after update Mixxx hangs
Squirrel
Post by Squirrel » Sun Sep 04, 2016 18:13
Hi to all
after my last update with Rigo I cannot start Mixxx. It starts and ask me where I have my music installed. I select a path and click choose. Hereafter this window disappears and only the main window of mixxx stays but hangs.
[email protected] ~ $ mixxx
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
ALSA lib /var/tmp/portage/media-libs/alsa-lib-1.1.2/work/alsa-lib-1.1.2/src/pcm/
pcm_asym.c:106:(_snd_pcm_asym_open) capture slave is not defined
ALSA lib /var/tmp/portage/media-libs/alsa-lib-1.1.2/work/alsa-lib-1.1.2/src/conf
misc.c:1281:(snd_func_refer) Unable to find definition 'cards.SB-XFi.pcm.hdmi.0:
CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
.c:4371:(_snd_config_evaluate) function snd_func_refer returned error: Datei ode
r Verzeichnis nicht gefunden
.c:4850:(snd_config_expand) Evaluate error: Datei oder Verzeichnis nicht gefunde
n
pcm.c:2450:(snd_pcm_open_noupdate) Unknown PCM hdmi
n
misc.c:1281:(snd_func_refer) Unable to find definition 'cards.SB-XFi.pcm.modem.0
:CARD=0'
n
pcm.c:2450:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline:CARD=0,DEV=0
:CARD=0'
n
:CARD=0'
n
pcm.c:2450:(snd_pcm_open_noupdate) Unknown PCM phoneline
ALSA lib /var/tmp/portage/media-libs/alsa-lib-1.1.2/work/alsa-lib-1.1.2/src/confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.SB-XFi.pcm.modem.0:CARD=0'
ALSA lib /var/tmp/portage/media-libs/alsa-lib-1.1.2/work/alsa-lib-1.1.2/src/conf.c:4371:(_snd_config_evaluate) function snd_func_refer returned error: Datei oder Verzeichnis nicht gefunden
ALSA lib /var/tmp/portage/media-libs/alsa-lib-1.1.2/work/alsa-lib-1.1.2/src/conf.c:4850:(snd_config_expand) Evaluate error: Datei oder Verzeichnis nicht gefunden
ALSA lib /var/tmp/portage/media-libs/alsa-lib-1.1.2/work/alsa-lib-1.1.2/src/pcm/pcm.c:2450:(snd_pcm_open_noupdate) Unknown PCM phoneline
connect(2) call to /dev/shm/jack-1001/default/jack_0 failed (err=Datei oder Verzeichnis nicht gefunden)
attempt to connect to server failed
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[Auxiliary1]" , "passthrough" )
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[Auxiliary2]" , "passthrough" )
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[Auxiliary3]" , "passthrough" )
Warning [Main]: ControlDoublePrivate::getControl returning NULL for ( "[Auxiliary4]" , "passthrough" )
Warning [Main]: Unrecognized OpenGL version
Presently I have no idea.
Many thanks for help
Squirrel
