☢ @@ Dependencies not found [Solved]
svantoviit
Post by svantoviit » Mon Mar 28, 2016 10:23
Upgrading on sabayon-weekly stops at an unsatisfied dependency.
Something is pulling dev-java/icedtea-bin:8 which is not available in Entropy.
# equo up --force && equo u -a
╠  @@ Repositories synchronization ...
╠   # Sabayon Linux Official Repository
╠   # Repository URL: http://pkg.sabayon.org/standard/sabayon-weekly/database/amd64/5 [bz2]
╠   # Repository local path: /var/lib/entropy/client/database/amd64/sabayon-weekly/standard/amd64/5
╠   # Repository API: 3
╠   #  (1/1) Scanning URL: http://pkg.sabayon.org/standard/sabayon-weekly/database/a╠   # Selected URL: http://pkg.sabayon.org/standard/sabayon-weekly/database/amd64/5 [bz2]
╠ 	Downloading repository ...
╠ 	Downloading checksum packages.db.dumplight.bz2.md5 ...
╠ 	packages.db.meta: available, w00t!.
╠ 	  << unpacked meta file: 00-sabayon.package.keywords
╠ 	  << unpacked meta file: 00-sabayon.package.mask
╠ 	  << unpacked meta file: 00-sabayon.package.unmask
╠ 	  << unpacked meta file: 00-sabayon.package.use
╠ 	  << unpacked meta file: cross-armv6j-hardfloat-linux-gnueabi
╠ 	  << unpacked meta file: cross-armv7a-hardfloat-linux-gnueabi
╠ 	  << unpacked meta file: cross-armv7a-unknown-linux-gnueabi
╠ 	  << unpacked meta file: eapi
╠ 	  << unpacked meta file: make.conf
╠ 	  << unpacked meta file: make.profile
╠ 	  << unpacked meta file: packages.db.critical
╠ 	  << unpacked meta file: packages.db.fallback_mirrors
╠ 	  << unpacked meta file: packages.db.keywords
╠ 	  << unpacked meta file: packages.db.lic_whitelist
╠ 	  << unpacked meta file: packages.db.mask
╠ 	  << unpacked meta file: packages.db.mirrors
╠ 	  << unpacked meta file: packages.db.post_update.sh
╠ 	  << unpacked meta file: packages.db.post_upgrade.sh
╠ 	  << unpacked meta file: packages.db.restricted
╠ 	  << unpacked meta file: packages.db.revision
╠ 	  << unpacked meta file: packages.db.system_mask
╠ 	  << unpacked meta file: packages.db.webservices
╠ 	  << unpacked meta file: parent
╠ 	  << unpacked meta file: signature.asc
╠ 	packages.db.meta.asc: not available, it's ok.
╠ 	notice.rss: available, w00t!.
╠ 	Repository revision: 3323
╠ 	Downloaded repository status: OK
╠ 	GPG key already installed for: sabayon-weekly
☛ 	Make sure to verify the imported key and set an appropriate trust level:
☛ 	$ gpg --homedir '/etc/entropy/client-gpg-keys' --edit-key 'F96DEF6B01C5BDAEB1BADB8CB116DA6F114D935D'
╠ 	Unpacking database to packages.db.dumplight ...
╠ 	Injecting downloaded dump packages.db.dumplight, please wait ...
╠ 	Indexing Repository metadata ...
╠  @@ /etc/make.profile: link differs. Updating.
╠  @@ Security Advisories: getting latest advisories ...
╠    # Security Advisories: verification successful.
╠  @@ Security Advisories: updated successfully
╠  @@  Notice board: sabayon-weekly
╠     [0] [Wed, 26 Feb 2014 13:46:17 +0000] Title: Running OpenRC is now unsupported
╠     [1] [Sat, 12 Sep 2015 18:34:50 +0000] Title: Replace KDM with SDDM!
╠  @@ Calculating System Updates:
╠  @@ Calculating dependencies...
☢  @@ Dependencies not found:
☢    # Not found: dev-java/icedtea-bin:8
How to solve this?
Re: ☢ @@ Dependencies not found
Post by wolfden » Mon Mar 28, 2016 10:49
have you used portaged and pulled it?
does running show anything?
equo query revdeps icedtea-bin
icedtea is in entropy, maybe uninstall the bin and install the other. How old is your installation?
svantoviit
Post by svantoviit » Mon Mar 28, 2016 12:13
wolfden wrote:have you used portaged and pulled it?
icedtea-bin? not that I remember
wolfden wrote:does running show anything?
# equo q revdeps -vq icedtea-bin
dev-java/icedtea-7.2.6.4-r1
java-virtuals/jdk-with-com-sun-20111111-r3
virtual/jdk-1.6.0-r2
wolfden wrote:icedtea is in entropy, maybe uninstall the bin and install the other.
# equo rm -a dev-java/icedtea-bin
╠  @@ These are the packages that would be removed:
╠  ## [sabayon-weekly] virtual/jre-1.6.0-r1 [0.0b]
╠  ## [sabayon-weekly] virtual/jdk-1.6.0-r2 [0.0b]
╠  ## [sabayon-weekly] dev-java/icedtea-bin-6.1.12.5 [128.5MB]
╠  @@ Packages that would be removed: 3
╠  @@ Freed disk space: 128.5MB
╠  @@ Total bandwidth wasted: 39.3MB
     Would you like to proceed ? [Yes/No] y
Uninstalling icedtea-bin doesn't help. Upgrade still requires dev-java/icedtea-bin:8.
wolfden wrote:How old is your installation?
Rolling since 6.
$ cat /etc/sabayon-edition
Sabayon Linux 6 amd64 XFCE
$ cat /etc/sabayon-release
Sabayon Linux amd64 16.04
# equo st | grep -Ei -m 2 "(revision|repository).*:"
╠     Repository name: sabayon-weekly
╠     Revision: 3323
# equo q updates
╠  @@ Available Updates
╠   Packages to update:  58
╠   Packages to remove:  41
Post by wolfden » Mon Mar 28, 2016 22:46
Yea I figured it had to be old as we use to have the bin package in entropy.
You should be able to uninstall all the packages than install icedtea, it should not pull the bin file.
 equo rm dev-java/icedtea-bin
equo install dev-java/icedtea
Post by wolfden » Tue Mar 29, 2016 1:51
It seems icetea-bin is back in entropy
@@ Package: dev-java/icedtea-bin-3.0.0_pre09-r1 branch: 5, [sabayonlinux.org]
╠          Available:     version: 3.0.0_pre09-r1 ~ tag: NoTag ~ revision: 0
╠          Installed:     version: 3.0.0_pre09-r1 ~ tag: NoTag ~ revision: 0
╠          Slot:          8
╠          Homepage:      http://icedtea.classpath.org
╠          Description:   A Gentoo-made binary build of the
╠                         IcedTea JDK
╠          License:       GPL-2-with-linking-exception
so everything should work for ya now
Post by Stupot » Tue Mar 29, 2016 4:42
I don't know why it's called icedtea-bin-3, certainly not following the previous icedtea naming conventions, but it does indeed provide the pre-release of openjdk 8.
svantoviit
Post by svantoviit » Tue Mar 29, 2016 6:00
wolfden wrote:You should be able to uninstall all the packages than install icedtea, it should not pull the bin file.
Doesn't work as I'm on weekly.
wolfden wrote:It seems icetea-bin is back in entropy
Wasn't there when I checked yesterday, it appeared just lately: 2016-03-28.
https://packages.sabayon.org/ wrote: dev-java/icedtea-bin-3.0.0_pre09-r1
A Gentoo-made binary build of the IcedTea JDK
binary → standard → sabayonlinux.org → amd64 → 5 | revision: 0 | date: 2016-03-28
Anyway it's missing in weekly, so it seems something went wrong in the Entropy repo chain.
I have sent a greeting to the entropy-team, so they are aware of it https://bugs.sabayon.org/show_bug.cgi?id=5184.
Pulled icetea-bin manually from the web and now the upgrade runs OK. Thank you for your help.
For those with the same issue:
$ wget "http://dl.sabayon.org/entropy/standard/sabayonlinux.org/packages/amd64/5/dev-java/dev-java:icedtea-bin-3.0.0_pre09-r1.505c918ea4e921da81fe03ef4dce9942bebcc0e4~0.tbz2"
# equo i -a dev-java\:icedtea-bin-3.0.0_pre09-r1.505c918ea4e921da81fe03ef4dce9942bebcc0e4~0.tbz2
