # do not remove vesa
#Option "XAANoOffscreenPixmaps"
#Option "BusType" "PCI"
#Option "ColorTiling" "on"
#Option "EnablePageFlip" "on"
EndSection
# Screen sections.
Section "Screen"
# The Identifier, Device and Monitor lines must be present
Identifier "Screen 1"
Device "VESA"
Monitor "Generic Monitor"
#Option "AddARGBGLXVisuals" "true"
# The favoured Depth and/or Bpp may be specified here
DefaultDepth 24
Depth 8
ViewPort 0 0
Modes "1024x768" "800x600" "640x480"
EndSubsection
Depth 16
ViewPort 0 0
EndSubsection
Depth 24
ViewPort 0 0
EndSubsection
EndSection
# The Identifier line must be present
Identifier "Main Layout"
Screen 0 "Screen 1"
InputDevice "Mouse1" "CorePointer"
InputDevice "Mouse2" "SendCoreEvents"
InputDevice "Mouse3" "SendCoreEvents"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
#Option "Composite" "Enable"
EndSection
Si tu problema persiste porque no usas otra configuración si anda bien, no veo porque la necesidad de usar la resolución que estás queriendo.
Saludos.
coldfire
Post by coldfire » Thu Jun 07, 2007 15:41
LA VERSION 3.3, LO QUE PASA ES QUE DESDE QUE LE CAMBIE, AUNQUE VUELVA A MI RESOLUCION ANTERIOR YA NO JALA BERYL, BUENO ME MANDA A METACITY. OLVIDE MENCIONAR QUE SOY BASTANTE NUEVO PARA ESTO DE LINUX Y SABAYON ES LA PRIMER DISTRO QUE USO :lol: .
Apokalyptica79
Post by Apokalyptica79 » Thu Jun 07, 2007 15:42
Hola es la version 3.3 mino o full?
