driver nvidia
Conversações gerais a respeito de Sabayon Linux
khyron
driver nvidia
Post by khyron » Wed Jun 26, 2013 17:08
Boa tarde!
EU gostaria de saber se alguem poderia me ajudar instalar o driver da nvidia aqui no sabayon 13.04 64bits "kde"
dei uma olhada no site, mas nao consegui entender muito tem td aquilo, e também acho q esta desatualizado
sistema: sabayon 13,04 /64 / kde
placa de video: nvidia gforce 8800 gts 512
obrigado
khyron
Re: driver nvidia
Post by khyron » Fri Jun 28, 2013 0:59
Informações adicionais
1) Processador:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 26
Model name: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Stepping: 5
CPU MHz: 1596.000
BogoMIPS: 5397.03
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 8192K
NUMA node0 CPU(s): 0-7
2) video
lsmod | grep nvid
nvidia               9364356  22
[   13.073452] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
lspci -k | grep nvidia
        Kernel driver in use: nvidia
        Kernel modules: nouveau, nvidia
lspci -k | grep VGA
02:00.0 VGA compatible controller: NVIDIA Corporation G92 [GeForce 8800 GTS 512] (rev a2)
3) Sistema
Linux system 3.8.0-sabayon #1 SMP Fri May 24 17:20:54 UTC 2013 x86_64 Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz GenuineIntel GNU/Linux
4) lspci
00:00.0 Host bridge: Intel Corporation 5520/5500/X58 I/O Hub to ESI Port (rev 12)
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 12)
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 12)
00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 12)
00:09.0 PCI bridge: Intel Corporation 7500/5520/5500/X58 I/O Hub PCI Express Root Port 9 (rev 12)
00:10.0 PIC: Intel Corporation 7500/5520/5500/X58 Physical and Link Layer Registers Port 0 (rev 12)
00:10.1 PIC: Intel Corporation 7500/5520/5500/X58 Routing and Protocol Layer Registers Port 0 (rev 12)
00:11.0 PIC: Intel Corporation 7500/5520/5500 Physical and Link Layer Registers Port 1 (rev 12)
00:11.1 PIC: Intel Corporation 7500/5520/5500 Routing & Protocol Layer Register Port 1 (rev 12)
00:13.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub I/OxAPIC Interrupt Controller (rev 12)
00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 12)
00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 12)
00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 12)
00:15.0 PIC: Intel Corporation 7500/5520/5500/X58 Trusted Execution Technology Registers (rev 12)
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
00:1c.1 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 2
00:1c.4 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
00:1f.2 IDE interface: Intel Corporation 82801JI (ICH10 Family) 4 port SATA IDE Controller #1
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
00:1f.5 IDE interface: Intel Corporation 82801JI (ICH10 Family) 2 port SATA IDE Controller #2
06:00.0 SATA controller: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 02)
06:00.1 IDE interface: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 02)
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller (rev 03)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller (rev 03)
09:06.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
3f:00.0 Host bridge: Intel Corporation Xeon 5500/Core i7 QuickPath Architecture Generic Non-Core Registers (rev 05)
3f:00.1 Host bridge: Intel Corporation Xeon 5500/Core i7 QuickPath Architecture System Address Decoder (rev 05)
3f:02.0 Host bridge: Intel Corporation Xeon 5500/Core i7 QPI Link 0 (rev 05)
3f:02.1 Host bridge: Intel Corporation Xeon 5500/Core i7 QPI Physical 0 (rev 05)
3f:03.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller (rev 05)
3f:03.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Target Address Decoder (rev 05)
3f:03.4 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Test Registers (rev 05)
3f:04.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Control Registers (rev 05)
3f:04.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Address Registers (rev 05)
3f:04.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Rank Registers (rev 05)
3f:04.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Thermal Control Registers (rev 05)
3f:05.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Control Registers (rev 05)
3f:05.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Address Registers (rev 05)
3f:05.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Rank Registers (rev 05)
3f:05.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Thermal Control Registers (rev 05)
3f:06.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Control Registers (rev 05)
3f:06.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Address Registers (rev 05)
3f:06.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Rank Registers (rev 05)
3f:06.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Thermal Control Registers (rev 05)
khyron
Re: driver nvidia
Post by khyron » Fri Jun 28, 2013 1:01
com pelo q estou vendo o driver esta instalado, mas como saber informação mais precisa sobre isto?
khyron
Re: driver nvidia
Post by khyron » Fri Jun 28, 2013 1:18
Mais informações:
Tamanho do recebimento: 3.7MB
Espaço necessário: 11.9MB
Licença: NVIDIA-r1
Soma de Checagem: af961b8daf19afd332293919d3c12079
USE flags: -custom-cflags -kernel_FreeBSD -pax_kernel -tools -x-multilib X abi_x86_64 acpi amd64 elibc_glibc kernel_linux multilib userland_GNU
Dependências para rodar programa
=sys-kernel/linux-sabayon-3.8.13~-1
virtual/modutils
~x11-drivers/nvidia-userspace-319.23
~x11-drivers/nvidia-userspace-319.23[-tools]
~x11-drivers/nvidia-userspace-319.23[X]
~x11-drivers/nvidia-userspace-319.23[multilib]
Dependências para construção
sys-apps/pciutils
sys-apps/sed
virtual/linux-sources
Estou achando q estte driver nao esta ok, pois nao consigo ativar o OpenGL na configuração de sistema > efeitos da área de trabalho, apenas opção Xrender pode ficar ativo, se eu colocar OpenGL o Ambiente grafico nao sobe mais.
Obrigado
khyron
Re: driver nvidia
Post by khyron » Sun Jun 30, 2013 17:15
i cant close this topic.... remove this topic please...im stop use sabayon
thx
Re: driver nvidia
Post by albfneto » Sun Jun 30, 2013 19:47
não precisa parar de usar Sabayon por causa isso!
funciona a NVIDIA e bem...o driver está OK, eu uso!
a Renderização do Kwin já é OpenGL, não é xrender! Vc tem que usar nas janelas do Kwin, composição OpenGL e varredura rasterizada...
para usar OpenGL senão funciona, poste aqui a saída do comando:
eselect qtgraphicssystem list
comandos, completa pra re-instalar os drivers,
# equo up
# equo u
# equo i linux-sabayon
$ eselect kernel list (veja o num do kernel mais novo)
# eselect kernel set num do kernel mais novo
$ eselect bzimage list (veja o num da bzimage correspondente ao kernel mais novo)
# eselect bzimage set num do bzimage do kernel mais novo
# equo i nvidia-drivers nvidia-settings nvidia-userspace
# eselect opengl set nvidia
aí faz reboot. Se o x não entra, tente o comando>:
/etc/init.d/xdm restart
