Entropy. Propose many downgrades [Solved]
Post by albfneto » Fri Jul 29, 2016 14:21
In one of my Sabayon installations.
yesterday, I updated the repositories,normal command...
# equo up
then, in Rigo, Magneto and also using:
# equo u -p
The system proposed downgrading many KDE packages.... 146 KDE packages will be downgraded...
is it real? Until now, i dont run the "upgrade" command...
Re: Entropy. Propose many downgrades.
Post by Stupot » Fri Jul 29, 2016 18:27
What repos do you have enabled? Can you give us the actual output?
Post by albfneto » Fri Jul 29, 2016 23:51
I installed two community repositories: Community and KDE-Unstable.
even when removed, the problem still continue
tomorrow, i will post the output, since the partition is in other installation.
this is my main Sabayon installation.
the cited sabayon is my other partition.
in this comp i have two sabayon and one OpenSUSE.
but i run the command with "pretend" option, in order to not dowgrade all my KDE
Re: Entropy. Propose many downgrades [Solved]
Post by albfneto » Mon Aug 01, 2016 21:48
This issue was solved by itself.
after recent updating the repositories and upgrading the distro.
no more problem.
may be some momentaneous problem in the servers.
